Home » Archived » BIRT » Integration in JBoss app possible?
Integration in JBoss app possible? [message #249077] Fri, 20 July 2007 00:21 Go to next message
Is it possible to integrate the BIRT Engine API into an application
deployed on JBoss?
I have installed the BIRT 2.2.0 "platform" files (copied from the BIRT
Viewer) in a directory outside of a JBoss controlled directory. I
configured IRT following:
http://www.eclipse.org/birt/phoenix/deploy/reportEngineAPI.p hp
My code:
private static EngineConfig config = null;
public void create(String filepath, OutputStream outputStream, String
format, Map<String, String> params){
try{
if(config == null) {
config = new EngineConfig();
config.setEngineHome("C:\\var\\itsolut\\birt\\platform");
// config.setEngineHome("/var/itsolut/birt/platform");
config.setLogConfig(".", Level.FINEST);
IPlatformContext context = new PlatformFileContext(config);
config.setPlatformContext(context);
try {
Platform.startup(config);
catch (BirtException e) {
throw new RuntimeException("Could not start the platform",
e);
IReportEngineFactory factory = (IReportEngineFactory)
Platform.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
IReportEngine engine = factory.createReportEngine( config );
engine.changeLogLevel( Level.WARNING );
InputStream stream = new FileInputStream(filepath);
IReportRunnable design = engine.openReportDesign(stream);
// here is where the exception (below) is thrown
</snip>
I am getting the following exception:
Caused by: java.lang.NoClassDefFoundError:
com/ibm/icu/text/SimpleDateFormat
at
org.eclipse.birt.report.model.metadata.DateTimePropertyType. <clinit>(DateTimePropertyType.java:61)
at
org.eclipse.birt.report.model.metadata.MetaDataDictionary.<init >(MetaDataDictionary.java:257)
at
org.eclipse.birt.report.model.metadata.MetaDataDictionary.<clinit >(MetaDataDictionary.java:112)
at
org.eclipse.birt.report.model.api.impl.DesignEngineImpl.newS essionHandle(DesignEngineImpl.java:127)
at
org.eclipse.birt.report.model.api.DesignEngine.newSessionHan dle(DesignEngine.java:108)
at
org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:142)
at
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:243)
at
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:179)
at
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:156)
at
org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDesign(ReportEngine.java:278)
at
com.itsolut.core.component.BIRTManager.create(BIRTManager.ja va:69)
at
com.itsolut.core.action.common.BirtReportGenerator.generate( BirtReportGenerator.java:93)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at
org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodIn vocation.java:112)
at
org.jboss.ejb3.interceptor.InvocationContextImpl.proceed(Inv ocationContextImpl.java:166)
... 111 more
Thoughts?
Thanks in advance,
Chris....
Re: Integration in JBoss app possible? [message #249180 is a reply to message #249077] Fri, 20 July 2007 10:57 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Chris,
Can you try to deploy the viewer as a test?
Take a look at the JBoss notes here
http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php
Jason
> deployed on JBoss?
> My code:
> try{
> try {
> e);
> } IReportEngineFactory factory =
> (IReportEngineFactory) Platform.createFactoryObject(
> </snip> I am getting the following exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 111 more
> Thoughts?
> Thanks in advance,
> Chris....
Re: Integration in JBoss app possible? [message #249201 is a reply to message #249180] Fri, 20 July 2007 13:01 Go to previous messageGo to next message
Jason,
Thanks for the reply.
I didn't try to deploy the viewer; but I did get the BIRT Engine to run in
my application so I can generate reports (only tried the PDF version for
now).
When I deployed just on Tomcat, I had to include 3 jars in my app:
coreapi.jar
engineapi.jar
modelapi.jar
In addition to these three, JBOSS ear files need two more files:
com.ibm.icu.jar
js.jar
Once I included these in the ear (not the war contained in the ear)
proper, everything now works.
Altough, I'm not sure why I need these two additional jars? I would have
thought the classes that need these jars would be in the platform only and
accessed via the OSGI mechanism used to deploy BIRT.
Chris....
Re: Integration in JBoss app possible? [message #249367 is a reply to message #249201] Mon, 23 July 2007 09:32 Go to previous messageGo to next message
BIRT makes use of all the jars in the ReportEngine/lib directory.
For example js.jar is used for scripting in BIRT.
Jason
Chris Hane wrote:
> Jason,
> in my application so I can generate reports (only tried the PDF version
> for now).
> coreapi.jar
> engineapi.jar
> modelapi.jar
> com.ibm.icu.jar
> js.jar
> have thought the classes that need these jars would be in the platform
> only and accessed via the OSGI mechanism used to deploy BIRT.
> Chris....
Re: Integration in JBoss app possible? [message #249375 is a reply to message #249367] Mon, 23 July 2007 11:50 Go to previous message
ok - that makes sense. I was hoping that the number of libraries that I
had to include directly in my application would be smaller. Right now it
looks like it is going to come out to 9MB.
I was hoping more of those would have been included in the "platform"
directory which is a 1 time upload and configuration per JBoss instance
whereas the other libraries must be included in every application.
Thanks for the info.
Chris....
Previous Topic:Traditional Chinese missing in runtime lang pack for viewer
Next Topic:BIRT 2.2, hidden columns, and Excel emitter
Current Time: Thu Sep 18 17:05:25 EDT 2025
Powered by FUDForum. Page generated in 0.05076 seconds
