Home » Newcomers » Newcomers » Eclipse 3.3.1.1 Continually freezes under XP
Eclipse 3.3.1.1 Continually freezes under XP [message #250817] Tue, 04 March 2008 22:04 Go to next message
Originally posted by: shane.urbanheadz.com
I have been using eclipse as my development software for some time now. A
few weeks ago I needed to set up a development machine so I used eclipse.
It was working fine for a while and then it started to freeze
periodically. I will be typing then it will freeze for 5 to 15 seconds and
then be fine again. I have put up with this for a couple of weeks in an
attempt to find a pattern but have fail. It is drving me MAD. Sometimes
its quite a time between freeze and sometimes its just 15 or so seconds
then it will freeze again. And it happens when I do anything. Save, type,
click, etc. I have installed the latest JDK 1.6 with no success.
Does anyone have any experience with this problem? Can someone help me
before I lost my head?
Re: Eclipse 3.3.1.1 Continually freezes under XP [message #250822 is a reply to message #250817] Tue, 04 March 2008 23:58 Go to previous messageGo to next message
Check out this link:
http://www.eclipsezone.com/eclipse/forums/t61618.html
Pay particular attention to the -XX:MaxPermSize=128M bit.
HTH,
Wayne
Re: Eclipse 3.3.1.1 Continually freezes under XP [message #250830 is a reply to message #250817] Wed, 05 March 2008 01:47 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Shane" <shane@urbanheadz.com> wrote in message
news:eba6e4a83f97c8d884fb09ce55143fa2$1@www.eclipse.org...
>It was working fine for a while and then it started to freeze periodically.
>I will be typing then it will freeze for 5 to 15 seconds and then be fine
>again. I have put up with this for a couple of weeks in an attempt to find
>a pattern but have fail. It is drving me MAD. Sometimes its quite a time
>between freeze and sometimes its just 15 or so seconds then it will freeze
>again. And it happens when I do anything. Save, type, click, etc. I have
I wonder if there is a networking issue. Perhaps one of the components
(WTP? Mylin?) is trying to access schemas or bug databases over the
network?
Your post is not entirely clear about what the difference is between the new
and old development machines. That would be helpful information. Also it
would be good to know what OS you are on, and what Eclipse components you've
installed.
Re: Eclipse 3.3.1.1 Continually freezes under XP [message #251355 is a reply to message #250817] Wed, 12 March 2008 06:38 Go to previous message
> now. A few weeks ago I needed to set up a development machine so I
> used eclipse. It was working fine for a while and then it started to
> freeze periodically. I will be typing then it will freeze for 5 to 15
> seconds and then be fine again. I have put up with this for a couple
> of weeks in an attempt to find a pattern but have fail. It is drving
> me MAD. Sometimes its quite a time between freeze and sometimes its
> just 15 or so seconds then it will freeze again. And it happens when I
> do anything. Save, type, click, etc. I have installed the latest JDK
Make stack dumps while it freezes and check whether it's at the same
location. Then file a bug report.
Dani
Previous Topic:Where can I get the "Readme" example plugin
Next Topic:disable auto-indent in C/C++ editor
Current Time: Tue Jul 22 23:01:36 EDT 2025
Powered by FUDForum. Page generated in 0.09146 seconds
