Home » Eclipse Projects » GEF » A few questions on Zest
A few questions on Zest [message #246567] Sun, 14 December 2008 07:32 Go to next message
Originally posted by: zzhangh.cn.ibm.com
Hi all,
I got a few questions while using Zest as below,
1. How to use custom figure for GraphNodes (not tooltips, but the nodes themselves)
2. After a graph has been created, how to show/hide texts on the nodes (I tried GraphNode#setNodeStyle(), but the graph
was not updated)
Thanks in advance!
Hao
Re: A few questions on Zest [message #246572 is a reply to message #246567] Sun, 14 December 2008 22:26 Go to previous messageGo to next message
Originally posted by: lifesting.gmail.com
Hao Zhang wrote:
> Hi all,
> was not updated)
> Thanks in advance!
> Regards,
> Hao
1. Every GraphNode has a GraphLabel as its figure, so if you use Zest
Viewer(JFace style), specify a image in the viewer's labelprovider or
directly set the image for GrahpNode through invoking its method
*setImage* (SWT style)
viewer = new GraphViewer(shell, SWT.NONE);
viewer.setContentProvider(new MyContentProvider());
viewer.setLabelProvider(new MyLabelProvider(){
public Image getImage(Object element) {
return custom_image;
Graph g = new Graph(shell, SWT.NONE);
GraphNode n = new GraphNode(g, SWT.NONE, "David");
n.setImage(image);
2 Because figure is GraphLabel, you can simply do it like below:
Hide:
node.setText("");
//update node style
node.setNodeStyle(n.getNodeStyle() | ZestStyles.NODES_HIDE_TEXT);
Show:
node.setText("New Text");
node.setNodeStyle(n.getNodeStyle() & ~ZestStyles.NODES_HIDE_TEXT);
Hope this help you!
BTW: are you the famous IBM CSDL fellow Zhang Hao?
Re: A few questions on Zest [message #246577 is a reply to message #246572] Mon, 15 December 2008 05:05 Go to previous messageGo to next message
Hi David,
For the show/hide question your suggestion worked, thanks!
However, for the other one, what I wanted is to use a custom IFigure other than an Image, is there any solution? Do I
have to write my own GraphNode?
P.S. I'm not the fellow...
Hao
David BY Chan wrote:
> Hao Zhang wrote:
>> Hi all,
>> was not updated)
>> Thanks in advance!
>> Regards,
>> Hao
> n.setImage(image);
> Hide:
> node.setText("");
> //update node style
> Show:
> Hope this help you!
Re: A few questions on Zest [message #246582 is a reply to message #246577] Mon, 15 December 2008 22:21 Go to previous message
yes, write an extended GraphNode and override its method
createFigureForModel, where substitute your figure for GraphLabel.
More details you'd better read the source code of Zest.
Hao Zhang wrote:
> Hi David,
> Regards,
> Hao
>> Hao Zhang wrote:
>>> Hi all,
>>> was not updated)
>>> Thanks in advance!
>>> Regards,
>>> Hao
>> n.setImage(image);
>> Hide:
>> node.setText("");
>> //update node style
>> Show:
>> Hope this help you!
Previous Topic:Question about creating a new Plug-in
Next Topic:Layer question
Current Time: Wed Nov 12 11:44:56 EST 2025
Powered by FUDForum. Page generated in 0.03609 seconds
