Home » Archived » BIRT » Large number of tables in data set/query designer
Large number of tables in data set/query designer [message #252382] Tue, 14 August 2007 12:29 Go to next message
Originally posted by: arinto.almedina.net
I use BIRT to design reports against a very large database that has
approximately 25000 tables (i know, that's a lot, but it is proprietary
software out of my control). When I create a new data set, Eclipse runs
out of memory because (i think) it tries to load all the table
definitions to display in the "Available Items" pane. If I increase the
memory available to Java using the "-vmargs -Xmx" option, the Data Set
Designer opens, but only after about 5 minutes of waiting, and no table
names are available in the Items pane.
I tested this behavior in several BIRT versions, up to and including 2.2.
Is there a way to pre-filter the table names or disable the "Available
Items" pane? Waiting 5 minutes each time I want to create or edit a data
set is a bit frustrating.
Pedro Arinto
Re: Large number of tables in data set/query designer [message #252453 is a reply to message #252382] Tue, 14 August 2007 21:48 Go to previous messageGo to next message
Pedro,
You can try this.
1. In eclipse with BIRT, Select Main menu Window->Preferences.
2. In preferences window, expand Report Design->Data Set Editor->JDBC Data
Set.
3. Specify maximum number of schemas and tables to display.
"Pedro Arinto" <arinto@almedina.net> wrote in message
news:f9sl9l$h84$1@build.eclipse.org...
> out of memory because (i think) it tries to load all the table definitions
> to display in the "Available Items" pane. If I increase the memory
> available to Java using the "-vmargs -Xmx" option, the Data Set Designer
> opens, but only after about 5 minutes of waiting, and no table names are
> Pedro Arinto
Re: Large number of tables in data set/query designer [message #252718 is a reply to message #252453] Thu, 16 August 2007 05:31 Go to previous message
Lchen,
Problem solved.
I never noticed that preference before... I must look more carefully
next time.
Thanks a lot,
Pedro
lchen wrote:
> Pedro,
> You can try this.
> Set.
>> Hi,
>> Thanks,
>> Pedro Arinto
Previous Topic:How to retrieve an IReportContext from the API using a RunAndRenderTask?
Next Topic:Platform already running error while running birt engine in another plugin
Current Time: Thu Sep 18 16:43:14 EDT 2025
Powered by FUDForum. Page generated in 0.03781 seconds
