Home » Archived » BIRT » How to periodically generate reports
How to periodically generate reports [message #247001] Mon, 09 July 2007 16:23 Go to next message
Originally posted by: ali.jetha.auf.org
Hi guys,
I'm still new to BIRT and I wanted to have your opinion on the best way
to generate batch reports periodically.
A use case would be:
I have a report with a parameterized query. I want to generate into a
local folder the reports (in pdf format) with parameters A, B, C, D, ... Z.
I want this to be done everyday, without human interraction if possible.
(It would be also nice to rename automatically the files with the
parameter at the end: report-A.pdf, report-B.pdf, ...)
Re: How to periodically generate reports [message #247026 is a reply to message #247001] Mon, 09 July 2007 17:58 Go to previous message
Hello Ali Jawad-Jetha,
This would be relatively straight-forward to do using the ReportEngine in
a java program. Have a look at the RunTime package form BIRT and take a
look at the Integration Examples on the wiki ( http://wiki.eclipse.org/Integration_Examples_%28BIRT%29
Scott Rosenbaum
> Hi guys,
> way to generate batch reports periodically.
> ... Z.
> possible. (It would be also nice to rename automatically the files
> with the parameter at the end: report-A.pdf, report-B.pdf, ...)
Previous Topic:CISCO - Reporting
Next Topic:help for Expression Builder
Current Time: Tue Jul 29 00:08:55 EDT 2025
Powered by FUDForum. Page generated in 0.04691 seconds
