Home » Eclipse Projects » GEF » Make Figure resizable but not repositionable
Make Figure resizable but not repositionable [message #249027] Wed, 20 May 2009 13:36 Go to next message
I'm quite new to gef and draw2d.
I'm implementing a simple Form editor.
The figures use a XYLayout and the corresponding EditPolicy inherits from
XYLayoutEditPolicy.
All figures can be resized and their position can be changed. Works just
fine.
For some figures I would like to turn off the possibility to change the
position.
Is their a simple way to do this?
What I tried:
I can prevent changes to the x and y coordinates in the model, but the
figures can still be dragged around. After you release the mouse button
they flip back to their original position. Not an elegant solution :(
TIA,
Thomas
Re: Make Figure resizable but not repositionable [message #249032 is a reply to message #249027] Wed, 20 May 2009 16:04 Go to previous messageGo to next message
One way to do it would be to override createChildEditPolicy(EditPart) in
your XYLayoutEditPolicy.
For the appropriate parts, return a subclass of ResizableEditPolicy
that overrides getMoveCommand(ChangeBoundsRequest) and returns
UnexecutableCommand.INSTANCE.
I haven't tried it but hope that helps.
Ben
Thomas Porcham wrote:
> Hello,
> from XYLayoutEditPolicy.
> fine.
> position.
> What I tried:
> TIA,
> Thomas
Re: Make Figure resizable but not repositionable [message #249034 is a reply to message #249032] Thu, 21 May 2009 13:37 Go to previous message
Ben, thanks for your quick reply!
I tried your approach and it works. However, it still shows the "move and
flip back" behavior.
There is a method setDragAllowed(boolean draggable) in ResizableEditPolicy.
I used this method to turn dragging off.
public class SizeEditPolicy extends XYLayoutEditPolicy {
protected Command createChangeConstraintCommand(EditPart child,
Object constraint) {
ChangeSizePositionCommand command = new ChangeSizePositionCommand();
command.setModel(child.getModel());
command.setConstraint((Rectangle) constraint);
return command;
protected Command getCreateCommand(CreateRequest request) {
// TODO Auto-generated method stub
return null;
protected EditPolicy createChildEditPolicy(EditPart child) {
ResizableEditPolicy resizablePol = new ResizableEditPolicy();
resizablePol.setDragAllowed(false); //disable position changes
return resizablePol;
Thomas
Previous Topic:[Announce] GEF 3.5.0 I200905121850 is available
Next Topic:Display editparts on a ScrollingGraphicalViewer
Current Time: Tue Nov 04 02:39:42 EST 2025
Powered by FUDForum. Page generated in 0.04833 seconds
