Home » Archived » BIRT » caching problem
caching problem [message #249290] Fri, 20 July 2007 23:56 Go to next message
I found that while i try to run the birt report from my local pc(windows
xp) to server (linux), there will caused http status 404 error. i think
it's coz by the caching references in linux server which cannot be
recognize by windows. So anyway to remove the caching folder(eg.
birt.war/documents)? thanks
Re: caching problem [message #249370 is a reply to message #249290] Mon, 23 July 2007 11:11 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Faireni,
I am not sure what you are describing, but if you use &__overwrite=true
in the url the rptdocument should be overwritten.
Jason
Re: caching problem [message #249480 is a reply to message #249370] Tue, 24 July 2007 02:45 Go to previous messageGo to next message
what should i do in order to remove the 'documents' folder in my birt.war
file?? i have deleted
<context-param>
<param-name>BIRT_VIEWER_DOCUMENT_FOLDER</param-name>
<param-value></param-value>
</context-param>
in web.xml and web-template.xml but the documents folder still appeared.
What Should i do then? Thanks.
Re: caching problem [message #249545 is a reply to message #249480] Tue, 24 July 2007 11:43 Go to previous messageGo to next message
You have to have some place to write the documents, unless you are only
doing runandrender task which happens when you use /preview or /run
(Birt 2.1 only). You can specify a complete path in this entry like
c:/temp.
Jason
> birt.war file?? i have deleted
> <context-param>
> </context-param>
Re: rptdocument caching problem in linux [message #249665 is a reply to message #249545] Tue, 24 July 2007 22:18 Go to previous messageGo to next message
jason,
i encounter this problem which the .rptdocument file will cause the 'http
error status 404" problems in linux jboss server. look like linux can't
recognized the .rptdocuments file type that are auto-generated. Can u help
me? thankx
Re: rptdocument caching problem in linux [message #249746 is a reply to message #249665] Wed, 25 July 2007 11:35 Go to previous messageGo to next message
Faireni,
I am not certain what you mean. The Viewer should work fine in this
situation. Can you explain how it is failing? What url are you
entering and what does the log file show?
Jason
faireni wrote:
> jason,
> 'http error status 404" problems in linux jboss server. look like linux
> can't recognized the .rptdocuments file type that are auto-generated.
> Can u help me? thankx
Re: rptdocument caching problem in linux [message #249862 is a reply to message #249746] Wed, 25 July 2007 20:45 Go to previous messageGo to next message
Jason,
the situation is like this, I'm working with birt 2.1.1 to design the
report and deploy a birt.war file in jboss server (not my local computer,
and the os of the server is linux). I have hard-coded my report to run
with the prefix "http://172.16.0.50:8080/birt/run?__report=report\\" and i
have a report perspective in my rcp project.
1) when i run frameset with the url as below thru Internet explorer, the
report shown in pretty condition.
http://172.16.0.50:8080/birt/frameset?__report=report\Invent oryListingReport.rptdesign&camp=%20a%20bc%20Sdn%20Bhd%20 %20-%20LKB&titles=Invoice%20Date%20:%202007-07-25,2007-0 7-25,Category%20:%20ACC,WE&stmt=%20FROM%20sp_inventory%2 0WHERE%20sp_inventory.UPDATE_ON%20> =%20%222007-07-25%2000:00:00%22%20and%20sp_inventory.UPDATE_ ON%20 < =%20%222007-07-25%2023:59:59%22%20and%20sp_inventory.CATEGOR Y%20 >=%20%22ACC%22%20and%20sp_inventory.CATEGORY%20<=%20%22WE%22
2) After i run in frameset, i tried to run in /run? in my rcp project as
below:
http://172.16.0.50:8080/birt/run?__report=report\InventoryLi stingReport.rptdesign&camp=%20a%20bc%20Sdn%20Bhd%20%20-% 20LKB&titles=Invoice%20Date%20:%202007-07-25,2007-07-25, Category%20:%20ACC,WE&stmt=%20FROM%20sp_inventory%20WHER E%20sp_inventory.UPDATE_ON%20> =%20%222007-07-25%2000:00:00%22%20and%20sp_inventory.UPDATE_ ON%20 < =%20%222007-07-25%2023:59:59%22%20and%20sp_inventory.CATEGOR Y%20 >=%20%22ACC%22%20and%20sp_inventory.CATEGORY%20<=%20%22WE%22
the error below shown:
HTTP Status 404 - /birt/run
type Status report
message /birt/run
description The requested resource (/birt/run) is not available.
Apache Tomcat/5.5.9
But i try to run in the sequence as i stated above in my local
server(127.0.0.1, os=Windows xp), I didn't encounter problem http status
404.
What has happen? Please help, I've running out of idea. So i try to remove
the auto-generated document folder which contain of binary file
rptdocument but as u said, i can't do this if run in framest, rite?
hope to hear from u soon. Thanks. :-)
Re: rptdocument caching problem in linux [message #250049 is a reply to message #249862] Thu, 26 July 2007 11:42 Go to previous messageGo to next message
Faireni,
Does the Frameset url work on the linux box?
Also, although I do not think it will make a difference reverse your \
with /. So this
becomes
http://172.16.0.50:8080/birt/run?__report=report/
Jason
faireni wrote:
> Jason,
> computer, and the os of the server is linux). I have hard-coded my
> report to run with the prefix
> "http://172.16.0.50:8080/birt/run?__report=report\\" and i have a report
> below:
> type Status report
> message /birt/run
> Apache Tomcat/5.5.9
> 404.
> remove the auto-generated document folder which contain of binary file
> rptdocument but as u said, i can't do this if run in framest, rite? hope
Re: rptdocument caching problem in linux [message #250132 is a reply to message #250049] Fri, 27 July 2007 03:04 Go to previous messageGo to next message
Jason,
sorry because I haven't test with in linux own browser since the linux
server is not at my site. i just tried to access the database and view
report on IE assigning the server ip eg.172.16.0.50, I dun dare to try
again since i don't have the access to manually delete the auto-generated
document folder. Nad hence everytime the 'documents' folder is generated,
all the reports can't be viewed due to the 'http status 404 error'.
jason, do u have any better suggestion or testing method?
Re: rptdocument caching problem in linux [message #250178 is a reply to message #250132] Fri, 27 July 2007 11:30 Go to previous messageGo to next message
Faireni,
I do not think this problem has to do with the documents folders.
Can you log a bugzilla entry?
Jason
faireni wrote:
> Jason,
> auto-generated document folder. Nad hence everytime the 'documents'
> folder is generated, all the reports can't be viewed due to the 'http
> status 404 error'.
Re: rptdocument caching problem in linux [message #250247 is a reply to message #250178] Fri, 27 July 2007 22:18 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=198173
Previous Topic:localization support
Next Topic:IE 7 fails to display contents of JSP pages containing BIRT tag library elements
Current Time: Fri Jul 25 12:14:36 EDT 2025
Powered by FUDForum. Page generated in 0.05719 seconds
