the right way to deal with requests [message #248822] |
Wed, 06 May 2009 12:21  |
hi folks,
i want to create components in my diagram via the context menu of my
editor. therefore i added a action that create a CreateRequest and a
CreationFactory. The next step was that i called the
performRequest-method of my responsible editpart. but the default
implementation of this method is empty and i have to implement the
method myself. but i m in doubt how i do this. can you please give me
some hints what are the next steps? is it possible to determine the
position where the context menu was opened?
Re: the right way to deal with requests [message #248988 is a reply to message #248857] |
Fri, 15 May 2009 06:03   |
hey folks,
thanks for your many many replies. unfortunately i was very busy the
last 2 weeks, so that i have today the first chance to look at your posts.
you have post a lot to determine the location where the actions is
performed. thanks for that. maybe you can give me a short overview how
to deal with request? that would very useful.
thanks again and regards,
rené
Nikola Mihajlovic wrote:
> AbstractTool tool = (AbstractTool) editDomain.getActiveTool();
> Method m = AbstractTool.class.getDeclaredMethod("getLocation");
> m.setAccessible(true);
> location = (Point) m.invoke(tool);
> You also need to traslate the point, take a look at
> org.eclipse.gef.editpolicies.ConstrainedLayoutEditPolicy on how to do this
> Ben Vitale wrote:
>> The entry is not suggesting that you can't create new parts using the
>> context menu.
>> It seems like good advice to me that you shouldn't rely on a location
>> that may not work in all scenarios.
>> If you have a snippet to get the context menu location, please post
>> it.
>> Thanks
>> Ben
>>> That doesn't help at all, the author of the FAQ was just being a
>>> smartass. They should have explained how to find the location of the
>>> context menu if it was brought via mouse. I'm sure that GMF creates
>>> parts via the context menu, so what is the problem?
>>> Ben Vitale wrote:
>>>> Regarding the location of the context menu,
>>>> http://wiki.eclipse.org/index.php/GEF_Developer_FAQ#How_do_I _find_the_location_of_the_context_menu.3F
>>>> -Ben
>>>> René wrote:
>>>>> hi folks,
>>>>> my editor. therefore i added a action that create a CreateRequest
>>>>> and a CreationFactory. The next step was that i called the
>>>>> me some hints what are the next steps? is it possible to determine
>>>>> the position where the context menu was opened?
Re: the right way to deal with requests [message #248993 is a reply to message #248988] |
Fri, 15 May 2009 11:49  |
hey,
its me again. i solved the problem with the request. it was much easier
than i thought. you have to call just getCommand(Request) of the
responsible edit part. this uses the registered edit policies to create
and return the correct command...
i just want to thank you again. specially nikolas post was very helpful
and works immediately. the use of reflection to get the drop location is
a nice hack and i properly have to pondering for years to come to this
idea. btw: i didn't have to translate the location. it was out of the
box relative to my diagram domain.
best regards,
rené
René wrote:
> hey folks,
> rené
>> this
>>> context menu.
>>> it.
>>> Thanks
>>> Ben
>>>>> -Ben
>>>>> René wrote:
>>>>>> hi folks,
FUDForum. Page generated in 0.09497 seconds
