Home » Eclipse Projects » Babel » Import/contribute existing properties files
Import/contribute existing properties files [message #24488] Wed, 14 January 2009 04:43 Go to next message
Originally posted by: mickael.istria.openwide.fr
The Java Workflow Tooling already contained French and German
translations as properties files before we added the project to Babel.
However, we would now like to contribute those properties files directly
into Babel.
I've seen that some scripts already exist on the Bugzilla to import that
files, but I understood that they are currently not intended to be used
"as it" by contributors.
Thus I wondered how could I contribute those files? Should I open a bug
with the translation files so that Antoine would spend time running his
script against them ;) ?
Thanks in advance for your help
Mickael
Re: Import/contribute existing properties files [message #24529 is a reply to message #24488] Wed, 14 January 2009 04:59 Go to previous messageGo to next message
Hello Mickael,
Thanks a lot for pointing that out.
The Babel Committers have gathered a couple of ideas, especially for tools
like the Message Editor (for Properties files) which are part of Babel.
So either a direct import on the server side, or something to allow a
MessageEditor to communicate with the TranslationServer seems helpful here.
Could you please tell me, where those files are at the moment (repository
path, etc.) ?
As I would be happy to take a look at the German ones at least from the
Native Speaker and Language Champion perspective.
Werner
Re: Import/contribute existing properties files [message #24569 is a reply to message #24529] Wed, 14 January 2009 05:06 Go to previous messageGo to next message
Hello Werner,
Thanks a lot for your quick response!
You can find the JWT Workflow Editor translation files on CVS:
* repo: dev.eclipse.org:/cvsroot/technology
* files: org.eclipse.jwt/we/jwt-we/plugin_[fr/de].properties
Mickael
Werner Keil a écrit :
> Hello Mickael,
> tools like the Message Editor (for Properties files) which are part of
> Babel.
> (repository path, etc.) ?
> Regards,
> Werner
Re: Import/contribute existing properties files [message #24647 is a reply to message #24569] Wed, 14 January 2009 14:12 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
Please open a bug against Babel and attach the files.
Also consider making translations in the Web UI. Importing stuff is
tiresome on my end.
If you'd like to help on creating an API for the client to directly
communicate with the server, there is a bug opened for that.
Antoine
Mickael Istria wrote:
> Hello Werner,
> Regards,
> Mickael
>> Hello Mickael,
>> Babel.
>> here.
>> the Native Speaker and Language Champion perspective.
>> Regards,
>> Werner
Re: Import/contribute existing properties files [message #24687 is a reply to message #24647] Thu, 15 January 2009 03:41 Go to previous messageGo to next message
Hi Antoine,
I opened bug 261156
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=261156) with attached
properties files.
Don't worry, now that JWT is integrated into Babel, we only use the
WebUI for translations, so that we won't bother with import you any more ;)
Mickael
> tiresome on my end.
> Cheers,
> Antoine
>> Hello Werner,
>> Regards,
>> Mickael
>>> Hello Mickael,
>>> Babel.
>>> here.
>>> Regards,
>>> Werner
Re: Import/contribute existing properties files [message #24727 is a reply to message #24647] Thu, 15 January 2009 05:00 Go to previous messageGo to next message
"Antoine Toulme" <atoulme@intalio.com> schrieb im Newsbeitrag
news:gkldfk$e0j$1@build.eclipse.org...
> tiresome on my end.
That sounds like it is so far still manually done ?;-/
Re: Import/contribute existing properties files [message #24765 is a reply to message #24727] Thu, 15 January 2009 09:09 Go to previous messageGo to next message
>> tiresome on my end.
Of course, Werner, there is a lot of stuff to take care of. I'm not sure
we will ever escape having to deal with the file encoding and looking at
the translation quality.
Those two steps take a lot of energy. After that, it's a piece of cake.
Antoine
Re: Import/contribute existing properties files [message #24801 is a reply to message #24687] Thu, 15 January 2009 09:10 Go to previous message
> Hi Antoine,
> I opened bug 261156
> properties files.
OK thanks.
Thank you!
> Mickael
>> tiresome on my end.
>> Cheers,
>> Antoine
>>> Hello Werner,
>>> Regards,
>>> Mickael
>>>> Hello Mickael,
>>>> Babel.
>>>> here.
>>>> Regards,
>>>> Werner
Re: Import/contribute existing properties files [message #576643 is a reply to message #24488] Wed, 14 January 2009 04:59 Go to previous message
Hello Mickael,
path, etc.) ?
Werner
Re: Import/contribute existing properties files [message #576690 is a reply to message #24529] Wed, 14 January 2009 05:06 Go to previous message
Hello Werner,
Mickael
> Hello Mickael,
> Babel.
> Regards,
> Werner
Re: Import/contribute existing properties files [message #576758 is a reply to message #24569] Wed, 14 January 2009 14:12 Go to previous message
tiresome on my end.
Antoine
> Hello Werner,
> Regards,
> Mickael
>> Hello Mickael,
>> Babel.
>> here.
>> Regards,
>> Werner
Re: Import/contribute existing properties files [message #576796 is a reply to message #24647] Thu, 15 January 2009 03:41 Go to previous message
Hi Antoine,
I opened bug 261156
properties files.
Mickael
> tiresome on my end.
> Cheers,
> Antoine
>> Hello Werner,
>> Regards,
>> Mickael
>>> Hello Mickael,
>>> Babel.
>>> here.
>>> Regards,
>>> Werner
Re: Import/contribute existing properties files [message #576813 is a reply to message #24647] Thu, 15 January 2009 05:00 Go to previous message
> tiresome on my end.
Re: Import/contribute existing properties files [message #576856 is a reply to message #24727] Thu, 15 January 2009 09:09 Go to previous message
>> tiresome on my end.
Antoine
Re: Import/contribute existing properties files [message #576894 is a reply to message #24687] Thu, 15 January 2009 09:10 Go to previous message
> Hi Antoine,
> I opened bug 261156
> properties files.
OK thanks.
Thank you!
> Mickael
>> tiresome on my end.
>> Cheers,
>> Antoine
>>> Hello Werner,
>>> Regards,
>>> Mickael
>>>> Hello Mickael,
>>>> Babel.
>>>> here.
>>>> Regards,
>>>> Werner
Previous Topic:Platform independent?
Next Topic:Editor usage
Current Time: Thu Nov 06 02:40:52 EST 2025
Powered by FUDForum. Page generated in 0.05892 seconds
