Home » Language IDEs » Java Development Tools (JDT) » NoClassDefFoundError...
NoClassDefFoundError... [message #247056] Wed, 29 August 2007 01:08 Go to next message
Originally posted by: simon.ou.edu
Hi...
I hope that all is well.
I have a serial port code that works within a regular java application.
When I port the same code (mostly untoched) onto an RCP plugin
applicaiton, then I get the following error:
java.lang.NoClassDefFoundError: gnu/io/CommPortIdentifier
at com.saic.ngk.messaging.SerialComm.<init>(SerialComm.java:23)
at
com.saic.ngk.userInterface.TSmainGui.createPartControl(TSmai nGui.java:80)
The libraries are obvioulsy correctly installed in the proper places for
the Java-only application to work correctly. It is a problem with the
plugin run-time enviornment, but I cannot figure this out.
I wonder if any one has had a similar issue where
comes along? How to solve this problem? Thanks.
Regards...
Miguel.
Re: NoClassDefFoundError... [message #247061 is a reply to message #247056] Wed, 29 August 2007 02:21 Go to previous messageGo to next message
Originally posted by: jacek.pospychala.pl.ibm.com
Miguel,
Because of their OSGI nature, plugins have different approach to loading
classes. They look only in other plug-ins and not in jars.
You can package your jar in a plug-in (remember to keep it in folder,
don't jar it), if it's your jar you can repackage it's classes directly
into a plug-in. In fact, if the jar is repackaged into plug-in, it still
can work as a jar for normal Java applications, but works also for OSGI
apps.
There is more detail on this common issue:
http://wiki.eclipse.org/Pragmatic_Advice_on_PDE_Classpath
Adding 3rd party jar files:
http://wiki.eclipse.org/Plug-in_Development_Environment
miguel wrote:
> Hi...
> application. When I port the same code (mostly untoched) onto an RCP
> plugin applicaiton, then I get the following error:
> at
> for the Java-only application to work correctly. It is a problem with
> the plugin run-time enviornment, but I cannot figure this out.
> Regards...
> Miguel.
Re: NoClassDefFoundError... [message #247079 is a reply to message #247061] Wed, 29 August 2007 08:37 Go to previous messageGo to next message
Hi Jacek...
I appreciate your help. This was exactly what was going on. The two
links that you provided point to the exact solution. Thanks again.
This problem + solution should be somewhere in the FAQ. Do you know if
they are? How could any one suggest and/or include this in the FAQ for
Eclipse? Thanks.
Regards...
Miguel.
Jacek Pospychala wrote:
> Miguel,
> apps.
Re: NoClassDefFoundError... [message #247084 is a reply to message #247079] Wed, 29 August 2007 09:47 Go to previous message
Miguel,
Indeed, I looked into main FAQ
(http://wiki.eclipse.org/index.php/The_Official_Eclipse_FAQs)
and RCP-FAQ (http://wiki.eclipse.org/index.php/RCP_FAQ)
but didn't found it.
Anyone (you too!) can add to Wiki, you'll only need to create your own
account, but this is just to keep your email.
miguel wrote:
> Hi Jacek...
> if they are? How could any one suggest and/or include this in the FAQ
> for Eclipse? Thanks.
> Regards...
> Miguel.
>> Miguel,
>> loading classes. They look only in other plug-ins and not in jars.
>> directly into a plug-in. In fact, if the jar is repackaged into
>> plug-in, it still can work as a jar for normal Java applications, but
>> works also for OSGI apps.
Previous Topic:Launching Framework / ClassLoader
Next Topic:Subversion & subclipse
Current Time: Tue Sep 16 23:27:51 EDT 2025
Powered by FUDForum. Page generated in 0.02795 seconds
