[3.3.2] exit code 13 with antrunner -- please help!!!!!!! [message #251897] |
Wed, 05 March 2008 18:46  |
Originally posted by: bmf1972.fastmail.fm
Hi all,
I am not sure that this is the right newsgroup; if not, then please let
me know.
I am using the maven-pde-plugin to launch an Eclipse plugin build.
So far things were working nice and I still have a machine on which the
build runs. I assume that after applying few updates (don't know which)
my build begun to fail :(
[INFO] [pde:ext]
[INFO] java -classpath C:\PROGRA~1\Java\ECLIPS~2.0\startup.jar
org.eclipse.core.
launcher.Main -application org.eclipse.ant.core.antRunner -buildfile
C:\document
s\pm\project-trunks\wirexn\lang\eclipse\features\org.wirexn. lang.eclipse.feature
\target\pdeBuilder\build.xml
[INFO]
[ERROR] BUILD ERROR
[INFO]
[INFO] Error executing command line. Exit code:13
(NOTE: startup.jar is a soft-link to the latest version of the equinox
launcher)
The .log file shows:
!SESSION 2008-03-06 01:26:25.890
eclipse.buildId=I20070625-1500
java.version=1.6.0_03
Framework arguments: -application org.eclipse.ant.core.antRunner
-buildfile
C:\documents\pm\project-trunks\wirexn\lang\eclipse\features\ org.wirexn.lang.eclipse.feature\target\pdeBuilder\build.xml
Command-line arguments: -application org.eclipse.ant.core.antRunner
-buildfile
!ENTRY org.eclipse.ant.core 4 3 2008-03-06 01:26:26.906
!MESSAGE The library "jsdtCompilerAdapter.jar" specified from
"org.eclipse.wst.jsdt.core" for the antTasks or antTypes extension does
not exist
"org.eclipse.wst.jsdt.core" for the extraClasspathEntries extension does
not exist
!ENTRY org.eclipse.ant.core 4 2 2008-03-06 01:26:27.109
!MESSAGE Malformed URL.
!STACK 0
at
org.eclipse.core.internal.runtime.Activator.getURLConverter( Activator.java:313)
at org.eclipse.core.runtime.FileLocator.toFileURL(FileLocator.j ava:163)
at
org.eclipse.ant.core.AntCorePreferences.addLibraries(AntCore Preferences.java:834)
at
org.eclipse.ant.core.AntCorePreferences.getDefaultAntHomeEnt ries(AntCorePreferences.java:440)
at
org.eclipse.ant.core.AntCorePreferences.getDefaultAntHome(An tCorePreferences.java:301)
at
org.eclipse.ant.core.AntCorePreferences.restoreAntHome(AntCo rePreferences.java:289)
at
org.eclipse.ant.core.AntCorePreferences.restoreCustomObjects (AntCorePreferences.java:194)
at
org.eclipse.ant.core.AntCorePreferences.<init>(AntCorePreferences.java:160)
at
org.eclipse.ant.core.AntCorePlugin.setRunningHeadless(AntCor ePlugin.java:232)
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:493)
at org.eclipse.ant.core.AntRunner.start(AntRunner.java:599)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
at org.eclipse.core.launcher.Main.main(Main.java:30)
!ENTRY org.eclipse.osgi 4 0 2008-03-06 01:26:27.828
!MESSAGE Application error
!STACK 1
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:512)
at
at
at
at
at
Caused by: java.lang.NoClassDefFoundError:
org/apache/tools/ant/launch/AntMain
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$000(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at
org.eclipse.ant.internal.core.AntClassLoader.findClass(AntCl assLoader.java:54)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at
org.eclipse.ant.internal.core.ant.InternalAntRunner.getAntVe rsionNumber(InternalAntRunner.java:888)
at
org.eclipse.ant.internal.core.ant.InternalAntRunner.isVersio nCompatible(InternalAntRunner.java:908)
at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:504)
at
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:495)
... 20 more
Root exception:
java.lang.NoClassDefFoundError: org/apache/tools/ant/launch/AntMain
at
at
at
at
at
at
at
at
at
at
Seems like the root cause is this missing class:
Now, I am looking into
plugins\org.apache.ant_1.7.0.v200706080842\lib\ant-launcher. jar\org\apache\tools\ant\launch\
and there is an AntMain.class! Perhaps it's too late and I should go to
sleep...
Please help,
Adrian.
Re: [3.3.2] exit code 13 with antrunner -- please help!!!!!!! [message #251917 is a reply to message #251897] |
Sun, 09 March 2008 03:41  |
Apparently, after installing the Axis2 plugin, the Ant Home directory
configuration is changed to the Axis2 Home directory...
After changing the Ant Home directory under Preferences > Ant > Runtime
> Classpath > Ant Home Entries, everything works as expected.
Adrian Herscu wrote:
> Hi all,
> me know.
> [INFO] [pde:ext]
> org.eclipse.core.
> C:\document
> [INFO]
> [ERROR] BUILD ERROR
> [INFO]
> launcher)
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> -buildfile
> -buildfile
> not exist
> not exist
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 1
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> ... 20 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sleep...
> Please help,
> Adrian.
FUDForum. Page generated in 1.04311 seconds
