Home » Eclipse Projects » Eclipse Platform » M9 not possible to launch Run-time workspace
M9 not possible to launch Run-time workspace [message #245469] Wed, 26 May 2004 05:34 Go to next message
Originally posted by: Vasily.Smirnov.atbusiness.com
------=_NextPart_000_02E8_01C44326.398F7E20
Content-Type: text/plain;
charset="koi8-r"
Content-Transfer-Encoding: quoted-printable
Hi!
After attempt to launch my plugin inside run-time workspace I got =
following error:
eclipse.buildId=3Dunknown
java.version=3D1.4.2
java.vendor=3DSun Microsystems Inc.
BootLoader constants: OS=3Dwin32, ARCH=3Dx86, WS=3Dwin32, NL=3Dru_RU
!ENTRY org.eclipse.osgi =CD=C1=CA 26, 2004 13:30:40.501
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.workbench" could =
not be found in the registry.
at =
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivat=
or.java:298)
at =
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:2=
56)
at =
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:1=
27)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
All other "Application name" settings inside "Command line settings" =
group works correctly.=20
What should I do to make "org.eclipse.ui.workbench" available "in the =
registry"?
br,
Vasily Smirnoff
Content-Type: text/html;
charset="koi8-r"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Dkoi8-r">
<META content=3D"MSHTML 5.50.4807.2300" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#f1f4fa>
<DIV><FONT face=3D"Lucida Sans Unicode" color=3D#000000 =
size=3D2>Hi!</FONT></DIV>
<DIV><FONT face=3D"Lucida Sans Unicode" color=3D#000000 size=3D2>After =
attempt to=20
launch my plugin inside run-time workspace I got following =
error:</FONT></DIV>
<DIV><FONT face=3D"Lucida Sans Unicode" color=3D#000000=20
size=3D2>eclipse.buildId=3Dunknown<BR>java.version=3D1.4.2 <BR>java.vendor=
=3DSun=20
Microsystems Inc.<BR>BootLoader constants: OS=3Dwin32, ARCH=3Dx86, =
WS=3Dwin32,=20
NL=3Dru_RU<BR>!ENTRY org.eclipse.osgi =CD=C1=CA 26, 2004 =
13:30:40.501<BR>!MESSAGE=20
Application error<BR>!STACK 1<BR>java.lang.RuntimeException: Application =
"org.eclipse.ui.workbench" could not be found in the =
registry.<BR>&nbsp;at=20
or.java:298)<BR>&nbsp;at=20
56)<BR>&nbsp;at=20
27)<BR>&nbsp;at=20
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<BR>&nbsp;at=20
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)<BR>&nbsp;at=20
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown =
java.lang.reflect.Method.invoke(Unknown Source)<BR>&nbsp;at=20
org.eclipse.core.launcher.Main.basicRun(Main.java:185)<BR>&nbsp;at=20
org.eclipse.core.launcher.Main.run(Main.java:638)<BR>&nbsp;at=20
org.eclipse.core.launcher.Main.main(Main.java:622)</FONT></DIV >
size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3D"Lucida Sans Unicode" color=3D#000000 size=3D2>All =
other=20
"Application name" settings inside "Command line settings" group works=20
correctly. </FONT></DIV>
<DIV><FONT face=3D"Lucida Sans Unicode" color=3D#000000 size=3D2>What =
should I do to=20
registry"?</FONT></DIV>
size=3D2>br,</FONT></DIV>
<DIV><FONT face=3D"Lucida Sans Unicode" color=3D#000000 size=3D2>Vasily=20
Smirnoff</FONT></DIV></BODY></HTML>
------=_NextPart_000_02E8_01C44326.398F7E20--
OT: Re: M9 not possible to launch Run-time workspace [message #245547 is a reply to message #245469] Wed, 26 May 2004 09:12 Go to previous messageGo to next message
Originally posted by: remove.this.tim.adler.at.bertelsmann.de
Off-Topic:
I got one simple question: Where can you see this exception-logging that
you are posting from here. I got the problem that one plugin is not
working properly, but Eclipse is not displaying any exceptions. I'm
searching for the spot where they are written to.
Can you help me??
Thx, Tim
Vasily Smirnov wrote:
> Hi!
> After attempt to launch my plugin inside run-time workspace I got following error:
> eclipse.buildId=unknown
> java.version=1.4.2
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ru_RU
> !ENTRY org.eclipse.osgi май 26, 2004 13:30:40.501
> !STACK 1
> java.lang.RuntimeException: Application "org.eclipse.ui.workbench" could not be found in the registry.
> at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:298)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:256)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
> All other "Application name" settings inside "Command line settings" group works correctly.
> What should I do to make "org.eclipse.ui.workbench" available "in the registry"?
> br,
> Vasily Smirnoff
Re: OT: Re: M9 not possible to launch Run-time workspace [message #245558 is a reply to message #245547] Wed, 26 May 2004 09:19 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
Help->About->Configuration Details shows log information
In the workspace .metadata/.log file as well.
Peter
Tim Adler wrote:
> Off-Topic:
> Can you help me??
> Thx, Tim
>> Hi!
>> following error:
>> java.version=1.4.2
>> !STACK 1
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> group works correctly. What should I do to make
>> br,
>> Vasily Smirnoff
Re: OT: Re: M9 not possible to launch Run-time workspace [message #245563 is a reply to message #245547] Wed, 26 May 2004 09:32 Go to previous messageGo to next message
You can veiw the log via Help->About->Configuration Details. The log
will also be in .metadata/.log. One other thing you can do is to pull up
the Error view from the PDE. Window >> Show View>>Other>>PDE
Runtime>>Error View. That way you can watch them all the time.
Rob
Tim Adler wrote:
> Off-Topic:
> Can you help me??
> Thx, Tim
>> Hi!
>> following error:
>> java.version=1.4.2
>> !STACK 1
>> at
>> at
>> at
>> br,
>> Vasily Smirnoff
Re: M9 not possible to launch Run-time workspace [message #245764 is a reply to message #245469] Wed, 26 May 2004 13:26 Go to previous messageGo to next message
me too.
---------------------- >8 -------
Hi Folks,
This is hopefully a simple problem but I'm stumped for where to start.
I've converted all the deprecated API's M8 -> M9 shift, however when the
runtime workbench starts the error below is reported.
Is there a $0.02c solution to this one; or an RTFM that I've missed?
Rich
!SESSION May 26, 2004 17:37:08.421
java.version=1.4.2_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
!ENTRY org.eclipse.osgi May 26, 2004 17:37:08.421
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench"
at
at
at
Re: M9 not possible to launch Run-time workspace [message #245856 is a reply to message #245764] Wed, 26 May 2004 17:12 Go to previous messageGo to next message
Vasily,
have you tried creating a new Run Configuration rather than using your
original one?
Having been through and created a fresh one I'm a little further on...
now I'm up to
Unhandled event loop exception
Reason:
Widget is disposed
Which I think is an improvement :-?
Rich
Re: M9 not possible to launch Run-time workspace [message #246089 is a reply to message #245856] Thu, 27 May 2004 04:43 Go to previous messageGo to next message
I'm used a new one. But I will try to recreate it again.
"rich boakes" <rich.boakes@port.ac.uk> wrote in message news:c930pu$ee7$3@eclipse.org...
> Vasily,
> original one?
> now I'm up to
> Reason:
> Widget is disposed
> Rich
Re: M9 not possible to launch Run-time workspace [message #246573 is a reply to message #245469] Thu, 27 May 2004 16:53 Go to previous messageGo to next message
------=_NextPart_000_00DC_01C4440B.30DB3D60
charset="koi8-r"
This looks like a really old launch configuration. It should be looking =
for org.eclipse.ui.ide.workbench as the application, not =
org.eclipse.ui.workbench. There have been some changes in PDE that =
require recreating launch configs from earlier 3.0 milestones. If you =
still have problems after recreating the launch config, please report a =
bug against PDE-UI.
When looking for a .log file, look in both <workspaceDir>/.metadata/.log =
and <installDir>/configuration/*.log (generated file name).
If Eclipse fails before it even creates the workspace, e.g. if it can't =
find the application, any log file it creates will go in the =
configuration dir.
Nick
"Vasily Smirnov" <Vasily.Smirnov@atbusiness.com> wrote in message =
news:c91nvu$h0j$1@eclipse.org...
Hi!
following error:
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.workbench" =
at =
or.java:298)
at =
56)
at =
27)
registry"?
br,
Vasily Smirnoff
charset="koi8-r"
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>This looks like a really old launch=20
configuration.&nbsp; It should be looking for =
org.eclipse.ui.ide.workbench as=20
the application, not org.eclipse.ui.workbench.&nbsp; There have been =
some=20
changes in PDE that require recreating launch configs from earlier 3.0=20
milestones.&nbsp; If you still have problems after recreating the launch =
config,=20
please report a bug against PDE-UI.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>When looking for a .log file, look in =
both=20
&lt;workspaceDir&gt;/.metadata/.log and =
&lt;installDir&gt;/configuration/*.log=20
(generated file name).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>If Eclipse fails before it even creates =
the=20
workspace, e.g. if it can't find the application, any log file it =
creates will=20
go in the configuration dir.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Nick</FONT></DIV>
<DIV>&nbsp;</DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Vasily Smirnov" &lt;<A=20
href=3D"mailto:Vasily.Smirnov@atbusiness.com">Vasily.Smirnov@atbusiness.c=
om</A>&gt;=20
wrote in message <A=20
href=3D"news:c91nvu$h0j$1@eclipse.org">news:c91nvu$h0j$1@eclipse.org</A>.=
...</DIV>
attempt to=20
error:</FONT></DIV>
=3DSun=20
WS=3Dwin32,=20
Application error<BR>!STACK 1<BR>java.lang.RuntimeException: =
Application=20
56)<BR>&nbsp;at=20
27)<BR>&nbsp;at=20
sun.reflect.NativeMethodAccessorImpl.invoke0(Native =
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown =
other=20
"Application name" settings inside "Command line settings" group works =
should I do to=20
size=3D2>Vasily=20
Smirnoff</FONT></DIV></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_00DC_01C4440B.30DB3D60--
Re: M9 not possible to launch Run-time workspace [message #246578 is a reply to message #246573] Thu, 27 May 2004 16:55 Go to previous message
------=_NextPart_000_00F4_01C4440B.70CD7AA0
charset="koi8-r"
Note that in the case of launching a run-time workbench from within a =
host eclipse, the configuration directory is in =
<hostWorkspace>/.metadata/.plugins/org.eclipse.pde.core/<subdirForYourLau=
nchConfig>.
Usually if something gets written here, though, PDE should tell you =
about it.
If it doesn't, that should also be reported since this location is so =
out of the way, mere mortals shouldn't be expected to find anything =
here.
Nick
"Nick Edgar" <nick_edgar@_no.spam.please_.ca.ibm.com> wrote in message =
news:c95k3v$nsl$1@eclipse.org...
This looks like a really old launch configuration. It should be =
looking for org.eclipse.ui.ide.workbench as the application, not =
bug against PDE-UI.
When looking for a .log file, look in both =
<workspaceDir>/.metadata/.log and <installDir>/configuration/*.log =
If Eclipse fails before it even creates the workspace, e.g. if it =
can't find the application, any log file it creates will go in the =
configuration dir.
Nick
Hi!
following error:
!STACK 1
at =
or.java:298)
at =
56)
at =
27)
What should I do to make "org.eclipse.ui.workbench" available "in =
the registry"?
br,
Vasily Smirnoff
charset="koi8-r"
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Note that in the case of launching a =
run-time=20
workbench from within a host eclipse, the configuration directory is in=20
&lt;hostWorkspace&gt;/.metadata/.plugins/org.eclipse .pde.core/&lt;subdirF=
orYourLaunchConfig&gt;.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Usually if something gets written here, =
though, PDE=20
should tell you about it.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>If it doesn't, that should also be =
reported since=20
this location is so out of the way, mere mortals shouldn't be expected =
to find=20
anything here.</FONT></DIV>
<DIV>"Nick Edgar" &lt;<A=20
href=3D"mailto:nick_edgar@_no.spam.please_.ca.ibm.com">nick_edgar@_no.spa=
m.please_.ca.ibm.com</A>&gt;=20
href=3D"news:c95k3v$nsl$1@eclipse.org">news:c95k3v$nsl$1@eclipse.org</A>.=
...</DIV>
some=20
changes in PDE that require recreating launch configs from earlier 3.0 =
milestones.&nbsp; If you still have problems after recreating the =
launch=20
config, please report a bug against PDE-UI.</FONT></DIV>
both=20
<DIV><FONT face=3DArial size=3D2>If Eclipse fails before it even =
creates the=20
creates will=20
<DIV>&nbsp;</DIV>
om</A>&gt;=20
...</DIV>
size=3D2>After attempt to=20
launch my plugin inside run-time workspace I got following=20
error:</FONT></DIV>
=3DSun=20
WS=3Dwin32,=20
Application=20
56)<BR>&nbsp;at=20
27)<BR>&nbsp;at=20
other=20
"Application name" settings inside "Command line settings" group =
works=20
size=3D2>What should I do=20
size=3D2>Vasily=20
Smirnoff</FONT></DIV></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML >
------=_NextPart_000_00F4_01C4440B.70CD7AA0--
Previous Topic:Can i change the view of eclipse
Next Topic:FAQ: "It's in the <ABC> FAQ"
Current Time: Sat Nov 08 16:36:30 EST 2025
Powered by FUDForum. Page generated in 0.05002 seconds
