Home » Language IDEs » Java Development Tools (JDT) » Filter resources from being refreshed or managed by eclipse?
Filter resources from being refreshed or managed by eclipse? [message #248388] Thu, 04 October 2007 14:29 Go to next message
Originally posted by: mikesnare.gmail.com
Is it possible to tell eclipse to completely ignore all the content under
a particular tree underneath the project directory?
For legacy reasons, we have a lot of flotsam in our vob, and there are
several trees that, while necessary for a full packaged build, simply
increase the amount of time it takes eclipse to refresh.
I know it's possible to filter items from the view in the explorers, but
I'm more interested in preventing eclipse from seeing/using/managing them
at all.
-Mike
Re: Filter resources from being refreshed or managed by eclipse? [message #248392 is a reply to message #248388] Thu, 04 October 2007 14:31 Go to previous messageGo to next message
Mike,
As far as I know, this is not possible. It is possible to create a
project where all the folders under the project are links to somewhere
else in the file system, so maybe that approach will do the trick for you.
> under a particular tree underneath the project directory?
> but I'm more interested in preventing eclipse from
> seeing/using/managing them at all.
> -Mike
Re: Filter resources from being refreshed or managed by eclipse? [message #248396 is a reply to message #248392] Thu, 04 October 2007 14:49 Go to previous messageGo to next message
Not a bad idea, but not good for mass consumption here. (I may use it
myself...).
What about a resource change listener? If I could register against some
resource plugin early enough, could I not load some external file that
tells me which resources to ignore, and somehow prevent it?
-Mike
On Thu, 04 Oct 2007 14:31:22 -0400, Ed Merks <merks@ca.ibm.com> wrote:
> Mike,
> you.
>> Thanks,
>> -Mike
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Filter resources from being refreshed or managed by eclipse? [message #248411 is a reply to message #248396] Thu, 04 October 2007 19:52 Go to previous message
Mike,
No, I think Eclipse will want to create a full representation of the
entire hierarchy of contained resources.
> myself...).
> some resource plugin early enough, could I not load some external file
> that tells me which resources to ignore, and somehow prevent it?
> -Mike
>> Mike,
>> somewhere else in the file system, so maybe that approach will do the
>> trick for you.
>>> are several trees that, while necessary for a full packaged build,
>>> simply increase the amount of time it takes eclipse to refresh.
>>> Thanks,
>>> -Mike
Previous Topic:Re: Dynamic output path
Next Topic:Custom hyper link detectors for stack traces in consoles
Current Time: Tue Nov 04 07:46:10 EST 2025
Powered by FUDForum. Page generated in 0.07705 seconds
