Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Ruby module in DLTK
Ruby module in DLTK [message #24640] Thu, 29 May 2008 14:51 Go to next message
I am writing some code that looks at the Ruby ITypes within an
ISourceModule. I guess it makes makes (but is a little confusing) that a
Ruby module becomes an IType, but is there any way to easily distinguish
Ruby modules from Ruby classes?
Another issue I have is that IScriptProject.findType(String,
IProgressMonitor) does not find the above Ruby module when I use
IType.getFullyQualifiedName() as the first parameters. What am I doing
wrong?
Thanks, Felix
Re: Ruby module in DLTK [message #24681 is a reply to message #24640] Thu, 29 May 2008 16:00 Go to previous messageGo to next message
Never mind the second question, this simply hasn't been implemented in DLTK
1.0RC1.
"Felix L J Mayer" <felix.mayer@objectaid.com> wrote in message
news:g1mtvo$n7e$1@build.eclipse.org...
> wrong?
> Thanks, Felix
Re: Ruby module in DLTK [message #24721 is a reply to message #24640] Fri, 30 May 2008 01:15 Go to previous messageGo to next message
Hi Felix,
You can distinguish them by class:
org.eclipse.dltk.ruby.ast.RubyModuleDeclaration
org.eclipse.dltk.ruby.ast.RubyClassDeclaration
Alex
Re: Ruby module in DLTK [message #24759 is a reply to message #24640] Fri, 30 May 2008 04:12 Go to previous messageGo to next message
Hi Felix,
For this purpose you need to call IType.getFlags() method and check for Modifiers.AccModule flag. It it is set then
IType is a module. If not set then it is class.
> wrong?
To find types you should use SearchEngine.searchAllTypeNames() methods.
Example of using it to search types by name:
IProject prj = myProject;
IScriptProject project = DLTKCore.create(prj);
String patternString = "myClass*";
// Requestor will accept matches
TypeNameMatchRequestor requestor = myRequestor;
IDLTKSearchScope scope = SearchEngine.createSearchScope(project);
try {
SearchEngine engine = new SearchEngine();
engine.searchAllTypeNames(null, 0, patternString.toCharArray(),
SearchPattern.R_EXACT_MATCH | SearchPattern.R_PATTERN_MATCH,
IDLTKSearchConstants.TYPE, scope, requestor,
IDLTKSearchConstants.WAIT_UNTIL_READY_TO_SEARCH, null);
} catch (CoreException e) {
e.printStackTrace();
For more information about search you could look at SearchTests class from org.eclipse.dltk.tcl.core.tests plugin.
> Thanks, Felix
Re: Ruby module in DLTK [message #25013 is a reply to message #24759] Wed, 04 June 2008 15:14 Go to previous message
Thanks for the helpful answers. Is there also a way to search within the
context of a IType? I would like to find the ITypes that correspond to an
ITypes superclass names. The original IType will typically have imports and
such that uniquely define the superclasses, but the search engine might find
additional ITypes that have the right name.
"Andrei Sobolev" <haiodo@xored.com> wrote in message
news:g1oct5$ifi$1@build.eclipse.org...
> Hi Felix,
>> wrong?
> try {
>> Thanks, Felix
Previous Topic:RSE plugin integration with dltk
Next Topic:FieldDeclaration not included in Outline view
Current Time: Sat Jul 19 14:16:29 EDT 2025
Powered by FUDForum. Page generated in 0.04277 seconds
