| NullPointerException when exporting report containing Bar Chart to PDF [message #250551] |
Tue, 31 July 2007 12:11  |
Originally posted by: stefan.risto.novosec.com
I have a report with a bar chart in a group header. Preview and export
to html is fine, but whenever I try to export it to pdf I get a
NullPointerException (Stacktrace attached below).
If I remove the chart the export works.
Does anyone have an idea what causes this NPE?
I appreciate your help,
Stefan
31.07.2007 17:59:14 org.eclipse.birt.data.engine.impl.QueryResults close
FEIN: QueryResults is closed
31.07.2007 17:59:14
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask doRun
SCHWERWIEGEND: An error happened while running the report. Cause:
at
org.eclipse.birt.report.engine.internal.executor.dom.DOMRepo rtItemExecutor.execute(DOMReportItemExecutor.java:39)
at
org.eclipse.birt.report.engine.layout.content.ListContainerE xecutor$ExecutorList.getNextChild(ListContainerExecutor.java :85)
at
org.eclipse.birt.report.engine.layout.content.BlockStackingE xecutor.getNextChild(BlockStackingExecutor.java:45)
at
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .traverseChildren(PDFBlockStackingLM.java:86)
at
org.eclipse.birt.report.engine.layout.pdf.PDFListLM.traverse Children(PDFListLM.java:110)
at
org.eclipse.birt.report.engine.layout.pdf.PDFStackingLM.layo utChildren(PDFStackingLM.java:118)
at
org.eclipse.birt.report.engine.layout.pdf.PDFAbstractLM.layo ut(PDFAbstractLM.java:132)
at
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .layoutChildNode(PDFBlockStackingLM.java:109)
at
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .traverseChildren(PDFBlockStackingLM.java:89)
at
at
at
org.eclipse.birt.report.engine.layout.pdf.PDFRowLM.traverseC hildren(PDFRowLM.java:88)
at
at
at
at
at
org.eclipse.birt.report.engine.layout.pdf.PDFTableLM.travers eChildren(PDFTableLM.java:108)
at
at
at
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .traverseChildren(PDFBlockStackingLM.java:68)
at
at
at
at
at
at
at
org.eclipse.birt.report.engine.layout.pdf.PDFRowLM.traverseC hildren(PDFRowLM.java:101)
at
at
at
at
at
at
at
at
at
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.layout(P DFPageLM.java:212)
at
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layoutReport(PDFReportLayoutEngine.java:64)
at
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layout(PDFReportLayoutEngine.java:87)
at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:148)
at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:71)
at ExecuteReport.executeReport(ExecuteReport.java:107)
at ExecuteReport.main(ExecuteReport.java:119)
Mit freundlichen Grüßen
Stefan Risto
FUDForum. Page generated in 0.24850 seconds
