Home » Archived » BIRT » How can I enumerate row in group??
How can I enumerate row in group?? [message #250144] Fri, 27 July 2007 05:52 Go to next message
Originally posted by: dexiu.dexiu.pl
I have report where i must do this:
group 1
index | content of row
1 | abcd
2 | asdf
3 | aser
group 2
1 | fret
2 | hrth
3 | kkff
Sebastian Nowak
Re: How can I enumerate row in group?? [message #250148 is a reply to message #250144] Fri, 27 July 2007 05:58 Go to previous messageGo to next message
Dexiu pisze:
> group 1
> 1 | abcd
> 2 | asdf
> 3 | aser
> group 2
> 1 | fret
> 2 | hrth
> 3 | kkff
> Sebastian Nowak
How can i do this??
Sebastian Nowak
Re: How can I enumerate row in group?? [message #250175 is a reply to message #250148] Fri, 27 July 2007 11:21 Go to previous messageGo to next message
Dexiu ha scritto:
> Dexiu pisze:
>> group 1
>> 1 | abcd
>> 2 | asdf
>> 3 | aser
>> group 2
>> 1 | fret
>> 2 | hrth
>> 3 | kkff
>> Sebastian Nowak
> How can i do this??
> Sebastian Nowak
Hi!
Add a data field in your table and select RowNum from available
columns binding.
row.__rownum will appear in the expression.
Remember that RowNum starts counting from 0 (zero).
So you'll write row.__rownum+1
Easy, right ? :)
Bye
Nico
Re: How can I enumerate row in group?? [message #250312 is a reply to message #250175] Mon, 30 July 2007 03:05 Go to previous messageGo to next message
Nico pisze:
> Dexiu ha scritto:
>> Dexiu pisze:
>>> group 1
>>> 1 | abcd
>>> 2 | asdf
>>> 3 | aser
>>> group 2
>>> 1 | fret
>>> 2 | hrth
>>> 3 | kkff
>>> Sebastian Nowak
>> How can i do this??
>> Sebastian Nowak
> Hi!
> columns binding.
> Easy, right ? :)
> Bye
> Nico
Hi, it's not so easy
row.__rownum+1 return
group 1
1 | abcd
2 | asdf
3 | aser
group 2
4 | fret
5 | hrth
6 | kkff
Re: How can I enumerate row in group?? [message #250325 is a reply to message #250312] Mon, 30 July 2007 04:20 Go to previous messageGo to next message
Hi Dexiu
The row.__rownum is the index of all row of table, currently it can not
define index based on group. You can try these way:
1, Drag a aggregation from palette into your table to instead of index
column.
2, Select the Data field to "content of row" column
3, Select the function to RUNNINGCOUNT
4, Select Aggregation on Group you defined in table.
I hope that will fill your need.
Regards!
Re: How can I enumerate row in group?? [message #250328 is a reply to message #250312] Mon, 30 July 2007 04:24 Go to previous messageGo to next message
Hi Dexiu
I attached the report design file, that file may help you to solve that.
Regards!
Tianli
"Dexiu" <dexiu@dexiu.pl> wrote in message
news:f8k2j0$u2o$1@build.eclipse.org...
> Nico pisze:
>> Dexiu ha scritto:
>>> Dexiu pisze:
>>>> group 1
>>>> 1 | abcd
>>>> 2 | asdf
>>>> 3 | aser
>>>> group 2
>>>> 1 | fret
>>>> 2 | hrth
>>>> 3 | kkff
>>>> Sebastian Nowak
>>> How can i do this??
>>> Sebastian Nowak
>> Hi!
>> columns binding.
>> Easy, right ? :)
>> Bye
>> Nico
> group 1
> 1 | abcd
> 2 | asdf
> 3 | aser
> group 2
> 4 | fret
> 5 | hrth
> 6 | kkff
Re: How can I enumerate row in group?? [message #250366 is a reply to message #250325] Mon, 30 July 2007 08:12 Go to previous messageGo to next message
Tianli pisze:
> Hi Dexiu
> column.
> Regards!
RUNNINGCOUNT - I don't have this function :( or I can't find...
Re: How can I enumerate row in group?? [message #250467 is a reply to message #250366] Mon, 30 July 2007 20:33 Go to previous message
Hi Dexiu
Have you seen the report design I attached? The normal dataitem has no
function list, you should use the Aggregation, it's in Palette's Quick
Tools.
It can count your row based on group of table or the whole table.
Regards!
Previous Topic:Algum Brazuca na lista !???
Next Topic:Image generation
Current Time: Fri Sep 19 00:45:06 EDT 2025
Powered by FUDForum. Page generated in 0.03482 seconds
