Home » Language IDEs » Java Development Tools (JDT) » using Eclipse in Jboss env..
using Eclipse in Jboss env.. [message #251173] Thu, 31 January 2008 18:32 Go to next message
Originally posted by: ceek63.yahoo.com
Here's my development env:
J2SE 5
Jboss 4.x
Eclipse 3.x
Linux
I have my current Java src tree with build.xml. Should I create a Java
perspective or J2EE perspective? Should I import build.xml or just src
directory? Am lost in trying to find the right first step in setting up my
development environment mainly to perform debugging operations. I mainly
develop JSPs and servlets.
Thanks for the pointers.
anyone knows EMF based Java metamodel? [message #251192 is a reply to message #251173] Fri, 01 February 2008 11:00 Go to previous messageGo to next message
I wonder if there exist a EMF equivalent from the Java "metamodel" in
org.eclipse.jdt.core.dom. My intention is to use it as target metamodel
in a QVT transformation, i.e. to write a codegenerator with QVT. And
there would be still the problem to map an according EMF model to
instances of classes in org.eclipse.jdt.core.dom, in order to call the
toString() method on them..
Any idea?
Re: anyone knows EMF based Java metamodel? [message #251196 is a reply to message #251192] Fri, 01 February 2008 12:19 Go to previous message
Jörg,
The JEM model used the WTP and VE is like that. We also have a Java
model (not very complete) example in EMF's examples feature...
Jörg Kiegeland wrote:
> Hello,
> metamodel in a QVT transformation, i.e. to write a codegenerator with
> QVT. And there would be still the problem to map an according EMF
> model to instances of classes in org.eclipse.jdt.core.dom, in order to
> call the toString() method on them..
> Any idea?
Previous Topic:problem creating lib directory
Next Topic:How to attach source of JSF implementation?
Current Time: Sat Nov 15 21:13:17 EST 2025
Powered by FUDForum. Page generated in 0.03949 seconds
