Home » Archived » BIRT » BIRT 2.2 create an example at start ...
BIRT 2.2 create an example at start ... [message #246133] Tue, 03 July 2007 10:14 Go to next message
Originally posted by: nico.aol.com
I used BIRT 2.1.1 and I install recently BIRT 2.2.
When I create the Engine with the Report Engine API, an example is
created, you can see the log:
BIRT - Platform.startup
3 juil. 2007 13:24:42
org.eclipse.birt.report.data.oda.sampledb.SampledbPlugin start
INFO: Sampledb plugin starts up. Current startCount=0
org.eclipse.birt.report.data.oda.sampledb.SampledbPlugin init
INFO: Creating Sampledb database at location
/tmp/BIRTSampleDB_1183469082702_1b5c22f
BIRT - Platform.createFactoryObject
What is "/tmp/BIRTSampleDB_1183469082702_1b5c22f"?
Thank you
Re: BIRT 2.2 create an example at start ... [message #246144 is a reply to message #246133] Tue, 03 July 2007 10:29 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Nico,
This is the sample derby database.
Jason
Nico wrote:
> Hello,
> Thank you
Re: BIRT 2.2 create an example at start ... [message #246148 is a reply to message #246144] Tue, 03 July 2007 10:41 Go to previous messageGo to next message
Ok, thank you for the wuisk answer.
Can I disabled? And how?
Nico
Re: BIRT 2.2 create an example at start ... [message #246160 is a reply to message #246148] Tue, 03 July 2007 12:06 Go to previous messageGo to next message
You can remove the sampledb plugin.
Jason
> Nico
Re: BIRT 2.2 create an example at start ... [message #246252 is a reply to message #246160] Wed, 04 July 2007 03:39 Go to previous message
Ok, thank you :)
Previous Topic:Xerces exception after using BIRT engine
Next Topic:2.1 -> 2.2 migration
Current Time: Sun Jul 20 22:25:18 EDT 2025
Powered by FUDForum. Page generated in 0.06835 seconds
