Home » Language IDEs » Java Development Tools (JDT) » source refresh after running ant task
source refresh after running ant task [message #251955] Mon, 10 March 2008 09:45 Go to next message
I have an ant task that generates code (using JAXB's xjc task). After the
task is run I need to refresh the source tree, to that the newly generated
classes are picked up. Is there any way to do the refresh from within the
ant task?
Zohar
Re: source refresh after running ant task [message #251959 is a reply to message #251955] Mon, 10 March 2008 10:23 Go to previous messageGo to next message
Originally posted by: eclipse-news.rizzoweb.com
zohar wrote:
> Hello,
> the task is run I need to refresh the source tree, to that the newly
> generated classes are picked up. Is there any way to do the refresh from
> within the ant task?
How are you invoking the Ant script? If you're launching it from inside
Eclipse, it uses a Launch configuration and you can edit that (via the
External Tools dialog - icon on the toolbar looks like a green circle,
white triangle, and red toolbox) and set it up to automatically refresh
the project after Ant runs.
Hope this helps,
Eric
Re: source refresh after running ant task [message #251979 is a reply to message #251955] Tue, 11 March 2008 06:42 Go to previous messageGo to next message
Originally posted by: valere.fedronic.ext.streamezzo.com
<eclipse.refreshLocal resource="MyProject/MyFolder" depth="infinite"/>
* resource is a resource path relative to the workspace
* depth can be one of the following: zero, one or infinite
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/ant_eclipse_tasks.htm
Valere.
zohar a écrit :
> Hello,
> Zohar
Re: source refresh after running ant task [message #251987 is a reply to message #251979] Tue, 11 March 2008 09:40 Go to previous messageGo to next message
I get:
BUILD FAILED
c:\myWork\build.xml:193: Problem: failed to create task or type
Cause: The name is undefined.
Action: Check the spelling.
Action: Check that any custom tasks/types have been declared.
Action: Check that any <presetdef>/<macrodef> declarations have taken place.
"valere fedronic" <valere.fedronic.ext@streamezzo.com> wrote in message
news:fr5nni$ldc$1@build.eclipse.org...
> Valere.
> zohar a écrit :
>> Hello,
>> Thanks,
>> Zohar
Re: source refresh after running ant task [message #251990 is a reply to message #251987] Tue, 11 March 2008 09:57 Go to previous message
The Ant builds needs to run in the same VM as Eclipse itself. See your
launch configuration for this setting.
Greets
Benny
zohar wrote:
> I get:
> BUILD FAILED
> place.
>> Hi,
>> Valere.
>> zohar a écrit :
>>> Hello,
>>> from within the ant task?
>>> Thanks,
>>> Zohar
Previous Topic:Error creating a Jar file in Java Project
Next Topic:How to prevent cursor re-positioning?
Current Time: Fri Jul 25 12:13:43 EDT 2025
Powered by FUDForum. Page generated in 0.27027 seconds
