Home » Newcomers » Newcomers » Problem Writing Resource
Problem Writing Resource [message #250162] Mon, 25 February 2008 23:20 Go to next message
Originally posted by: khewuwei.gmail.com
I have encountered a error while checking out a CVS project using eclipse.
The error message is:
"Checking out 'tinyos-1.x' from CVS (Time of error: February 26, 2008
11:43:02 AM SST)
Reason:
Problem Writing resource
'tinyos-1.x/contrib/imote2/tools/src/iMoteTerm/USB/rev1/hids di.h'. Timeout
while reading from input stream"
May I know how to solve this issue? Greatly appreciate any help rendered.
Thank you.
U-Wei
Re: Problem Writing Resource [message #250208 is a reply to message #250162] Tue, 26 February 2008 08:11 Go to previous message
U-Wei,
It sounds like there was a network glitch that caused the attempt to
read the repository contents to time out. Do you get this problem each
time you try. Is your fire wall allowing Eclipse this type of network
access.
> eclipse. The error message is:
> 11:43:02 AM SST)
> Reason:
> Timeout while reading from input stream"
> Thank you.
> Best regards,
> U-Wei
Previous Topic:Using SelectionService to update several views
Next Topic:cookbooks
Current Time: Sun Nov 09 05:20:32 EST 2025
Powered by FUDForum. Page generated in 0.09294 seconds
