problems extending JPanel [message #24679] |
Thu, 11 March 2004 07:24  |
Originally posted by: mb.thomas-daily.de
Greetinx!
I am using Visual Editor 0.5.
I just tried to add a class that extends JPanel.
The result:
!ENTRY org.eclipse.ve.java.core 2 0 Mrz 11, 2004 13:10:25.404
!MESSAGE Exception
!STACK 0
java.lang.ExceptionInInitializerError: IWAV0118E Class
somepackage.MyJPannel (or one of its superclasses) is not found or has
errors.
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:825)
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:752)
at
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.addCo mponentWithConstraint(ContainerProxyAdapter.java:210)
at
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.addCo mponent(ContainerProxyAdapter.java:178)
at
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.appli ed(ContainerProxyAdapter.java:53)
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.appliedLi st(BeanProxyAdapter.java:180)
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.applyAllS ettings(BeanProxyAdapter.java:525)
at
org.eclipse.ve.internal.jfc.core.ComponentProxyAdapter.apply AllSettings(ComponentProxyAdapter.java:635)
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:754)
at
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itSetting(CompositionProxyAdapter.java:125)
at
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:103)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1663)
!MESSAGE Could not instantiate somepackage.MyJPannel with initialization
string=null
!MESSAGE Exception
!STACK 0
errors.
at
at
at
at
at
This is the code:
package somepackage;
import javax.swing.JPanel;
public class MyJPannel extends JPanel
This is the example code that uses the above class:
import javax.swing.JFrame;
public class MyJPanelExamleJFrame extends JFrame
private javax.swing.JPanel jContentPane = null;
private somepackage.MyJPannel myJPannel = null;
public MyJPanelExamleJFrame()
super();
initialize();
private void initialize()
this.setSize(300, 200);
this.setContentPane(getJContentPane());
private javax.swing.JPanel getJContentPane()
if (jContentPane == null)
jContentPane = new javax.swing.JPanel();
jContentPane.setLayout(new java.awt.BorderLayout());
jContentPane.add(getMyJPannel(), java.awt.BorderLayout.CENTER);
return jContentPane;
private somepackage.MyJPannel getMyJPannel()
if (myJPannel == null)
myJPannel = new somepackage.MyJPannel();
return myJPannel;
Is this a bug?
thanx!
Marcus
Re: problems extending JPanel [message #25763 is a reply to message #25752] |
Fri, 12 March 2004 15:56  |
Rich Kulp wrote:
> Not VE 0.5.0. The 1.0.0 drivers do, but they are not up to production
> level yet.
> We aren't doing any bug fixes for 0.5.0 because we are heads down on
> 1.0.0 work.
I see. I wish you good luck and a nice weekend :)
And thanks for this nevertheless nice tool!
Marcus
Re: problems extending JPanel [message #584228 is a reply to message #24679] |
Thu, 11 March 2004 07:49  |
Marcus Beyer wrote:
> Greetinx!
> The result:
now I've seen that there are some more messages in the log:
!ENTRY org.eclipse.jem.beaninfo 2 0 Mrz 11, 2004 13:10:15.483
!MESSAGE %Introspection failed on class "somepackage.MyJPannel."
!ENTRY org.eclipse.jem.beaninfo 2 0 Mrz 11, 2004 13:10:15.967
!MESSAGE %Introspection failed on class "somepackage.MyJPanelExamleJFrame."
!ENTRY org.eclipse.jem.beaninfo 2 0 Mrz 11, 2004 13:10:24.467
!ENTRY org.eclipse.jem.beaninfo 2 0 Mrz 11, 2004 13:10:24.951
string=null
Marcus
Re: problems extending JPanel [message #584275 is a reply to message #24679] |
Thu, 11 March 2004 10:18  |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Do you have build on resource changes turned on? This kind of error
usually occurs because your classes aren't being compiled. Try doing a
rebuild all first to see if that allows them to come up.
Thanks, Rich Kulp
Re: problems extending JPanel [message #584396 is a reply to message #25058] |
Fri, 12 March 2004 06:00  |
I think so, but can't find that switch :|
> This kind of error
Thank you! Strange: the error only disappears from the "Java Beans"
view, when I close the Visual Editor of the file referencing the new
class -- and open it again. Is this normal for VE?
In the meantime I have a new (but smaller) problem with this tiny class:
import javax.swing.BoxLayout;
public class XBoxedJPanel extends JPanel
public XBoxedJPanel()
super();
initialize();
setLayout(new BoxLayout(this, BoxLayout.X_AXIS));
When I add this somewhere I don't get an entry for "layout" in the
"Properties" view. The "layout" field is simply empty. Why?
thanx!
Marcus
Re: problems extending JPanel [message #584439 is a reply to message #25465] |
Fri, 12 March 2004 10:18  |
We have problems with BoxLayout. It will take a little time to catch
everything up. New parsing algorithm we are using breaks BoxLayout
because it is special because it requires the parent for construction.
(This is actually a stupid implementation. Layouts aren't meant to be
shared, and they are told who the parent is when they applied, there was
no reason to require it in the constructor too).
Thanks, Rich Kulp
Re: problems extending JPanel [message #584475 is a reply to message #25465] |
Fri, 12 March 2004 10:53  |
Eclipse 3.0 has changed notifications on when things are changed and we
haven't had the time to make it work completely. So it may be necessary
at times to close and reopen an editor if something changes.
Thanks, Rich Kulp
Re: problems extending JPanel [message #584503 is a reply to message #25692] |
Fri, 12 March 2004 11:05  |
Sorry? I am using Eclipse 2.1.2.
Then VE runs also on Eclipse 3?
thanx!
Marcus
Re: problems extending JPanel [message #584531 is a reply to message #25745] |
Fri, 12 March 2004 12:36  |
level yet.
1.0.0 work.
> thanx!
> Marcus
Thanks, Rich Kulp
Re: problems extending JPanel [message #584561 is a reply to message #25752] |
> level yet.
> 1.0.0 work.
Marcus
FUDForum. Page generated in 0.06495 seconds
