Home » Archived » BIRT » getProperty() returns null
getProperty() returns null [message #252132] Mon, 13 August 2007 09:20 Go to next message
i'm using BIRT 2.2 and i've ran into this problem:
i created report with user property called "version". Later i need to
access that property using BIRT Runtime. I access it using getProperty()
method:
ReportRunnable reportDesign = engine.openReportDesign("Report.rptdesign");
String version = reportDesign.getProperty("version");
Now, when there's a library linked to Report.rptdesign, version is null.
When i remove the library from report design, it returns correct value.
Where's the problem? Am i accesing it wrong? How should i access user
properties with BIRT Runtime.
Re: getProperty() returns null [message #252147 is a reply to message #252132] Mon, 13 August 2007 09:58 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
This sounds like a bug. Can you log a bugzilla entry?
Jason
Gravy wrote:
> method:
> Thanks
Re: getProperty() returns null [message #252155 is a reply to message #252147] Mon, 13 August 2007 10:19 Go to previous message
Submitted as bug to bugzilla with id 199751:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=199751
Previous Topic:Another BIRT newbie question - Please help
Next Topic:BIRT 2.1.2 Chart report not working in 2.1.3 - please help
Current Time: Fri Jul 25 18:10:26 EDT 2025
Powered by FUDForum. Page generated in 0.51556 seconds
