Home » Eclipse Projects » Eclipse Platform » EXCEPTION_ACCESS_VIOLATION
EXCEPTION_ACCESS_VIOLATION [message #245363] Wed, 26 May 2004 01:23 Go to next message
Originally posted by: john.starfriend.net
Eclipse doesn't fire up any more. I don't know what has changed - it used
to run fine. Other Java programs work ok.
Any help would be very much appreciated.
Here is the log output:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x77F83378
Function=RtlInitUnicodeString+0x1B
Library=C:\WINNT\system32\ntdll.dll
Current Java thread:
at org.eclipse.swt.internal.win32.OS.ExpandEnvironmentStringsW( Native
Method)
at
org.eclipse.swt.internal.win32.OS.ExpandEnvironmentStrings(O S.java:1353)
at org.eclipse.swt.program.Program.getKeyValue(Program.java:113 )
at org.eclipse.swt.program.Program.getProgram(Program.java:135)
at org.eclipse.swt.program.Program.getPrograms(Program.java:165 )
at
org.eclipse.ui.internal.registry.EditorDescriptor.findProgra m(EditorDescriptor.java:76)
at
org.eclipse.ui.internal.registry.EditorDescriptor.loadValues (EditorDescriptor.java:212)
at
org.eclipse.ui.internal.registry.EditorRegistry.loadAssociat ions(EditorRegistry.java:521)
at
org.eclipse.ui.internal.registry.EditorRegistry.initializeFr omStorage(EditorRegistry.java:453)
at
org.eclipse.ui.internal.registry.EditorRegistry.<init>(EditorRegistry.java:64)
at
org.eclipse.ui.internal.WorkbenchPlugin.getEditorRegistry(Wo rkbenchPlugin.java:234)
at org.eclipse.ui.internal.EditorManager$7.run(EditorManager.ja va:908)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:864)
at org.eclipse.ui.internal.EditorManager$6.run(EditorManager.ja va:857)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:853)
at
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:756)
at
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2263)
at
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1327)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1263)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 223)
at org.eclipse.ui.internal.Workbench$12.run(Workbench.java:1141 )
at
at
org.eclipse.ui.internal.Workbench.openPreviousWorkbenchState (Workbench.java:1093)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:870)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
at
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Dynamic libraries:
0x00400000 - 0x00407000 C:\WINNT\system32\javaw.exe
0x77F80000 - 0x77FFD000 C:\WINNT\system32\ntdll.dll
0x7C2D0000 - 0x7C332000 C:\WINNT\system32\ADVAPI32.dll
0x7C570000 - 0x7C628000 C:\WINNT\system32\KERNEL32.DLL
0x77D30000 - 0x77DA1000 C:\WINNT\system32\RPCRT4.DLL
0x77E10000 - 0x77E75000 C:\WINNT\system32\USER32.dll
0x77F40000 - 0x77F7E000 C:\WINNT\system32\GDI32.DLL
0x78000000 - 0x78045000 C:\WINNT\system32\MSVCRT.dll
0x08000000 - 0x08136000 C:\Program
Files\Java\j2re1.4.2_01\bin\client\jvm.dll
0x77570000 - 0x775A0000 C:\WINNT\system32\WINMM.dll
0x681A0000 - 0x681A7000 C:\WINNT\system32\serwvdrv.dll
0x66740000 - 0x66747000 C:\WINNT\system32\umdmxfrm.dll
0x6BD00000 - 0x6BD0D000 C:\WINNT\system32\SYNCOR11.DLL
0x10000000 - 0x10007000 C:\Program Files\Java\j2re1.4.2_01\bin\hpi.dll
0x007E0000 - 0x007EE000 C:\Program Files\Java\j2re1.4.2_01\bin\verify.dll
0x007F0000 - 0x00808000 C:\Program Files\Java\j2re1.4.2_01\bin\java.dll
0x00810000 - 0x0081D000 C:\Program Files\Java\j2re1.4.2_01\bin\zip.dll
0x34A40000 - 0x34A48000
C:\eclipse\plugins\org.eclipse.core.resources.win32_2.1.0\os \win32\x86\core_2_1_0a.dll
0x34B60000 - 0x34BA7000
C:\eclipse\plugins\org.eclipse.swt.win32_2.1.1\os\win32\x86\ swt-win32-2135.dll
0x77A50000 - 0x77B3F000 C:\WINNT\system32\ole32.dll
0x71710000 - 0x71794000 C:\WINNT\system32\COMCTL32.dll
0x76B30000 - 0x76B6E000 C:\WINNT\system32\comdlg32.dll
0x70A70000 - 0x70AD5000 C:\WINNT\system32\SHLWAPI.DLL
0x782F0000 - 0x78538000 C:\WINNT\system32\SHELL32.DLL
0x779B0000 - 0x77A4B000 C:\WINNT\system32\OLEAUT32.dll
0x75E60000 - 0x75E7A000 C:\WINNT\system32\IMM32.dll
0x350D0000 - 0x351A4000 C:\WINNT\system32\nView.dll
0x690A0000 - 0x690AB000 C:\WINNT\system32\PSAPI.DLL
0x77820000 - 0x77827000 C:\WINNT\system32\VERSION.dll
0x759B0000 - 0x759B6000 C:\WINNT\system32\LZ32.DLL
0x695E0000 - 0x69609000 C:\WINNT\system32\OLEPRO32.DLL
0x72800000 - 0x72846000 C:\WINNT\system32\DDRAW.dll
0x728A0000 - 0x728A6000 C:\WINNT\system32\DCIMAN32.dll
0x35720000 - 0x35727000 C:\Program
Files\Logitech\MouseWare\System\LgWndHk.dll
0x35730000 - 0x35744000 C:\freeserve\freeserveconnectionkit\Freehook.dll
0x35770000 - 0x357A1000 C:\Program Files\TextBridge Pro
Millennium\Bin\TBMHOOK.dll
0x719B0000 - 0x719B8000 C:\WINNT\system32\SHFOLDER.dll
0x77800000 - 0x7781E000 C:\WINNT\system32\WINSPOOL.DRV
0x76620000 - 0x76630000 C:\WINNT\system32\MPR.DLL
0x69640000 - 0x6965F000 C:\WINNT\system32\oleacc.dll
0x77920000 - 0x77943000 C:\WINNT\system32\imagehlp.dll
0x72A00000 - 0x72A2D000 C:\WINNT\system32\DBGHELP.dll
Heap at VM Abort:
Heap
def new generation total 576K, used 416K [0x10010000, 0x100b0000,
0x12770000)
eden space 512K, 71% used [0x10010000, 0x1006b818, 0x10090000)
from space 64K, 79% used [0x100a0000, 0x100acb78, 0x100b0000)
to space 64K, 0% used [0x10090000, 0x10090000, 0x100a0000)
tenured generation total 2472K, used 2356K [0x12770000, 0x129da000,
0x30010000)
the space 2472K, 95% used [0x12770000, 0x129bd160, 0x129bd200,
0x129da000)
compacting perm gen total 7168K, used 7159K [0x30010000, 0x30710000,
0x34010000)
the space 7168K, 99% used [0x30010000, 0x3070ddd0, 0x3070de00,
0x30710000)
Local Time = Wed May 26 06:08:48 2004
Elapsed Time = 14
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_01-b06 mixed mode)
John Pedersen
Re: EXCEPTION_ACCESS_VIOLATION [message #245552 is a reply to message #245363] Wed, 26 May 2004 09:15 Go to previous messageGo to next message
Hi John,
This has been fixed in the 3.0 stream. The reports for it (including the
perceived causes, which are likely of interest to you if you can't upgrade
to 3.0) are:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=40884
https://bugs.eclipse.org/bugs/show_bug.cgi?id=47279
Grant
"John Pedersen" <john@starfriend.net> wrote in message
news:c919jk$r6d$1@eclipse.org...
> PC=0x77F83378
> Method)
> at
> at
or.java:76)
> at
r.java:212)
> at
try.java:521)
> at
Registry.java:453)
> at
4)
> at
va:234)
> at
:1006)
> at
64)
> at
> at
> at
> at
27)
> at
:1006)
> at
1093)
> at
a:858)
> Dynamic libraries:
2_1_0a.dll
ll
> Heap at VM Abort:
> Heap
> 0x12770000)
> 0x30010000)
> 0x129da000)
> 0x34010000)
> 0x30710000)
> Elapsed Time = 14
> John Pedersen
Re: EXCEPTION_ACCESS_VIOLATION [message #246703 is a reply to message #245552] Fri, 28 May 2004 01:55 Go to previous message
Thanks Grant - I am moving to Linux anyway - maybe that will help!
Strange that Ecpipse has been working just fine for months.
John
Previous Topic:Ant build for simple JFace project
Next Topic:Unable to build M9 from sources
Current Time: Sun Jul 27 14:08:40 EDT 2025
Powered by FUDForum. Page generated in 0.04790 seconds
