Home » Archived » BIRT » Report parameters problem....
Report parameters problem.... [message #248818] Thu, 19 July 2007 06:55 Go to next message
Originally posted by: wkrugiolka.poczta.onet.pl
Hi!!
My problem is that i want to set some parameters before render task - not
befor run task.
When i set some parameters before run
task.setParameterValue("dummy", "dupa");
it works fine.
But is it possible to set parameters after run and before render ?
I'd like to run report just once and render it a lot of time......
My piece of code:
IReportRunnable design = null;
design = this.reportEngine.openReportDesign(this.reportEngineHome +
"Reports/" + pReportName + ".rptdesign");
IRunTask task = this.reportEngine.createRunTask(design);
String reportDocName = this.reportEngineHome + "Reports/" + pReportName +
".rptdocument";
task.setParameterValue("dummy", "dupa"); // IT WORSK FINE
task.run(reportDocName);
IReportDocument reportDocument =
this.reportEngine.openReportDocument(reportDocName);
IRenderOption options = new RenderOption();
options.setOutputFormat(IRenderOption.OUTPUT_FORMAT_PDF);
options.setOutputStream(pOutputStream);
IRenderTask renderTask =
this.reportEngine.createRenderTask(reportDocument);
renderTask.setRenderOption(options);
renderTask.setParameterValue("dummy", "dupa"); // IT DOESNT WORK :-(
renderTask.setAppContext(params);
renderTask.render();
renderTask.close();
Pozdro, Wojtas
http://www.e-krug.com/
Re: Report parameters problem.... [message #248933 is a reply to message #248818] Thu, 19 July 2007 12:18 Go to previous message
news.onet.pl,
I think the best bet would be to save the parameter values off as global
values. The following code should save the value of a parameter named aParam
to a global variable named gParam. The second line of code retrieves the
gParam value for use later in the report.
Why am I using the .value you might ask? Parameters are accessed as scriptable
objects. Since I assume you want to work with the value of the parameter
and not the parameter object, I just save off the value.
reportContext.setPersistentGlobalVariable("gParam", params["aParam"].value)
reportContext.getGlobalVariable("gParam")
Hope this helps,
Scott Rosenbaum
> Hi!!
> not
> befor run task.
> it works fine.
> But is it possible to set parameters after run and before render ? I'd
> My piece of code:
> pReportName +
> ".rptdocument";
> renderTask.close();
Previous Topic:Problem with the ppt emitter - with sample report
Next Topic:Custom ODA data source, want different behavior during preview vs. actual usage?
Current Time: Fri Jul 25 21:44:25 EDT 2025
Powered by FUDForum. Page generated in 0.04662 seconds
