Home » Language IDEs » Java Development Tools (JDT) » def-use-chain
def-use-chain [message #247300] Tue, 04 September 2007 10:05 Go to next message
Originally posted by: svylbowe.hotmail.com
is there any support for uncovering def-use-chains in the
org.eclipse.jdt.core APIs? Specifically, I wish to find all uses of a
parameter within a method body. Any help is greatly appriciated!
-- AH
Re: def-use-chain [message #247354 is a reply to message #247300] Tue, 04 September 2007 18:22 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
Anders H wrote:
Toggle on the Highlight Occurrences feature for the editor, then put the
cursor on any part of the parameter name that you're interested in. It
also works for other elements of code like methods, fields, exceptions,
return values, classes, etc.
The Highlight Occurrences feature is available via a toggle button on
the toolbar above the Java editor - icon looks like a yellow highlighter
pen.
Hope this helps,
Eric
Re: def-use-chain [message #247366 is a reply to message #247354] Wed, 05 September 2007 02:55 Go to previous messageGo to next message
Thanks!
Do you also know where the relevant sources for this functionality is
located. I need it for a custom plugin.
-- Anders
"Eric Rizzo" <eclipse5@rizzoweb.com> wrote in message
news:fbklqa$qop$4@build.eclipse.org...
> Anders H wrote:
>> Hi,
> The Highlight Occurrences feature is available via a toggle button on the
> toolbar above the Java editor - icon looks like a yellow highlighter pen.
> Hope this helps,
> Eric
Re: def-use-chain [message #247493 is a reply to message #247366] Wed, 05 September 2007 17:11 Go to previous messageGo to next message
Originally posted by: jacek.pospychala.pl.ibm.com
Anders,
Maybe this dirty little secrets tutorial will put more light on topic
you are looking for:
www.cs.purdue.edu/homes/baker29/pldi05-tutorials/Static%20An alysis%20for%20*Java*%20in%20*Eclipse*.pdf
Anders H wrote:
> Thanks!
> -- Anders
>> Anders H wrote:
>>> Hi,
>> Hope this helps,
>> Eric
Re: def-use-chain [message #247511 is a reply to message #247366] Thu, 06 September 2007 04:13 Go to previous messageGo to next message
Anders H wrote:
>Thanks!
It's in the org.eclipse.jdt.ui plug-in. Take a look at OccurrencesFinder.
HTH
Dani
>-- Anders
>>Anders H wrote:
>>>Hi,
>>Hope this helps,
>>Eric
Re: def-use-chain [message #247521 is a reply to message #247493] Thu, 06 September 2007 08:20 Go to previous messageGo to next message
Thanks!
Is the source code for this tutorial available anywhere?
-- Anders
"Jacek Pospychala" <jacek.pospychala@pl.ibm.com> wrote in message
news:fbn64n$umo$1@build.eclipse.org...
> Anders,
> Maybe this dirty little secrets tutorial will put more light on topic you
> are looking for:
> Anders H wrote:
>> Thanks!
>> -- Anders
>>> Anders H wrote:
>>>> Hi,
>>> pen.
>>> Hope this helps,
>>> Eric
Re: def-use-chain [message #247526 is a reply to message #247511] Thu, 06 September 2007 08:20 Go to previous message
Great, thanks!
-- Anders
"Daniel Megert" <daniel_megert@ch.ibm.com> wrote in message
news:fbocsi$a01$1@build.eclipse.org...
> Anders H wrote:
>>Thanks!
> HTH
> Dani
>>-- Anders
>>>Anders H wrote:
>>>>Hi,
>>>Hope this helps,
>>>Eric
Previous Topic:Organize Imports in Eclipse 3.3
Next Topic:What preference controls compile warning about @Override
Current Time: Sat Nov 08 01:54:14 EST 2025
Powered by FUDForum. Page generated in 0.04058 seconds
