open file in existing Eclipse instance [message #246809] |
Fri, 25 January 2008 08:52  |
Originally posted by: dsvick.gmail.com
I've looked and can not find an answer to my question, of course there are
a number of different ways to ask it, so if there is an answer or
discussion that already exists - just give me a shove in the right
direction.
I've got eclipse installed and everything is fine so far except that
whenever I want to open a new file in Eclipse from my file system (windows
explorer) it tries to open it in a new instance of Eclipse. I'm not
running multiple work spaces (no need to do so) so I end up either
dragging the file to the currently running Eclipse or opening it through
the open dialog in Eclipse. I've checked the preferences and can't find a
setting to tell Eclipse to open new files in a current instance.
Any help would be appreciated
thanks
Dave
Re: open file in existing Eclipse instance [message #246890 is a reply to message #246881] |
Fri, 25 January 2008 16:34   |
Originally posted by: eclipse-news.rizzoweb.com
ns_dkerber@ns_WarrenRogersAssociates.com wrote:
> In article <fncrd7$itn$1@build.eclipse.org>, eclipse-news@rizzoweb.com
> says...
>> There is a File > Open menu item that allows you to open a single file
>> outside the workspace, but that is not a very useful thing to do for
>> Java source files because they don't have any project context.
>> What would you expect Eclipse to do if you double-click an arbitrary
>> Java file from your file explorer - what project should it associate
>> that code with? Where does all the necessary context come from? All it
>> can really do without making lots of assumptions would be to open it in
>> a simple text editor, which IMO isn't a very useful thing to do.
> Why not? I have certainly had a use for this, when a java file is
> either standalone, or associated with a non-eclipse project, or I just
> want to look at some sample code that I downloaded from the web.
As I said, IMO. Obviously other people have different opinions.
There is, of course, File > Open...
Anecdotally, I find that I do very little in the Windoze File Explorer
with code files. The Eclipse Navigator, limited as it is, is good enough
for manipulating code files and I keep a "Sandbox" project in all my
workspaces specifically for the purpose of examining code such as
samples or experiments.
The beauty of Eclipse as a community is that we are each able to voice
our opinions and desires, and they actually have an effect - comment
and/or vote on the Bugzillas if you're so inclined; and as I said, I'm
sure code contributions would be more than welcomed since most of the
committers are usually overbooked with work and this has been a thorny
problem for quite a while.
Eric
Re: open file in existing Eclipse instance [message #247092 is a reply to message #246915] |
Tue, 29 January 2008 11:37  |
Dave wrote:
> Thanks for the replies, I sort of figured that that would be the
> response and the reason behind it too. I can see both sides of the fence
> in this and have to fall into the one where there would be need to do
> what I asked for. In a project environment I can understand the lack of
> it and it makes sense then too.
> My needs though is to open a lot of single files that may or may not be
> associated with a project. I guess I wont be uninstalling Crimson Editor
> any time soon then and I'll just stick with Eclipse for projects.
> Thanks again for you responses
Here's a little elaboration on the Sandbox "trick" that I use:
I always have a Java project in my workspaces named Sandbox and I can
drop whatever "temporary" code I want to examine or play with in there.
To go a little further, you can set up a linked folder in that project
to point to a location where you like to dump sample code; then if you,
for example, download some sample code into that location on your file
system, all you have to do is jump back to Eclipse, Refresh the project
(right-click menu), and you'll see the file(s) you just dumped in there.
I understand this is a work-around, but it is better than nothing and
faster than trying to contribute solutions to the larger request of
file-explorer integration.
Hope this helps,
Eric
FUDForum. Page generated in 0.33477 seconds
