Home » Language IDEs » Java Development Tools (JDT) » Export Java formatting profile XML
Export Java formatting profile XML [message #247772] Mon, 17 September 2007 15:14 Go to next message
You used to be able to export the Java formatting profile as an XML
document, but I don't see this option any longer (although you can still
import). I need to share my coding formatting profile with other
developers -- how do I do that now?
Thanks in advance for your suggestions.
--James
Re: Export Java formatting profile XML [message #247775 is a reply to message #247772] Mon, 17 September 2007 16:03 Go to previous messageGo to next message
James,
Use the New... button to give it a new name and then you'll be able to
export it from the wizard with all the tabs where you make all the
changes (using the Export... button).
> still import). I need to share my coding formatting profile with
> other developers -- how do I do that now?
> --James
Re: Export Java formatting profile XML [message #247879 is a reply to message #247775] Wed, 19 September 2007 12:49 Go to previous message
Thanks Ed, problem solved.
--James
Ed Merks wrote:
> James,
>> --James
Previous Topic:Content-assist: How does the JDT do that little yellow popup window for the parameters?
Next Topic:APT and jdt.compiler.tool plugins
Current Time: Wed Sep 03 01:05:08 EDT 2025
Powered by FUDForum. Page generated in 0.06952 seconds
