Home » Language IDEs » Java Development Tools (JDT) » problems with searching for references
problems with searching for references [message #247701] Sat, 08 September 2007 19:43 Go to next message
Originally posted by: Rudolf.Ziegaus.gmx.de
I want to search for references for a class or a method. I do this via
getSearchEngine().search(pattern, getParticipants(), searchScope,
searchRequestor, monitor);
where the pattern has been created with
pattern = SearchPattern.createPattern(element,
JavaSearchConstants.REFERENCES);
and the searchScope has been created with
searchScope = SearchEngine.createJavaSearchScope(javaProjects);
javaProjects is a array of IJavaProject, that the user selects.
Now when I use this approach on classes I will find all references in java
source code, but I miss references in plugin.xml.
Eclipse itself however also finds the reference to plugin.xml when I search
the same projects via "references".
I thought that maybe the way I create my searchscope might be wrong, so I
tried SearchEngine.createWorkspaceScope(), but to no avail. I also tried
variations of the createPattern method, but again I had no success.
Can anybody give me a hint which approach I need to take in order to also
find references to a class in plugin.xml?
TIA,
Rudi
Re: problems with searching for references [message #247781 is a reply to message #247701] Tue, 18 September 2007 11:31 Go to previous messageGo to next message
You correctly use Search Engine, but it just cannot find references in
non-Java files...
When you said that Eclipse finds references in plugin.xml, I guess you
mean that using the 'File Search' of Eclipse, then you found matches...
But this kind of search is a text search inside file contents (like
Windows search in fact) which is different from Java Search...
Rudolf Ziegaus wrote:
> Hello,
> TIA,
> Rudi
Re: problems with searching for references [message #247814 is a reply to message #247781] Tue, 18 September 2007 19:19 Go to previous messageGo to next message
Am Tue, 18 Sep 2007 17:31:42 +0200 schrieb Frederic Fusier:
> non-Java files...
Hello Frederic,
thanks for your reply. No, I did not mean the "File Search" in Eclipse. I
was talking about using "References" from the context menu. When I choose
the same working set as I do for my own search, I do get a match for a
class in "plugin.xml" that I don't get when I use my own search method.
Maybe Eclipse is doing additionally a search in all found "plugin.xml"
files?
Rudi
Re: problems with searching for references [message #247855 is a reply to message #247814] Wed, 19 September 2007 06:36 Go to previous messageGo to next message
> Hello Frederic,
> files?
> Rudi
You're right, I never noticed that... and it seems to exist since 3.2!
Thanks for the tip :-)
However, this match is not reported by Search Engine, but by the "PDE Java
Search Participant" which extends the org.eclipse.jdt.ui.queryParticipants
extension point in MANIFEST.MF of org.eclipse.pde.ui plugin.
Re: problems with searching for references [message #247959 is a reply to message #247855] Thu, 20 September 2007 17:57 Go to previous messageGo to next message
Am Wed, 19 Sep 2007 12:36:35 +0200 schrieb Frederic Fusier:
> > Hello Frederic,
>> files?
>> Rudi
You're welcome;-)
I found the necessary classes. However I have a further question. I'd like
to implement this very functionality in my plugin. What's the best way to
do it? When I copy the class's source code I have to import many internal
packages and I get a "restricted access" message. Is there a better way to
implement this functionality? Or can I suppress the warnings? What does
this message mean btw?
Rudi
Re: problems with searching for references [message #247974 is a reply to message #247959] Fri, 21 September 2007 04:57 Go to previous messageGo to next message
>> > Hello Frederic,
>>>files?
>>>Rudi
>You're welcome;-)
It means you are using internal code which can change anytime.
Dani
>Rudi
Re: problems with searching for references [message #247993 is a reply to message #247974] Sat, 22 September 2007 17:03 Go to previous message
Am Fri, 21 Sep 2007 10:57:35 +0200 schrieb Daniel Megert:
>>> > Hello Frederic,
>>>>files?
>>>>Rudi
>>You're welcome;-)
> Dani
>>Rudi
Yep, that what I thought. So, it's no good idea to use that code.
What alternatives do I have?
Since I have run into this problem with plugin.xml (that's where an
extension point is referenced) I thought I might as well parse the
plugin.xml for any mention of the class I am looking for.
Is there an "official way" to get the plugin.xml of a project? Of course I
could also look the members of the project and load the plugin.xml from
there. However, if there is an preferred way I would try to stick to that.
Rudi
Previous Topic:Changing Java source in a builder; which mechanism?
Next Topic:"Run as/ Ant build..." customization question
Current Time: Wed Nov 05 23:30:06 EST 2025
Powered by FUDForum. Page generated in 1.25640 seconds
