Problem on BIRT viewer on Tomcat [message #249257] |
Fri, 20 July 2007 21:03  |
Originally posted by: mackingzone.gmail.com
Hi all,
I built a simple report to a jdbc data source(sql server) using the
eclipse report designer, and now trying to view it through my web viewer.
But I'm running into problems, Tomcat doesn't seem to allow the viewer to
connect to the database. Could anyone shed some lights?
Here is how I deployed the BIRT viewer to my server.
1) Downloaded the BIRT runtime 2.2
2) Copy the entire 'WebViewerExample' to my <server>/webapps/ folder (not
directly under Tomcat though, I modified the server.xml (within Tomcat) to
point to the viewer (WebViewerExample).
3) Although I already had my jdbc driver deployed on my server, I couldn't
figure out how I can modify the classpath to include the jdbc drivers.
Instead, I followed the instruction, and copied the jdbc drivers into
< server/webapps/WebViewerExample/WEB-INF/platform/org.eclipse .birt.report.data.oda.jdbc_2.2.0.v20070615/drivers
folder.
4) I also modified the catalina.policy to grant the permission for the
jdbc drivers.
But after all these, I still seem to have problem getting it working
properly.
Here is the detail log.
Jul 20, 2007 3:23:37 PM
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager
openConnection
SEVERE: Cannot open connection.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Failed to get
connection.
SQL error #1: java.security.AccessControlExceptionaccess denied
(java.net.SocketPermission xxx.0.0.1:1433 connect,resolve)
com.inet.tds.l: java.security.AccessControlExceptionaccess denied
at
org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUr l(Connection.java:154)
at
org.eclipse.birt.report.data.oda.jdbc.Connection.open(Connec tion.java:111)
at
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo nnection.open(OdaConnection.java:235)
at
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:149)
at
org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:134)
at
org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:121)
at
org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiD ataSource(DataSourceRuntime.java:214)
at
org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSour ce(QueryExecutor.java:265)
at
org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(QueryExecutor.java:210)
at
org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:486)
at
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:161)
at
org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute (PreparedOdaDSQuery.java:142)
at
org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.execute(DataRequestSessionImpl.java:423)
at
org.eclipse.birt.report.engine.data.dte.DataGenerationEngine .doExecuteQuery(DataGenerationEngine.java:149)
at
org.eclipse.birt.report.engine.data.dte.DataGenerationEngine .doExecuteQuery(DataGenerationEngine.java:111)
at
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:178)
at
org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1678)
at
org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:82)
at
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:61)
at
org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 5)
at
org.eclipse.birt.report.engine.internal.executor.emitter.Rep ortItemEmitterExecutor.execute(ReportItemEmitterExecutor.jav a:45)
at
at
org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:42)
at
org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutChildren(HTMLBlockStackingLM.java:63)
at
org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:171)
at
org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.resumeLayout(HTMLInlineStackingLM.java:94)
at
org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.layoutChildren(HTMLInlineStackingLM.java:138)
at
org.eclipse.birt.report.engine.layout.html.HTMLRowLM.layoutC hildren(HTMLRowLM.java:41)
at
at
org.eclipse.birt.report.engine.layout.html.HTMLRowLM.layout( HTMLRowLM.java:31)
at
org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutChildren(HTMLBlockStackingLM.java:68)
at
org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou tChildren(HTMLTableLM.java:81)
at
at
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children(HTMLPageLM.java:142)
at
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:84)
at
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:90)
at
org.eclipse.birt.report.engine.presentation.ReportDocumentBu ilder.build(ReportDocumentBuilder.java:186)
at
org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:227)
at
org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:87)
at
org.eclipse.birt.report.service.ReportEngineService.runRepor t(Unknown
Source)
at
org.eclipse.birt.report.service.BirtViewerReportService.runR eport(Unknown
Source)
at
org.eclipse.birt.report.service.actionhandler.BirtRunReportA ctionHandler.__execute(Unknown
Source)
at
org.eclipse.birt.report.service.actionhandler.BirtChangePara meterActionHandler.runReport(Unknown
Source)
at
org.eclipse.birt.report.service.actionhandler.AbstractChange ParameterActionHandler.__execute(Unknown
Source)
at
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
Source)
at
org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(Unknown
Source)
at
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(Unknown
Source)
at
org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleChangeParameter(Unknown
Source)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(Unknown
Source)
at
org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(Unknown
Source)
at
at
at
org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
at
org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
at
org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
at
org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at
org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:453)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
at
org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
at
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
at sun.reflect.GeneratedMethodAccessor208.invoke(Unknown Source)
at
at
org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil .java:243)
at javax.security.auth.Subject.doAsPrivileged(Subject.java:517)
at
org.apache.catalina.security.SecurityUtil.execute(SecurityUt il.java:275)
at
org.apache.catalina.security.SecurityUtil.doAsPrivilege(Secu rityUtil.java:161)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:245)
at
org.apache.catalina.core.ApplicationFilterChain.access$000(A pplicationFilterChain.java:50)
at
org.apache.catalina.core.ApplicationFilterChain$1.run(Applic ationFilterChain.java:156)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:152)
at
blackboard.platform.servlet.ContentTypeFilter.doFilter(Conte ntTypeFilter.java:56)
at sun.reflect.GeneratedMethodAccessor211.invoke(Unknown Source)
at
at
at
at
org.apache.catalina.security.SecurityUtil.doAsPrivilege(Secu rityUtil.java:217)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:197)
at
at
at
at
blackboard.platform.servlet.RequestSessionFilter.handleReque st(RequestSessionFilter.java:314)
at
blackboard.platform.servlet.RequestSessionFilter.doFilter(Re questSessionFilter.java:152)
at sun.reflect.GeneratedMethodAccessor210.invoke(Unknown Source)
at
at
at
at
at
at
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
at
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:178)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:126)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:105)
at
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:107)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:148)
at
org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler. java:199)
at
org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.ja va:282)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java :754)
at
org.apache.jk.common.ChannelSocket.processConnection(Channel Socket.java:684)
at
org.apache.jk.common.ChannelSocket$SocketConnection.runIt(Ch annelSocket.java:876)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:595)
Caused by: com.inet.tds.l: java.security.AccessControlExceptionaccess
denied (java.net.SocketPermission 127.0.0.1:1433 connect,resolve)
at com.inet.tds.w.createSQLException(Unknown Source)
at com.inet.tds.TdsDriver.a(Unknown Source)
at com.inet.tds.TdsDriver.connect(Unknown Source)
at
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager$Wrap pedDriver.connect(JDBCDriverManager.java:787)
at java.sql.DriverManager.getConnection(DriverManager.java:525)
at java.sql.DriverManager.getConnection(DriverManager.java:140)
at
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doCo nnect(JDBCDriverManager.java:185)
at
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getC onnection(JDBCDriverManager.java:146)
at
org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUr l(Connection.java:150)
... 125 more
Re: Problem on BIRT viewer on Tomcat [message #249369 is a reply to message #249257] |
Mon, 23 July 2007 11:10   |
Originally posted by: jasonweathersby.alltel.net
Ethan,
This obviously looks like a permission problem.
What did you modify in the catalina.policy?
Jason
Ethan T wrote:
> Hi all,
> viewer. But I'm running into problems, Tomcat doesn't seem to allow the
> viewer to connect to the database. Could anyone shed some lights?
> (not directly under Tomcat though, I modified the server.xml (within
> Tomcat) to point to the viewer (WebViewerExample).
> couldn't figure out how I can modify the classpath to include the jdbc
> drivers. Instead, I followed the instruction, and copied the jdbc
> drivers into
> folder.
> jdbc drivers.
> properly.
> openConnection
> connection.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 125 more
Re: Problem on BIRT viewer on Tomcat [message #249451 is a reply to message #249383] |
Mon, 23 July 2007 19:45  |
Ethan,
Have you tried using localhost or the machinename instead of the ip address?
Jason
Ethan T wrote:
> Could you spot anything bad? Thanks!
> grant codeBase "file:${app.home}/webapps/-" {
> permission java.security.AllPermission;
> grant codeBase
> " file:${app.home}/webapps/viewerEngine/WEB-INF/platform/plugi ns/org.eclipse.birt.report.data.oda.jdbc_2.2.0.v20070615/oda -jdbc.jar!/- "
> permission java.net.SocketPermission "xxx.0.0.1:1433", "connect,resolve";
> grant codeBase
> " file:${app.home}/webapps/viewerEngine/WEB-INF/platform/plugi ns/org.eclipse.birt.report.data.oda.jdbc_2.2.0.v20070615/dri vers/Merlia.jar!/- "
> grant codeBase
> " file:${app.home}/webapps/viewerEngine/WEB-INF/platform/plugi ns/org.eclipse.birt.report.data.oda.jdbc_2.2.0.v20070615/dri vers/ojdbc14.jar!/- "
FUDForum. Page generated in 0.04165 seconds
