Home » Eclipse Projects » Eclipse Platform » JBOSS ClassCastException when accessing remote home interface
JBOSS ClassCastException when accessing remote home interface [message #247896] Tue, 01 June 2004 09:29 Go to next message
Originally posted by: gerhard.kainz.knowing.at
I am writing a plugin for eclipse 3.0 (M8) , that needs access to JBOSS. I
have all the JBOSS jars as bootstrap entries and j2ee.jar in the runtime
classpath. A security manager is set to all permissions.
The problem is as follows:
Following code is called as part of a factory Class
public static OCSessionEJB getSessionBean() {
if (ocSession == null) {
try {
getInitialContext();
Object ref = context.lookup("OCSessionEJB");
Object object = PortableRemoteObject.narrow(ref,
OCSessionEJBHome.class);
OCSessionEJBHome home = (OCSessionEJBHome) object;
ocSession = home.create();
} catch (Exception e) {
System.err.println("MESSAGE:" + e.getMessage());
e.printStackTrace(System.err);}}
return ocSession;
private static void getInitialContext() throws NamingException {
if (context == null) {
if(System.getSecurityManager() == null) {System.setSecurityManager(new
RMISecurityManager());}
Hashtable connectionProperties = new Hashtable();
connectionProperties.put(Context.INITIAL_CONTEXT_FACTORY,
namingContextFactory);
connectionProperties.put(Context.PROVIDER_URL, providerURL);
context = new InitialContext(connectionProperties);}
I wrote a small application, that uses the plugin's viewer and fills it with
data from our jboss server. It works (including the above code). When I run
it as a plugin the initial context ist set (seems so), the context.lookup
works (ref != null) but PortableRemoteObject.narrow() throws a
ClassCastException.
Any ides are welcome
Gerhard a: Kainz
Re: JBOSS ClassCastException when accessing remote home interface [message #247940 is a reply to message #247896] Tue, 01 June 2004 10:46 Go to previous message
Thanks to J. O Connor I found the following and it works:
// set security manager
// if(System.getSecurityManager() == null) {
// System.setSecurityManager(new RMISecurityManager());
// Hashtable connectionProperties = new Hashtable();
// connectionProperties.put(Context.INITIAL_CONTEXT_FACTORY,
// namingContextFactory);
// connectionProperties.put(Context.PROVIDER_URL, providerURL);
// context = new InitialContext(connectionProperties);
Hashtable env = new Hashtable();
env.put("java.naming.factory.initial",
"org.jnp.interfaces.NamingContextFactory");
env.put("java.naming.factory.url.pkgs",
"org.jboss.naming:org.jnp.interfaces");
env.put("java.naming.provider.url", "jnp://localhost:1099");
env.put("java.naming.rmi.security.manager", "yes");
NamingContextFactory namingFactory = new
NamingContextFactory();
context = namingFactory.getInitialContext(env);
"gk" <gerhard.kainz@knowing.at> schrieb im Newsbeitrag
news:c9hvp5$k0c$1@eclipse.org...
> try {
> return ocSession;
with
run
> ClassCastException.
> Gerhard a: Kainz
Previous Topic:[RCP M8] NoClassDefFoundError org/eclipse/swt/widgets/Listener
Next Topic:Can't Install/Update New Features/Plugins
Current Time: Sat Aug 23 07:15:30 EDT 2025
Powered by FUDForum. Page generated in 0.03305 seconds
