| Find the IType for a class [message #246497] |
Fri, 03 August 2007 00:20  |
Originally posted by: rupinder10.gmail.com
I am trying to write a plugin that needs its launcher to extend the
JUnitLaunchConfiguration. Unfortunately, the JUnitLaunchConfiguration uses
project.findType(className)
to the IType of the test class to be launched. In my case the test class
I want to launch is not a part of the project but is in the plugin jar.
Is there a way for me to get to the IType if the class file is in the
plugin and not the java project ?
| Re: Find the IType for a class [message #246526 is a reply to message #246521] |
Sat, 04 August 2007 05:13   |
If the class file is on the plugins classpath, then PDE should have put the
corresponding jar file on your project classpath through the PDE Container
and so, you should see this jar under the 'Plug-in Dependencies' folder in
the Package Explorer... Can you see it there?
If you do not see it, then I assume that the nature of your project is not
correct. What kind of nature did you intend to apply to your project:
Java, Plug-in, other?
Rupinder wrote:
> You are correct about the fact that project.findType does find the
> classes in the project. But in my case, the class file is not on the
> project's classpath but is in the plugins classpath.
> The project just has an XML file. What I am trying to do is that when
> the use right click's the file to run it (yes run an XML file) the
> plugin should use the XML file to create test cases and run them. The
> actual test class is on the plugin's classpath and I dont want the users
> to have to unnecessarily include jar files in their project because they
> are not writing java code.
> Frederic Fusier wrote:
>> The IJavaProject.findType(String) method should find any type which is on
>> the project classpath. So, if your jar is on your project classpath
>> (it should
>> be the case, I guess), then you could use this method to find any type
>> in it.
>> If you cannot find a type in your jar although it is on your
>> classpath, then
>> first verify that the given name is well qualified or that it is not a
>> secondary
>> type (see javadoc comment of the method). If the given parameter is
>> correct
>> then open a bug against JDT/Core component with a detailed description
>> of your
>> project configuration, the jar file containing the type you're trying
>> to find
>> using this method, thanks
>>> uses
>>> class I want to launch is not a part of the project but is in the
>>> plugin jar. Is there a way for me to get to the IType if the class
>>> file is in the plugin and not the java project ?
| Re: Find the IType for a class [message #246745 is a reply to message #246526] |
Sat, 11 August 2007 22:51   |
I do not see it on the Plug-in Dependencies folder. But I guess that is
because I am planning to use the Java nature.
>> users to have to unnecessarily include jar files in their project
>> because they are not writing java code.
>>> is on
>>> (it should
>>> type in it.
>>> classpath, then
>>> a secondary
>>> correct
>>> description of your
>>> to find
| Re: Find the IType for a class [message #246749 is a reply to message #246745] |
Sun, 12 August 2007 05:08  |
So if you are using a Java Nature, what did you mean by "The actual test class is on the plugin's classpath" ?
>> put the
>> Container
>> folder in
>> not
>>>> is on
>>>> (it should
>>>> type in it.
>>>> classpath, then
>>>> a secondary
>>>> correct
>>>> description of your
>>>> trying to find
FUDForum. Page generated in 0.06994 seconds
