Home » Eclipse Projects » Nebula » CompositeTable
CompositeTable [message #24196] Wed, 24 January 2007 13:33 Go to next message
Hello all.
Is it possible to re-order the columns of a composite table?
Ali.
Re: CompositeTable [message #24615 is a reply to message #24196] Thu, 25 January 2007 22:32 Go to previous message
Short answer: I'm working on a simple API to enable this right now.
Longer answer: You can do pretty much whatever you want using
CompositeTable, but you might have to code it yourself. CompositeTable
is very extensible. It's default API is also very low-level. However,
there are optional components added on top of the API to enable common
use-cases easily. I suggest reading through the snippets to get an idea
of what I mean.
Dave Orme
Re: CompositeTable [message #575885 is a reply to message #24196] Thu, 25 January 2007 22:32 Go to previous message
of what I mean.
Dave Orme
Previous Topic:New Nebula Presentation Component...
Next Topic:Example of MonthCalendar
Current Time: Wed Sep 03 04:48:14 EDT 2025
Powered by FUDForum. Page generated in 0.29401 seconds
