Home » Archived » BIRT » Border SIze
Border SIze [message #251276] Sun, 05 August 2007 21:57 Go to next message
Originally posted by: dean.kosko.blackrock.UYHREMOVESDNN.com
All,
Is there any way to override the 3 default border sizes? I tried putting 1
pt into a CSS and importing it, but it did not recognize it.
Thanks in advance for any info..
Dean
Re: Border SIze [message #251292 is a reply to message #251276] Mon, 06 August 2007 02:06 Go to previous messageGo to next message
You can modify the default border size in ROM.DEF. ROM.DEF is the
meta-data definition file. When the application startup, the meta-data
system will be initialized and loaded into a meta-data dictionary. It is a
global, shared dictionary of design meta-data information. The ROM file is
under the org.eclipse.birt.report.model.elements packages in
org.eclipse.birt.report.model plugin
Regards!
Re: Border SIze [message #251299 is a reply to message #251292] Mon, 06 August 2007 02:13 Go to previous message
About rom: http://www.eclipse.org/birt/ref/
Previous Topic:How to install BIRT ?
Next Topic:How to access a java class in birt report
Current Time: Sat Nov 08 09:32:13 EST 2025
Powered by FUDForum. Page generated in 0.03420 seconds
