Home » Archived » BIRT » Designer Local JNDI
Designer Local JNDI [message #249098] Fri, 20 July 2007 03:38 Go to next message
This is a little request for feature, I think it would be nice to have a
kind of 'local' JNDI in the designer in order to simulate the runtime
engine of a server like Tomcat.
Currently we're using the BIRT Designer with some DataSources that a
linked 'in hard' to a developpment database. When we want to deploy our
report in a test or production environment, we usually modify the
"database URL" of the Datasource in order to avoid a fallback to the
development database.
Sometimes we forget to do so and sometimes Tomcat lose it's context
informations and we have a report that goes to the wrong database ...
What would be cool is to have a report file that is exactly the same in
development and in production. We would just specify a JNDI name in the
datasource and a local JNDI serveur in the designer (something like this
http://www.javaranch.com/codebarn.jsp) would serve the connexion.
Best Regards,
Tchule.
PS : A side question, what is the purpose of the <xml-property
name="designerValues"> tag in the rptdesign file. Is it some kind of
cached result for the designer ? It is necessary in a production report
engine ? Shouldn't it be in the rptconfig file ?
Re: Designer Local JNDI [message #249197 is a reply to message #249098] Fri, 20 July 2007 12:40 Go to previous messageGo to next message
tchule,
I think I follow your request. You might want to document it up a bit more,
provide use cases, and submit it to Bugzilla.
Scott Rosenbaum
> report engine ? Shouldn't it be in the rptconfig file ?
Re: Designer Local JNDI [message #249483 is a reply to message #249197] Tue, 24 July 2007 03:03 Go to previous messageGo to next message
OK, thanks a lot.
Bugzilla entry 197443 created.
Tchule.
Re: Designer Local JNDI [message #250235 is a reply to message #249098] Fri, 27 July 2007 18:41 Go to previous message
From your use case, it seems the main objective is to be able to externalize
the data source properties from your report designs. This way the
externalized properties can change in a deployment environment without
changing the report designs themselves. Using a local JNDI service would
be one way to do that, but may be an overkill.
What we do have support now in BIRT 2.2 is to use an externalized connection
profile stored in a separate file. See this link for an overview:
http://www.eclipse.org/birt/phoenix/project/notable2.2.php#j ump_22
Hope this helps.
Linda
"tchule" <tchule@hotmail.com> wrote in message
news:dada149277936c4bec482f19ddb77f69$1@www.eclipse.org...
> Hello,
> Best Regards,
> Tchule.
Previous Topic:Open BIRT Report Designer from RCP application
Next Topic:localization support
Current Time: Wed Sep 03 16:51:50 EDT 2025
Powered by FUDForum. Page generated in 0.06111 seconds
