Home » Language IDEs » Java Development Tools (JDT) » Problem wih Java Profiling on eclipse
Problem wih Java Profiling on eclipse [message #251939] Mon, 10 March 2008 06:59 Go to next message
Originally posted by: naresh1710.rediff.com
here iam trying t use the java profiling in eclipse
i followed the following steps
Installation
- Shutdown Eclipse.
- Unzip the contents of the zip file into the plugins directory of your
Eclipse directory.
- Copy ProfilerDLL.dll from root plugin folder into bin folder of your
JRE installation.
- Restart Eclipse.
- Open "Profiler" perspective.
- Create profiler launch configuration.
- Launch it.
can you please let me know the actual problem ,
Appriciate for the earliest answer...
Naresh
Re: Problem wih Java Profiling on eclipse [message #251943 is a reply to message #251939] Mon, 10 March 2008 08:29 Go to previous message
Naresh,
Is this a TPTP question? I.e., where did you get the plugins for
profiling? I read all this and don't see that you've actually described
a problem. Only a series of steps. If it's a TPTP question, use their
newsgroup to ask about it. news://news.eclipse.org/eclipse.tptp Be sure
to describe the symptoms of the problem, not just steps that might work
well for everyone else. Also mention the version of Eclipse and these
plugins you are using as well as the version of your JRE.
Naresh wrote:
> Hi here iam trying t use the java profiling in eclipse
> Installation
> - Shutdown Eclipse.
> your Eclipse directory. - Copy ProfilerDLL.dll from root plugin
> folder into bin folder of your JRE installation.
> - Restart Eclipse.
> - Launch it.
> Thanks
> Naresh
Previous Topic:Highlighting All Variable Occurences When Cursor On Declaration
Next Topic:variables' value display
Current Time: Sun Nov 02 19:53:43 EST 2025
Powered by FUDForum. Page generated in 0.03883 seconds
