Home » Language IDEs » Java Development Tools (JDT) » Organize Imports in Eclipse 3.3
| Organize Imports in Eclipse 3.3 [message #247212] |
Mon, 03 September 2007 06:00  |
Hi all,
I have been using Eclipse for developing J2EE (WTP) projects since
Eclipse 3.2.
When Eclipse 3.3 came out, I download and unzip and start using it on
Windows XP platform.
JDK 1.5 b9
The file obtained is in
http://www.eclipse.org/downloads/download.php?file=/eclipse/ downloads/drops/R-3.3-200706251500/eclipse-SDK-3.3-win32.zip &r=1&protocol=http
I use the function "Organize Imports" all the time to remove unused
imports.
On Eclipse 3.2
From the "Package Explorer", I right click the "source package" node and
Source | Organize Imports
The imports will be modified for all the files within the source package.
However when I use Eclipse 3.3, for the same process, the imports are
not changed.
A dialog box still pop up with progress bar running. But after it
finished, the imports of the source file are not changed. However on
single (one) file, the organized import works.
If I set the focus on the text editor and run "Ctrl+Shirt+O", the
imports will change.
Is it because when iterating the files, it somehow ignore the "organize
imports" operation?
I even remove the whole Eclipse installation folder, unzip a clean copy
from the zip file downloaded above. Import the project. Then right
click, run organize imports. Still no luck.
I do the same on Eclipse 3.2, it works.
konkeong
| Re: Organize Imports in Eclipse 3.3 [message #247224 is a reply to message #247212] |
Mon, 03 September 2007 08:47   |
Lee,
I just tried this with a regular Java project without WTP installed.
I.e., I right clicked on the src folder and invoked Source->Organize
Imports. It correctly handled all the files. If you can create a
simple reproducible test case for your problem, then you should open a
bugzilla for it.
Lee Kon Keong wrote:
> Hi all,
> Eclipse 3.2.
> JDK 1.5 b9
> imports.
> On Eclipse 3.2
> not changed.
> "organize imports" operation?
> copy from the zip file downloaded above. Import the project. Then
> right click, run organize imports. Still no luck.
> Thanks
> konkeong
| Re: Organize Imports in Eclipse 3.3 [message #247228 is a reply to message #247212] |
Mon, 03 September 2007 09:47   |
> Hi all,
> Eclipse 3.2.
> JDK 1.5 b9
> imports.
> On Eclipse 3.2
Are you sure you're in the Package Explorer and not the Project Explorer?
Dani
> not changed.
> Thanks
> konkeong
| Re: Organize Imports in Eclipse 3.3 [message #247261 is a reply to message #247228] |
Mon, 03 September 2007 21:36   |
Dear Daniel,
You are correct.
The default layout for the Eclipse "Java Perspective" is to show the
"Package Explorer" and "Hierarchy" on the left side.
I even reset the "Java Perspective".
So I definitely run "Organize Imports" on this "Package Explorer"
window/pane.
Furthermore, I do "Window | Show Views | General | Project Explorer"
When I right click on the "node" in the "Project Explorer" to do
"organize imports", the dialog box still pops up, with progress bar
running. Once done, the imports are not changed.
konkeong
>> Hi all,
>> Eclipse 3.2.
>> JDK 1.5 b9
>> imports.
>> On Eclipse 3.2
> Dani
>> not changed.
>> Thanks
>> konkeong
| Re: Organize Imports in Eclipse 3.3 [message #247272 is a reply to message #247224] |
Tue, 04 September 2007 01:56   |
Dear Ed Merks,
I have tried with a new "Java Project", with one java source file.
The organize imports works.
I copy all the java files over into this new blank project, the
organized import doesn't work.
Now I am recreating the project, by slowly coping the files (2271 java
files) over and test repeatably, why and when and where the organize
imports stop working.
konkeong
Ed Merks wrote:
> Lee,
> bugzilla for it.
>> Hi all,
>> Eclipse 3.2.
>> JDK 1.5 b9
>> imports.
>> On Eclipse 3.2
>> not changed.
>> Thanks
>> konkeong
| Re: Organize Imports in Eclipse 3.3 [message #247278 is a reply to message #247272] |
Tue, 04 September 2007 02:40   |
--------------010102070300070803080102
I have tried with this.
With single source file "DateUtil.java".
In "Package Explorer", (the default Java Perspective settings).
I do a right click on the node "com.konkeong.common".
Organize imports work.
When I add one more source file "DateUtil2.java".
Right click the node "com.konkeong.common".
Organize imports doesn't work.
When I right click on the file "DateUtil.java".
Organize imports works.
I revert the imports changes (from above).
Delete the file "DateUtil2.java".
Right click on the node "com.konkeong.common".
Seems like on single file, it works. On multiple files, it doesn't work.
I also do the same for "Project Explorer", with same result.
> Dear Ed Merks,
> Thanks
> konkeong
> Ed Merks wrote:
>> Lee,
>> bugzilla for it.
>>> Hi all,
>>> Eclipse 3.2.
>>> JDK 1.5 b9
>>> imports.
>>> On Eclipse 3.2
>>> package.
>>> not changed.
>>> Thanks
>>> konkeong
Content-Type: application/x-zip-compressed;
name="junk1.zip"
Content-Disposition: inline;
filename="junk1.zip"
UEsDBAoAAAAAAPpzJDcAAAAAAAAAAAAAAAAGAAAAanVuazEvUEsDBBQAAAAI AAZ0JDf1M9tA
jwAAAOgAAAAQAAAAanVuazEvLmNsYXNzcGF0aLOxr8jNUShLLSrOzM+zVTLU M1BSSM1Lzk/J
zEu3VQoNcdO1ULK34+WySc5JLC4uSCzJAHI4EbzUvJKiSoXszLwUW6XiomQl BZAghKmPW2Vy
fh5MZX5Rul5qck5mQXGqXlZKiV5OYmlecgbQdj2vINd4Z3+/EEdPP9cgfKbl l5YUlJbADEzK
zAMrttFHdjIAUEsDBBQAAAAIALtMJDfVhcuVvAAAAH0BAAAOAAAAanVuazEv LnByb2plY3R1
UEsOwiAQXWviHRr2FrtzQetC4wXUAyCdNNQWyEAbjy9QalMTd/PezPsAO737 LhsBrdSqJEV+
IBkooWupmpI87tf9kZyq3ZYZ1C0IdwErUBrnrz27YYr3ULWDehWMxjmQQvc9 KFcxOk+BTQ42
ArpCz0F29c2ACCjBs5dyVUcm5WhschCdNBbytna50OgHPvIoAFwqeAXHZgjZ NmG6Jhj9TUnM
XMNHugEhXU/gf4NpHwrEu2i3GHyfu/6+D1BLAwQKAAAAAAAGdCQ3AAAAAAAA AAAAAAAACgAA
AGp1bmsxL2Jpbi9QSwMECgAAAAAABnQkNwAAAAAAAAAAAAAAAA4AAABqdW5r MS9iaW4vY29t
L1BLAwQKAAAAAAAGdCQ3AAAAAAAAAAAAAAAAFwAAAGp1bmsxL2Jpbi9jb20v a29ua2Vvbmcv
UEsDBAoAAAAAAAZ0JDcAAAAAAAAAAAAAAAAeAAAAanVuazEvYmluL2NvbS9r b25rZW9uZy9j
b21tb24vUEsDBBQAAAAIAAZ0JDf2UZuNTAsAAE4YAAAsAAAAanVuazEvYmlu L2NvbS9rb25r
ZW9uZy9jb21tb24vRGF0ZVV0aWwuY2xhc3O9WFl0E+cV/n4tlizJYAwyGAPG EIIsFmNCSGKy
AF4igQVJZdyQpgVhDVigxUhjA0mbtgkkzdYsLElDFidpmraHpKSLcUKb7k2b pvtzz2lP+5Cn
PvS0fezpd/8ZjSVbIQ89rc5h5p87/733u99d5jfv/fvtdwB04Q8+uBSWDBdy nUcK+SNGIX+o
kw+5Qr6zN2Uae8xM1gePQuPh1HiqM5vi690HDhvDpkJDf2JwX++2wb59g/FE n0LTwPSepFnM
5A9t4aaeQr5kpvLmUCo7ZvhRr7DwBH/rEol16fTyWKw7l+suldYnk0k6EYv9 ewYG9vXsTty2
rWfQj5DCPNmfSKTTsVguVyrpnXU3ZvIZ82YFd6RjSMHTU0gbAbgxL4QGzFGY O5DJG7vGcgeM
4mDqQNYQdIXhVHYoVczIsy30mCOZksKygSvFzygWHjLMwUI6dUJk8fxgJmcw qNyoQnOkwwq7
dDTb6ci3BNCCVh8W069+O0Y7nT2prJFPp4ohLMFShSCNxjU5w0aFoaqt2lBb CMvRzlhLBmn3
RuLxjiEfVpZtV3mW/atCuBqrSYKg5ot4PpHJZiVQsrUjgBXoEJqijD+yQ+hz kxmFBbX8K8yn
lZ6xYtHImxVeOtHlw4aqukieKJlGLoSN4nve8LRK2XswTfZEsKtwjOCrAhZi t/iwWWFOtTCA
a9FBacks9laqLyirV9abDwS8WItN47jZmczkRrOG6PUXirmUGUA3bpLYWTnh yGz9jqEAFLaG
cA02BbAdvT70lGPUBi0zIfShn0V4UD8pXF1pymqPLTXQkeiDOdNplAqDfBWs CFBhc2QmNzXA
zhb5MaAAoWxXCLtxg4LfLFjvfLiduZzW6Ds+bIyamUJewZUmqMaZDikqzaBP od4K2TSKClfN
wlgDkfB5Rwhx7KB3CdHcy18i0dsbiyUSyaQfn2Byqzuc1cOdzHL/WDbbU8iN pmTcLBoeN5NH
s04NbtxBX+J2mv/qHpxVXlL5+0NISX367N7wQv/cH8hLI4SDOETS+HJXKl+w OibuxtztW0mT
WXKapNoTSyFn17jaYSEtg9tYCXka6SzOZo6Pa7FfoZU49lJkFGePHml0TpKS HgypdJoFbZbf
DRZks5UBhciV2KnuHvZVg7PX6r5xdMhllwxLXZqetOZ87kDVRnIwr8K/ZTGA z+LzPnyOtE1X
/HQ5yRy8j3SVO3nG6y2iflJ6jSMqkK6owuba+/liuJAfN4qmbqRCBe+RWs1e m/lxPBzCI3iU
NTIu36zdBxVWXlndrq5x7JdyfzyEZiykukDmNGBRkK/wQI3eI+SOGqbjNaG5 sflvpNIzUhhj
96m4QkiW09O9gWUQo8SKXGFNzcTXNs7WzpT6jo9mioaUUmTHzDqNd9zJLJgV 49wv8W1Pleip
wRDNE0mD/KelS2aVOdWFm5dCeBbn5Ws324H20JhLHe+rNuZNG1kzNT2wq1XE 6mti9WUyTgKs
ibD6CqxWynT7e6++i0bc7DH9jToxzag/UxJ7u3cqFGpY/N9JJK438S0fvsm+ mn4bz5vGIYNt
/218h+hGU8USZ4L5IR+zuA+XOESmSbu1aBwq8ACUL3/eA5jEW/I9fJv557lC fvINnMR3Q/ge
3iErh+TM4YnEO+LyoWBtuHI5CmRiE4FVgBs36QmYHxPq60o6cVwUjdJYltqK ea2TYunttReJ
hF0+8jGwlzFd1rrPE7Yp/ZC0zfmHbdAKSweuENMW62TV4+x+5P+buY/AFkgy zmGjPyPnz4by
GXO9KKFdypAF6cJieFHHJ59+8nPWByqeg3x2yUGXkrmUXMO7kkKOXkLjm3pL E+Qc4OJ1Hjx8
ms9VyNqEBQjzXi9TyjZwmHvk3dopLNoZbQy6J7Es2hiybg3WbY7cLmPF3ugk rrqEyEXHz2JC
AyF50EpoSyhbyqdlPLQud/x6EMEarNV+1zl+11Auv6DYncL6KrN1GlJEm3Bp RZ7KZiteayle
N1NxQ4Xi9bjBVtxKguVt02V0723yX8KNO6NTuGUS26b1Ld66ed/i4A8wCbci pq3xMGNbe4vW
JGFd0XdR17TzohhdQ5uJtVGxmHCclAW8Ji4muJNqPqahGbeRDJ7WeY+QnnW8 WyDWk0rw2+dB
P3fG0Ei3zXS8kOe6du5ajdupsYcaQ9y7VwONala68DEkNTtdGNRkNPK6hzZc 1KzTYbh0GEN2
GHGi0aXi4B2INvmn8PGZnAzzntaumu3aslwFCFHMcooQStlsF/cI175o051V xqwE5SqK0mcb
qsddH5Kq4BVSNc77sZqp+iQ+ZVszyI2kahVT5VUXmYh9C3Agx38ZrtNNI9lT qa1STW1VtdSk
Kb2P1/sJ+xSr+4GK+Fchw94BpfU4gqyOP4e87bLX7qomy6XdO4WqIp+jQT3F nadp/2wFJU0O
JaNOv5i2xY0f1adRv2sSR2t26zI9RJ6npRdZYhOUvcRufZm9+goL8dWKjl3v dKyJMadUPOVS
GRfb+y7h+MCaSZyYmZM3aOQbVaVyt6YqxAF0Dz6tqfqMY/YuOzvNlWancG9i LW3fP5OuKVp5
i1V9Wdtfbmk69gO2/UadsAd0rT+IL9ieRsqeWEsPDQhD9PCYMJSYwhcvanob ifa2qgL4BVG/
R+n7fP5Vldd79PDz0u8T2qvsf5IJtbyetr0+xF1y1mhrOnOzOE6I47V03Lp0 5FRKvHd7bPdu
LGI+yu6btdofKf0Ty/rPfPMXTtm/agibLJM2BFmdxTla8BOogHFRawmepsxN HQuWh7CewZds
WGPUlPBams7cZBfLvtYlNqJdDqD5/GRU8/F3Sv9B6T85w/5VMXtaCOawBtNi g3EzBIHg4k4L
gpsQeAi0IeQoFc22ZaSjcOY5eN0XZDXP/YFQs0wkngvuC04JaEYUjSgPgsqL VlWHpcpXkZQ2
PMdetBh5nj3k0qsXNA/i+kXbdcJ2HeQHZNvyaOsUJqbd6CpWjFbNrzAd1Ab1 l0cblDbxaXcu
bfpl2/RjWg6s1lEZ13mbvQwo7Bk5deYFiUc/Li0/VUSnv6VqOfyqHWG1gn9H rMRKdRVWqVUV
OV/tRLjaiXC1HaGsXuHKwzpow5e5z6uhvWpDu4PPYiPEqLe3R1uXTOErM8Pu YtgbK9IacsIO
2WHL6hWdVvEjaITbr+JrtpdnKZWq3LAAX9+um5pVL/V+qj3D6jqeWCszo9sr r1hnVsfrMSKU
LuEJoqoD1C1EtB2LVA9z3Yc21V/BxganAzbggka3iHKrAzycYK9rdG3sCik/ r8ZZ7oBjxCk2
Wolzm9MCp5ZnqpvSow9NVT2gkoQ0xCTdwSRVfn9bnR5oteF4OMBf1zWysKIN 3+B81CDUkwQx
h/vPuzfXkaeLm31r5OpfK9f6dXINtHjkFmzxyi10GZN7w/Vhvycd9oUD4WA4 dAlT3Q0tDf5J
XA77JtDX0uDl0rM/7J/A9S0NHpHXT2BdS0NjUNaBCbRzHZJ1cAJhrhtkHZpA vWdz3WuY45ar
v9vHe7jugm7lJzjQyiTcrKGPwK2OsBezmKtyJCPPfixghRpFhypiqyphWJl4 UI3hMXUMp9Xd
OKvuwTPqXk3YMzoH5/F9O3/n8QP7cHAeP+TKpVc/4sqtVz+259V5/EQPVDct /BQ/47oeD+Nd
ku2jxZP4OVd+JuxeDu5zfNeK4xzf5yD/yXMUv+QqiA4m6X2uQjxoJDnUf80D 9VlalPT4qPMb
/NZOTzNtNdBrTHX/V+khnd5uX0udNVS3osfhMkpkUI+Sy8fJ5RPk8kly+RS5 PE0uz5DLc+hR
T6NPnde8nbTwOLzFHN5iDm8xh7eYw1vM4a1PRyy8dTu8bXJ4W+/wFnF4a3d4 W2zzpvA7PTd+
/x9QSwMEFAAAAAgABnQkN84oOklcCwAAcxgAAC0AAABqdW5rMS9iaW4vY29t L2tvbmtlb25n
L2NvbW1vbi9EYXRlVXRpbDIuY2xhc3O9WGt0VNUV/s48MpOZSUgCEwgJhIdI MjwCiKhBKZAE
ZyAD1AQEa4tD5hIG5gEzNzGx1aqFWrU+ULFUrEartQ9asQ8SpbXv2lr7bv91 rXa1f/zVtbra
/u3qt8+9c3MnGfFHVztrce+5+56997e//bgnvP3vN94EsB5/CMCjsGiokOs6 XsgfNwr54S4+
5Ar5rt6UaewzM9kNAfgUGo6lRlNd2RTf7zl8zBgyFep2JAcP9W4b7Ds0mEj2 KTT1T+8ZMIuZ
/PBmbuop5EtmKm/uT2VHjCBqFeaP87cmmVyTTi+Jx7tzue5Sae3AwACdiMUd +/r7D/XsSe7d
1jMYREShUfYnk+l0PJ7LlUp6Z82NmXzG3KLg7ejcr+DrKaSNELxojKAO9Qpz +jN5Y/dI7rBR
HEwdzhqCrjCUyu5PFTPybAt95tFMSaG9/4oEMIz5w4Y5WEinxkWYyA9mcgaj yp1QaO7otOIu
ncx2OfLNIbSgNYCFdKzfjtBQV08qa+TTqWIEbVikEKbRhGZnyHAZqtiqDbVH sARLGWzJIO/+
jkSic38Ay8u2KzzL/hURXI2VZEFQ80Uin8xksxIp6doZwjJ0Ck8xEtCxU/jz khqFedX8K8yl
lZ6RYtHImy4vXVgfwLqKwhgYL5lGLoIN4rtxaFql7D2cJnsi2F24k+ArAhZi NwewSaG+UhjC
teiktGQWe93q88rq7oILgIAXarFpjJldA5nciawhejsKxVzKDKEbN0nsLJ1o x2z9zv0hbMX2
ALYptF2pKCK4BhtD6MWOAPrKLGiXlqMIbkacdXpEPylc7XZmddDmKviZiiM5 0+kll0G+Crso
UNjUMZO9KuHMFgWxWwFC6t4IPogbFIJmwXoXADtr7rRG39iQccLMFPIKnjRB Ncx0SFFpBsEK
tVbIplFUuGoWxiqIQlC4LYJd6Kd3CdE8yF8y2dsbjyeTAwNBfJjprxwCrC/u ZB3sGMlmewq5
EymZSAuGRs2Bk1mnSjfspC9xO81/ZZfOKkDpjcMRDEkFB+zu8UP/vO/Ky+EI jiJD0vhydypf
sHoq4cWc7VtJk1ly2qjSE0shZ3eB2mkhLYPb4IY8jXQWZzMHzLU4rNBKHAcp Moqzh5OMAhbi
iB4dqXSaJW+W3w0WZLOVAYWOK7FT2V/jnOnOXqs/x9Apl70yT3Vp+tKa8zn9 FRvJQaPLv2Ux
hPvwiQDuJ23TFT9dTjIpT5Gucq/PeL1Z1D8pvXZAIZR2VWFz9f18MVTIjxpF UzdSwcV7R7Vx
UJ35MXw6gkfwKGtkVD5re44oLL+yul1dYzgs5X4mgmbMp7pA5jRgUZCvaH+V 3iPkziqmE1Wh
ebHpb/eS/6OFEXafSihEZDk9/+tYBnFKrMgVVlVNfHXjbO1MqW/sRKZoSCl1 7JxZp4nO25gF
0zXwgxLf9lSJnuoM0RwfMMh/WrpkVplTXbj5fATP4nPyPZztQHtoyKXG+iqN +dNG1kxNj/RK
FbH6JbH6EhknAdZEWHkFVt0y3f7+q2+nES97TH/FxqcZDWZKYm/PLoVCFYv/ O4nE9Q18K4Bv
sq+m3ybypjFs8IhxCZNEdyJVLHEmmO/xuUsE8DqHyDRpNxeN4QLPSPnyASCE KVyWL+a3mX+e
POQnX8kpvBnBd/E9sjIspxJfR6IzIR8K1oYnl6NAJjYRWAW4YaOegPkRob6m pBPHRdEojWSp
rZjXGimW3l57kUza5SMfA3sZ12Wt+zxpm9IPA7a54JANmkfa/ivEtNk6e/U4 ux/+/2bufbCF
BhjnkLEjI0fUeucYula0sFTqkBXpwUL4UcOngH4KctiHXM9hPnvkMEzJHEqu 4V1JJccm0fCa
3tIEOQh4eG2AD42Yy1XE2oR5iPJeK2PKNnCMe+Td6iks2BVrCHsvYXGsIWLd 6qxbvdwuY9nB
2CVcNYmOi46fhYQGLKCNhYTWSlkbAS7iubbd8etDB1Zhtfa7xvG7inL5hcXu FNZWmK3RkFZq
Ex6tyGPZbMVrLcXrZip2uRSvxw224lYSLG+bLqP7YFNwEjfuik3hA5fQM61v 8XYD5EBZxh9i
EhLYqa3xNGNbe53WJGHrY2+hpil5UYyuos3k6phYTDpOygJe91xMcifVAkxD M24hGTzQ895B
etbwboFYSyrBM6gPfdx5M9MY5+4Ed+9mneyhxl5qDFJjH/ce0EBjmpX1lO7T 7KzHfk1GA6+3
EryHmjU6DI8O44AdRoJoJORGB29/rCk4hYMzOTnM+5B21Wwp2K5ChChmOUbw Icfseu4RrgOx
ptsrjFkJyrqKMmAbqsVH3iNV4SukaoT30aqpOoQ7bGsGuZFUrWCq/OoiE5Ga h3SO/zJcH2k6
lj2d2irV1F5RS02a0vt4vZ+wT7GyT7viX4HjDAOU1iKHvI6/gBO2y167q5os l3bvnKwo8noN
6gx3PkH7T7koaXIoKTr9YtoWN7xfn8aCnksoVe3WxXqIPEtLz7HEnqdsgt36 Arv1RRbiS66O
Xet07CjudErFVy6VMbGdmsRd/asu4aMzc/JVGvlaRal8TFMV4QC6G/doqj7u mL3dzk6z2+wU
7k2upu3TM+mapJUpVvUb2v4SS9OxH7LtS9U/gE/pWn8QD9mejpY9sZYe7heG 6OExYSg5hccv
anobiPaWigL4KVH/jNKf8/mdCq936+Hnp98ntFfZ/yQTaXk9a3t9kLvksNHe 9PQWcZwUx6vp
uHXR0dMp8d7ts917OUlbHPfNWu2PlP6JZf1nvvkLJ+xfNYSNlkkbgqw+g3O0 ECRQAeOhVhs+
S5mXOhYsH2E9g/M2rBFqSngtTU/fZBdLqrXNRrTbATSXn4xKPv5O6T8o/Sdn 2L9cs6eFYLIa
TIsNxssQBIKHOy0IXkLgKdCGkKNUNNsXk46TTz0Lv/eCrBq97wo1i0Xiu+C9 4JSAZkSRXuVF
WPnQqvxYpGpcSWlnZedtRp5nD3n0akLzIK5fsF0nbddhfkC2LYm1TuHFaTe6 ilUjfKrJZTqs
DeovjzYobRLQ7jza9Eu26Ue0nF8vHZVxnb/Zz4CivqOnn3pO4tGPi8pPruj0 t1S1I6iWIKqW
8g+JZViulmOFusqV85VOhCudCFfaEcrqZa58rIN2fIH7/BraKza0A3wWGxFG vX1prLVtCl+c
GfY6hr3eldaIE3bEDltWL+u0ih9BI9x+GV+xvTxDqVTlunm4sF03Nate6v30 0ow0d3K1zIxu
v7xinVkdr8eIUNrG00NFB6gtRLQNC9R25roX7arPxcY6pwPWceQIugWUWx3g 4wR7VaNrZ1dI
+fk1znIH3EmcYqOVOLc5LXB6SaayKX360FTRA+oWQtrHJN3KJLm/v61OD7Ta cHwc4K/qGpnv
asOLeM0Coc4QRD33n/duqiFPX98UWCXX4Gq51q6Ra6jFJ7dwi19ukcuYOhit jQZ96WggGoqG
o5FJvNFd11IXvITvRAMT6Gup83PpuyManMD1LXU+kddOYE1LXUNY1qEJLOU6 IuvwBKJc18k6
MoFa36aaV1DvlWuwO8B7tOaCbuXHCb5MwhYNfRhedYy9eBxzVJZk5NiPeSxT BXSqk9iqihhS
JTygTDyiRvGkGsdZdRfOqbs1Yed0Ds7j+3b+zuMH9uHgPH7IlUevfsSVV69+ bM+r8/iJHqhe
WniLw7mGdD7EAX2OTTeHX+m3uQoyYfdwYJ/ju1b+cf4OV/K/PCfxC67C6OSp 95dcRXjQGMCv
8GseqM/SoqQnQJ3f4Ld2epppq45e46r7v0oP6fR3B1pqrKG6FT0OlzEig3qY XD5KLh8jl4+T
yzPk8gly+SS5PIse9TT61DOat1MWHoe3uMNb3OEt7vAWd3iLO7z16YiFt26H t40Ob2sd3joc
3pY6vC20eVP4nZ4bv/8PUEsDBAoAAAAAAABxJDcAAAAAAAAAAAAAAAAKAAAA anVuazEvc3Jj
L1BLAwQKAAAAAADHcyQ3AAAAAAAAAAAAAAAADgAAAGp1bmsxL3NyYy9jb20v UEsDBAoAAAAA
ANxOJDcAAAAAAAAAAAAAAAAXAAAAanVuazEvc3JjL2NvbS9rb25rZW9uZy9Q SwMECgAAAAAA
2XMkNwAAAAAAAAAAAAAAAB4AAABqdW5rMS9zcmMvY29tL2tvbmtlb25nL2Nv bW1vbi9QSwME
FAAAAAgAt1EkN1/W4QcYCgAAXjkAACsAAABqdW5rMS9zcmMvY29tL2tvbmtl b25nL2NvbW1v
bi9EYXRlVXRpbC5qYXZh7Vvdb9s4En8v0P+ByMNCTh25zXbvoWmKy8XJOndV sqjdLvpU0BJt
q5FEl6SS+g7932/4IYn6tNJ8ddEVgsQWZ4bDmd8MZyhljf1LvCTIp7F7SZNL QpOlC19imhw8
ffL0SRivKRPoM77CriBfhTuFOxEZY0FOKYuxOCjTpCKM3GMckSTArGnsd0aW lIU4sYjKZPxL
5M7CmHCB4/VBgwqtk6vRfOTpk3U6j0If+RHmHEmu96AB+p8cQnCtWXgFNxFM JIBsESY4QlPB
wmSJTr3Zp/HR7OTT7Mw7QYdoZwPXnuftBQGaTF7F8SvO3el0unNgZOmp2kSd vn/79tPxhffH
0fEsk+Z5QTCZxDHnRo6WNNrdReOQ43kEXmEE5NEE0QVKyDUKE5gg8QnaHZWX kC3OGcjlyZFv
ljz9Ae2i34lAggZ4gwLJFSYoNzSi88/EF25O+09GRMpsigVlyE8ZI4lQ/Bnp qMkEBduSiJmc
U+p4luT3C1XllaEB+WC4w/yrC8xnZtHOILeRvIDQ5UQ4Oenk4v27Txen4LaP Q/R8cNBB6p2d
v5+dbKOanhxfnI+3y3r79qxEWhAbE0rXFeuWEqRN4MZZ4oVRFHJnkE3R6rbM 8ALYbuM4yd/f
cceaq8VpjcubbrggsesXnL3W+E7LsvElVW1Y1oq0UzWuqEg+EoKKSap1Tq9b l1Nm6bEmtZyR
kdCM3szpzk3sIHJvgM8FLH2h0hv6CNfI80bjsUxHnvdqOnU/fPjQaC3NIkhQ l9ppN5O/uGDj
NpONRihOOTiCQJJlBK0II0M0Jz5OOUHVvQKFHCVUIL5J/BWjSfhfEriFMEO0 iAVkAOmFKr9T
ysq26c1qgdXVq3WyjOiW3N3H9FlqLMxWOIFrk2CO1rCnwFCYWAhdY4ZjFAiV jmv3edUaCo36
czPMCw2UTir0tQbdgK87zqnGgBjmVBW1Sv4NF8iB9RyCP9IoGhQDltF3dixH CLax+W23msWw
NufWFDlonC6Xk3k6KFF+gwwt/BVyTr76ZK02TzKoqgSwDZcJZcTi61zDneL8 llhvxvtDWMHM
GghXUI0e544nrULqlnHqyDQpq7ZKmhy0BW0tDP9gJCBQzoH0+4zGHzmp2orL vNFaCt9RclVO
87zxeDLxvOn0sXwlymps8VmXrYpCv4+JuNrmoQVbYx/8BmnXWoPZ/aEdEFYZ pIYqZiujPLeR
KG0rNzMJ7KCnoM6xVu3RCwG7p7rzWuCYJleECW6Vw4JWysLCvH9CNQgJM018 5SmwcYITCm0g
iQKuvJVJKXheR2Fy+WYlxPrVaHR9fe1ehv6lmgB8P3r522/uSsSvR4qqGgGg 11myTkWT3FKd
rFcBnlaYrXQKfYpl/0pMv0S5Efb/DcOqJLbswmslgywWZNFQGbK8IynsraP4 GFFAW6zKa/C+
I3hRN6MRevH8+fMBrFL+Rc+QHj0HY/N8GK46GhqKej1HPxRUrAJQmDV4dP2m 2bv6WCNNlGc/
73MyeuH+Ogqoz0d4HarhEf8SjQqZ4Pqo6ntbfJEJNQ6CcsHZCIHWjnFLGwgQ yLy+b2NhS0a0
cVAZ6oWDxuYSSo8cDVtb5g0wEfbwpx0fs3l/mhMPmxQHQUEq64oh2ntxL8ci BtpWBQFxaVwN
n0w5YbZMR1UtcQxVy6AaRmr/LEmZk0I6Lbk/R0qGKb0/9tlC8xlmVCLDVNBW IoVPJYjkx6H5
uYXZD0sDjjoBqYWFZWiVHWole3+bRlRitFqFFAXE49vzAWxpVS9B8fHQut8R utYaDW3WtsGd
PltQxTzSiqI1mY3LtKowg69FBBgP1itryWi4rnCUElm7ZDN3sdey5/WKQDWc +j7hPHe9krRg
NLZWkbMMEYmgVMzqVHlinMvfmr+3bWFaAVWaU+uoUmuhfNCNlYv555I/G5pj QwaIKLG7yo4X
i5KnOxOhEVRG4Q27bCO49ei9vuXeEnwIJwGC1K+L3zSeEyaxs6IpA/JcoByt 4bY3XuUkuSgl
2seJzC042aA15aEIrwCyDAy6xOqzMr6LzhbFsLo1VOwc+pBcHihPgqEsW3Lu jAaAPIdMB01P
0abcPmY0u1pGzWBqUcAEa8nnvuNwy6XVwu4Bwm0ot2i12F6Bl41nTFmBAMEm K/7df8ifxwvQ
Z45UatfW7BGD9nuj8N6DRP1KOckAPsdc6/FTBAVoPoF16ICwKpWOcNgG9w6w twJ3O2ofA7PH
K+Jfcu0Xic5QdbUKDAR6KT6UzoQBhlaYI/J1HTKigJDQwgFNZagxXHYoh2KC ecrUgxtzyEAA
GQFHXc/4GuH8L4le9SvDdaB7Rhz5aaQe29f4lOKbqZnyRH1Da8JCqhQyutQx LViq9rUFBlh2
A25OaURgVwz5ibaSow5UClsMm56HynVoEJZUrDX0lklf54xWpdIIDqX1QVlQ nRc9Q45Cd0WD
15buzfKldRrO/6xZ7xxzQ+lvaS/C5JseS5IQhrPT7FZA/qVg850oqaANUlZ7 YNWdVkxvA7aY
uzzvbbyLnOtQrBCecxqlsL4ojEMx+FnzjGaL8deTEudRZh0YCeM0E2xE/Th5 St+qql/HZUAi
gQGSlsf2GtJYNVcprjcmPdVm6ZWU6nLIzYXcVWa7OfZ/8Hz3I8D37tH6MFl0 WNekC1tHUIBj
tITK3xzZKSgVtToUgVlDz+X7irLmBjiZYlueEgDEcmmM8DQShd4ILE+Lo4C7 brZlHV9StXdX
UZ1ThpWadx2lXEpSTRFhDMRQ35ctUZAqljWjsgEpTlitZwpyxSoiQA2pg7Kl Fr3p9VQWmNSx
Za21BgE36qx1esSbxlZjd/9l/+a6fqba0W6Xyj+YftdSoaUXz7rv0nn293Ut dVVb+xirxm15
+eXuY8bqHfuGTcNTyb8jp6MjrzzKbo+f28ZHr368GgCPd4Y0o+gKNsnFJjc2 +C/MqoEaOORr
Npvq3Rh+aCJW1fsSbGhDMGs69TlL9l/q8x6A5f7LmswwUfu5+lMd1HWB+VPD odmxe+7q0nAX
/8nzapC/LhnH+Ue5kPxLpnxBqHQsXrNUWpX8lc1movkwL+w6kRSaCBiPgeMM KrIlYS4YgIOj
hRME1bSZ0XteE30ct9HL14maOOSq23jkAVcTT2acVt20W5v0UyNtfLpgaeIz 5i4ZU161fz+R
haj+oLeuGoGTGWNozLj3YmgcMMwXPbSWMbRUqykObYDjW4/6y4/KB4eHWvIA /fILaiH0Ls5n
k8GzF5rW87poP54cvTNC5RIkaVmh7Grht94wMGIm6pCyQzv1ooEh1gbpItev ERhyY7NaUpNX
HiSVnkhe3/RxbRdX9QxKsX1Hdm0R963hYa8m7qqlIcvCgmHjTP3yOyZ50sqe jJWbi79S/m3M
s/UolP9rkgXcvSbd7gSg30b6O//eW/59sGzb82X0iC6l3qr8dHb+JHP1nqiN xsEONMyDLbGe
LcuOdvj1f1BLAwQUAAAACADjcyQ3ViOxDhQKAABcOQAALAAAAGp1bmsxL3Ny Yy9jb20va29u
a2VvbmcvY29tbW9uL0RhdGVVdGlsMi5qYXZh7Vvdb9s4En8v0P+ByMNCTh25 zXbvoWmKy8XJ
OndVsqjdLvpU0BJtq5FEl6SS+g7932/4IYn6tNJ8ddEVgsQWZ4bDmd8MZyhl jf1LvCTIp7F7
SZNLQpOlC19imhw8ffL0SRivKRPoM77CLv8SubMwJlzgeH1QHhPkq3DHWJBT ymIsmkbbR6Zw
JyKt3KkII/cYRyQJMGsa+52RJWUhTiyip0/W6TwKfeRHmHMkhb8H2n30PzmG 4Fqz8AruIliO
ALpFmOAITQULkyU69Wafxkezk0+zM+8EHaKdDVx7nrcXBGgyeRXHrzh3p9Pp zoGRpedqE3X6
/u3bT8cX3h9Hx7NMmucFwWQSx5wbOVrSaHcXjUOO5xE4hRGQRxNEFygh1yhM YILEJ2h3VF5C
vjpnINcnh75ZAvUHtIt+JwIJGuANCiRbmKDcn4jOPxNfuDntPxkRKbMpFpQh P2WMJELxZ6Sj
JhsUbEsiZnJOqeRZkt8vVJVX5jnkg+UO868uMJ+ZVTuD3EjyAkKXE+HkpJOL 9+8+XZyC3z4O
0fPBQQepd3b+fnayjWp6cnxxPt4u6+3bsxJpQWxMKH1XrFtKkDaBG2eJF0ZR yJ1BNkWr2zLD
C2C7jeMkf3/HHWuuFqc1Lm+64YLErl9w9lrjOy3LxpdUtWFZK9JO1biiIlFI CComqdY5vW5d
Tpmlx5rUckZGQjN6M6c7N7GDyL0BPhew9IXKkOgjXCPPG43HMh953qvp1P3w 4UOjtTSLIEFd
aqfdTALjgo3bTDYaoTjl4AgCaZYRtCKMDNGc+DjlBFXzOgo5SqhAfJP4K0aT 8L8kcAthhmgR
C8gA0gtVfqeUlm3Tm9UCq6tX62Qp0S25u4/ps9RYmK1wAtcmwRytYVeBoTCx ELrGDMcoECof
1+7zqjUUGvXnZpgXGiidVOhrDboBX3ecU40BMcypKmqV/BsukAPrOQR/pFE0 KAYso+/sWI4Q
bGPz2241i2Ftzq0pctA4XS4n83RQovwGGVr4K+ScfPXJWu2eZFBVCWAbLhPK iMXXuYY7xfkt
sd6M94ewgpk1EK6gGj3OHU9ahdQt49SRaVKWbZU0OWgL2loY/sFIQKCeA+n3 GY0/clK1FZd5
o7UWvqPkqpzmeePxZOJ50+lj+UqU1djisy5bFZV+HxNxtc1DC7bGPvgN0q61 BrP7Qz8grDJI
DVXMVkZ5biNR2lZuZhLYQU9BnWOt2qMXAnZTdee1wDFNrggT3CqHBa2UhYV5 /4RqEBJmmvjK
U2DjBCcU+kASBVx5K5NS8LyOwuTyzUqI9avR6Pr62r0M/Us1Afh+9PK339yV iF+PFFU1AkCv
s2Sdiia5pTpZrwI8rTBb6RT6FMv+lZh+iXIj7P8bhlVJbNmF10oGWSzIoqEy ZHlHUthbR/Ex
ooC2WJXX4H1H8KJuRiP04vnz5wNYpfyLniE9eg7G5vkwXHU0NBT1eo5+KKhY BaAwa/Do+k2z
d/XpSZooz37e52T0wv11FFCfj/A6VMMj/iUaFTLB9VHV97b4IhNqHATlgrMR Aq0d45Y2ECCQ
eX3fxsKWjGjjoDLUCweNzSWUHjkatrbMG2Ai7OFPOz5m8/40Jx42KQ6CglTW FUO09+JejkUM
tK0KAuLSuBo+mXLCbJmOqlriGKqWQTWM1P5ZkjInhXRacn+OlAxTen/ss4Xm M8yoRIapoK1E
Cp9KEMlPXfNzC7MflgYcdQJSCwvL0Co71Er2/jaNqMRotQopCojHt+cD2NKq XoLi46F1vyN0
rTUa2qxtgzt9tqCKeaQVRWsyG5dpVWEGX4sIMB6sV9aS0XBd4SglsnbJZu5i r2XP6xWBajj1
fcJ57nolacFobK0iZxkiEkGpmNWp8sQ4l781f2/bwrQCqjSn1lGl1kL5oBsr F/PPJX82NMeG
DBBRYneVHS8WJU93JkIjqIzCG3bZRnDr0Xt9y70l+BBOAgSpXxe/aTwnTGJn RVMG5LlAOVrD
bW+8yklyUUq0jxOZW3CyQWvKQxFeAWQZGHSJ1WdlfBedLYphdWuo2Dn0Ibk8 UJ4EQ1m25NwZ
DQB5DpkOmp6iTbl9zGh2tYyawdSigAnWks99x+GWS6uF3QOE21Bu0WqxvQIv G8+YsgIBgk1W
/Lv/kD+PF6DPHKnUrq3ZIwbt90bhvQeJ+pVykgF8jrnW46cICtB8AuvQAWFV Kh3hsA3uHWBv
Be521D4GZo9XxL/k2i8SnaHqahUYCPRSfCidCQMMrTBH5Os6ZEQBIaGFA5rK UGO47FAOxQTz
lKkHN+aQgQAyAo66nvE1wvlfEr3qV4brQPeMOPLTSD23r/EpxTdTM+WJ+obW hIVUKWR0qWNa
sFTtawsMsOwG3JzSiMCuGPITbSVHHagUthg2PQ+V69AgLKlYa+gtk77OGa1K pREcSuuDsqA6
L3qGHIXuigavLd2b5UvrNJz/WbPeOeaG0t/SXoTJVz2WJCEMZ6fZrYD8S8Hm O1FSQRukrPbA
qjutmN4GbDF3ed7beBc516FYITznNEphfVEYh2Lws+YZzRbjryclzqPMOjAS xmkm2Ij6cfKU
vlVVv47LgEQCAyQtj+01pLFqrlJcb0x6qs3SKynV5ZCbC7mrzHZz7P/g+e5H gO/do/Vhsuiw
rkkXto6gAMdoCZW/ObJTUCpqdSgCs4aeyxcWZc0NcDLFtjwlAIjl0hjhaSQK vRFYnhZHAXfd
bMs6vqRq766iOqcMKzXvOkq5lKSaIsIYiKG+L1uiIFUsa0ZlA1KcsFrPFOSK VUSAGlIHZUst
etPrqSwwqWPLWmsNAm7UWev0iDeNrcbu/sv+zXX9TLWj3S6VfzD9rqVCSy+e dd+l8+zv61rq
qrb2MVaN2/Lyy93HjNU79g2bhqeSf0dOR0deeZTdHj+3jY9e/Xg1AB7vDGlG 0RVskotNbmzw
X5hVAzVwyNdsNtW7MfzQRKyq9yXY0IZg1nTqc5bsv9TnPQDL/Zc1mWGi9nP1 pzqo6wLzp4ZD
s2P33NWl4S7+k+fVIH9dMo7zj3Ih+ZdM+YJQ6Vi8Zqm0Kvkrm81E82Fe2HUi KTQRMB4DxxlU
ZEvCXDAAB0cLJwiqaTOj97wm+jhuo5evEzVxyFW38cgDriaezDitumm3Numn Rtr4dMHSxGfM
XTKmvGr/KiILUf1Bb101AiczxtCYce/F0DhgmC96aC1jaKlWUxzaAMe3HvWX H5UPDg+15AH6
5RfUQuhdnM8mg2cvNK3nddF+PDl6Z4TKJUjSskLZ1cJvvWFgxEzUIWWHdupF A0OsDdJFrl8j
MOTGZrWkJq88SCo9kby+6ePaLq7qGZRi+47s2iLuW8PDXk3cVUtDloUFw8aZ +uV3TPKklT0Z
KzcXf6X825hn61Eo/9ckC7h7TbrdCUC/jfR3/r23/Ptg2bbny+gRXUq9Vfnp 7PxJ5uo9URuN
gx1omAdbYj1bVhHtQPV/UEsBAhQACgAAAAAA+nMkNwAAAAAAAAAAAAAAAAYA AAAAAAAAAAAQ
AAAAAAAAAGp1bmsxL1BLAQIUABQAAAAIAAZ0JDf1M9tAjwAAAOgAAAAQAAAA AAAAAAEAIAAA
ACQAAABqdW5rMS8uY2xhc3NwYXRoUEsBAhQAFAAAAAgAu0wkN9WFy5W8AAAA fQEAAA4AAAAA
AAAAAQAgAAAA4QAAAGp1bmsxLy5wcm9qZWN0UEsBAhQACgAAAAAABnQkNwAA AAAAAAAAAAAA
AAoAAAAAAAAAAAAQAAAAyQEAAGp1bmsxL2Jpbi9QSwECFAAKAAAAAAAGdCQ3 AAAAAAAAAAAA
AAAADgAAAAAAAAAAABAAAADxAQAAanVuazEvYmluL2NvbS9QSwECFAAKAAAA AAAGdCQ3AAAA
AAAAAAAAAAAAFwAAAAAAAAAAABAAAAAdAgAAanVuazEvYmluL2NvbS9rb25r ZW9uZy9QSwEC
FAAKAAAAAAAGdCQ3AAAAAAAAAAAAAAAAHgAAAAAAAAAAABAAAABSAgAAanVu azEvYmluL2Nv
bS9rb25rZW9uZy9jb21tb24vUEsBAhQAFAAAAAgABnQkN/ZRm41MCwAAThgA ACwAAAAAAAAA
AAAgAAAAjgIAAGp1bmsxL2Jpbi9jb20va29ua2VvbmcvY29tbW9uL0RhdGVV dGlsLmNsYXNz
UEsBAhQAFAAAAAgABnQkN84oOklcCwAAcxgAAC0AAAAAAAAAAAAgAAAAJA4A AGp1bmsxL2Jp
bi9jb20va29ua2VvbmcvY29tbW9uL0RhdGVVdGlsMi5jbGFzc1BLAQIUAAoA AAAAAABxJDcA
AAAAAAAAAAAAAAAKAAAAAAAAAAAAEAAAAMsZAABqdW5rMS9zcmMvUEsBAhQA CgAAAAAAx3Mk
NwAAAAAAAAAAAAAAAA4AAAAAAAAAAAAQAAAA8xkAAGp1bmsxL3NyYy9jb20v UEsBAhQACgAA
AAAA3E4kNwAAAAAAAAAAAAAAABcAAAAAAAAAAAAQAAAAHxoAAGp1bmsxL3Ny Yy9jb20va29u
a2VvbmcvUEsBAhQACgAAAAAA2XMkNwAAAAAAAAAAAAAAAB4AAAAAAAAAAAAQ AAAAVBoAAGp1
bmsxL3NyYy9jb20va29ua2VvbmcvY29tbW9uL1BLAQIUABQAAAAIALdRJDdf 1uEHGAoAAF45
AAArAAAAAAAAAAEAIAAAAJAaAABqdW5rMS9zcmMvY29tL2tvbmtlb25nL2Nv bW1vbi9EYXRl
VXRpbC5qYXZhUEsBAhQAFAAAAAgA43MkN1YjsQ4UCgAAXDkAACwAAAAAAAAA AQAgAAAA8SQA
AGp1bmsxL3NyYy9jb20va29ua2VvbmcvY29tbW9uL0RhdGVVdGlsMi5qYXZh UEsFBgAAAAAP
AA8AIAQAAE8vAAAAAA==
--------------010102070300070803080102--
| Re: Organize Imports in Eclipse 3.3 [message #247283 is a reply to message #247278] |
Tue, 04 September 2007 03:36   |
Your example (junk1.zip) works for me with plain Eclipse SDK - did you
try that? Is there anything in the .log?
Dani
>> Dear Ed Merks,
>> java files) over and test repeatably, why and when and where the
>> organize imports stop working.
>> Thanks
>> konkeong
>> Ed Merks wrote:
>>> Lee,
>>> installed. I.e., I right clicked on the src folder and invoked
>>> Source->Organize Imports. It correctly handled all the files. If
>>> you can create a simple reproducible test case for your problem,
>>> then you should open a bugzilla for it.
>>>> Hi all,
>>>> Eclipse 3.2.
>>>> on Windows XP platform.
>>>> JDK 1.5 b9
>>>> imports.
>>>> On Eclipse 3.2
>>>> node and
>>>> package.
>>>> are not changed.
>>>> on single (one) file, the organized import works.
>>>> Thanks
>>>> konkeong
| Re: Organize Imports in Eclipse 3.3 [message #247374 is a reply to message #247283] |
Wed, 05 September 2007 03:31   |
--------------040600050308080107070707
I downloaded this zip file, unzip to clean folder.
http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/20070702/eclipse-java-europa-win32. zip&r=1&protocol=http
Use a new workspace.
Did the same thing on the project attached earlier.
Fail.
There is no ".log" in my "workspace\.metadata" folder. Or is there any
other ".log"?
Could be be a JDK version problem?
My machine has only 1 JDK installed,
java version "1.5.0_09"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_09-b01)
Java HotSpot(TM) Client VM (build 1.5.0_09-b01, mixed mode, sharing)
Windows XP Professional SP 2
> Dani
>>> Dear Ed Merks,
>>> Thanks
>>> konkeong
>>> Ed Merks wrote:
>>>> Lee,
>>>>> Hi all,
>>>>> Eclipse 3.2.
>>>>> JDK 1.5 b9
>>>>> imports.
>>>>> On Eclipse 3.2
>>>>> node and
>>>>> package.
>>>>> are not changed.
>>>>> Thanks
>>>>> konkeong
name="eclipse.log"
filename="eclipse.log"
!SESSION 2007-09-05 14:56:44.906 -----------------------------------------------
eclipse.buildId=I20070625-1500
java.version=1.6.0
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.resources 2 10035 2007-09-05 14:56:56.468
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.osgi 2 0 2007-09-05 14:57:09.375
!MESSAGE While loading class "org.eclipse.mylyn.internal.tasks.ui.ITaskHighlighter", thread "Thread[Worker-0,5,main]" timed out waiting (5000ms) for thread "Thread[Worker-1,5,main]" to finish starting bundle "update@plugins/org.eclipse.mylyn.tasks.ui_2.0.0.v20070627-1400.jar [125]". To avoid deadlock, thread "Thread[Worker-0,5,main]" is proceeding but "org.eclipse.mylyn.internal.tasks.ui.ITaskHighlighter" may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle "update@plugins/org.eclipse.mylyn.tasks.ui_2.0.0.v20070627-1400.jar" by thread "Worker-1".
at org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1141)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:258)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:136)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
at org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:243)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:49)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:239)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition$1.run(LightweightDecoratorDefinition.java:117)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.internalGetDecorator(LightweightDecoratorDefinition.ja va:113)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:241)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 71)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:336)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:322)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.ens ureResultCached(DecorationScheduler.java:369)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:329)
Caused by: org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 56 more
Root exception:
!ENTRY org.eclipse.osgi 2 0 2007-09-05 14:57:14.390
!MESSAGE While loading class "org.eclipse.mylyn.internal.tasks.ui.TaskListColorsAndFonts", thread "Thread[Worker-0,5,main]" timed out waiting (5000ms) for thread "Thread[Worker-1,5,main]" to finish starting bundle "update@plugins/org.eclipse.mylyn.tasks.ui_2.0.0.v20070627-1400.jar [125]". To avoid deadlock, thread "Thread[Worker-0,5,main]" is proceeding but "org.eclipse.mylyn.internal.tasks.ui.TaskListColorsAndFonts" may not be fully initialized.
!STACK 0
at org.eclipse.mylyn.internal.context.ui.ColorMap.<clinit>(ColorMap.java:23)
at org.eclipse.mylyn.context.ui.ContextUiPlugin.<init>(ContextUiPlugin.java:87)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
... 59 more
Root exception:
!ENTRY org.eclipse.osgi 2 0 2007-09-05 14:57:19.468
!MESSAGE While loading class "org.eclipse.mylyn.tasks.ui.TasksUiPlugin", thread "Thread[main,6,main]" timed out waiting (5000ms) for thread "Thread[Worker-1,5,main]" to finish starting bundle "update@plugins/org.eclipse.mylyn.tasks.ui_2.0.0.v20070627-1400.jar [125]". To avoid deadlock, thread "Thread[main,6,main]" is proceeding but "org.eclipse.mylyn.tasks.ui.TasksUiPlugin" may not be fully initialized.
!STACK 0
at org.eclipse.mylyn.context.ui.ContextUiPlugin$5.run(ContextUi Plugin.java:258)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
... 39 more
Root exception:
!ENTRY org.eclipse.osgi 2 0 2007-09-05 14:57:24.562
!MESSAGE While loading class "org.eclipse.mylyn.tasks.ui.TaskListManager", thread "Thread[main,6,main]" timed out waiting (5000ms) for thread "Thread[Worker-1,5,main]" to finish starting bundle "update@plugins/org.eclipse.mylyn.tasks.ui_2.0.0.v20070627-1400.jar [125]". To avoid deadlock, thread "Thread[main,6,main]" is proceeding but "org.eclipse.mylyn.tasks.ui.TaskListManager" may not be fully initialized.
!STACK 0
at org.eclipse.mylyn.context.ui.ContextUiPlugin$5.run(ContextUi Plugin.java:259)
... 39 more
Root exception:
--------------040600050308080107070707--
| Re: Organize Imports in Eclipse 3.3 [message #247516 is a reply to message #247507] |
Thu, 06 September 2007 04:33  |
> Dear Dani,
> Thank you so much for lodging the bug report and confirm that it is a
> bug. I guess now I have to wait for the next release?
> http://download.eclipse.org/eclipse/downloads/
> I should take the newest "3.3 Stream Maintenance Builds" that is later
> than "M20070905-0800", right?
We will put the fix into 3.3.1 i.e. next M-build > M20070905-1045.
Dani
> No issue here, I am running 2 copies of eclipse: 3.2.2 and 3.3
> 3.2.2 for the "organize imports". Just a bit of nuisance.
> Thanks
> konkeong
>>> Please ignore the previous attachment of the "eclipse.log".
>>> It is from the first workspace.
>>> When I switch to a new workspace, there is no ".log" file being
>>> generated.
>> I can reproduce now. Organize Imports is broken if the selection
>> contains exactly one file. Here's the bug for it:
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=202270
>> Dani
Current Time: Sun Nov 09 00:28:24 EST 2025
Powered by FUDForum. Page generated in 0.05587 seconds
