Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Issues on "A guide to building a DLTK-based language IDE"
Issues on "A guide to building a DLTK-based language IDE" [message #2455] Tue, 08 May 2007 08:46 Go to next message
I've read http://wiki.eclipse.org/index.php/DLTK_IDE_Guide and have tried to
repeat all steps in Eclipse.
First of all, which version of DLTK must be used 0.8 or 1.0? I guess 0.8 but
there is no mention about it. I installed 0.8 from
http://download.eclipse.org/technology/dltk/updates/0.8/site -interim.xml
update site.
Well, here some inaccuracies I've found:
1. Creating core plugin.
Original: To create core plugin lets select do New->Plug-in Project: set
name org.eclipse.dltk.examples.python.
Fix: org.eclipse.dltk.examples.python.core
2. Creating a simple Language Toolkit
Original: In extensions tab we need to create org.eclipse.dltk.core.languege
Fix: org.eclipse.dltk.core.language
3. Creating source element parser
Original: Lets create class PythonSourceElementParser which implements
ISourceElementpParser interface
Fix: ISourceElementParser
And the main point where I've stuck is PythonSourceElementParser code
snippet. There is unknown PythonSourceParser class is used. Where I can find
its definition?
Best Regards,
Sergey Gomanyuk.
Re: Issues on "A guide to building a DLTK-based language IDE" [message #2486 is a reply to message #2455] Thu, 10 May 2007 05:47 Go to previous messageGo to next message
Hi Sergey,
Thanks for fixes.
I've updated demo. For now it uses latest integration and Eclipse 3.3M7.
PythonSourceParser class are in org.eclipse.dltk.examples.python.core
project. org.eclipse.dltk.examples.python.parser package.
> update site.
> its definition?
> Best Regards,
> Sergey Gomanyuk.
Re: Issues on "A guide to building a DLTK-based language IDE" [message #2516 is a reply to message #2486] Thu, 10 May 2007 06:55 Go to previous messageGo to next message
Hi, again!
My current configuration:
Eclipse 3.3 M7
Latest DLTK from
http://download.eclipse.org/technology/dltk/updates/1.0/site -interim.xml
And Python example project sources from
http://us.xored.com/~haiodo/org.eclipse.dltk.examples.python .zip
The problem is:
org.eclipse.dltk.examples.python.ui and core each has compilation errors
for ex:
project org.eclipse.dltk.examples.python.ui:
The return type is incompatible with
ProjectWizardFirstPage.getInterpreterGroupObservable()
org.eclipse.dltk.examples.python.ui/src/org/eclipse/dltk/exa mples/python/ui/wizards
PythonProjectCreationWizard.java line 49
project org.eclipse.dltk.examples.python.core:
Type mismatch: cannot convert from Statement to Expression
org.eclipse.dltk.examples.python.core/src/org/eclipse/dltk/e xamples/python/parser
PythonSourceElementRequestor.java line 224
Sergey Gomanyuk
Re: Issues on "A guide to building a DLTK-based language IDE" [message #2546 is a reply to message #2516] Thu, 10 May 2007 09:00 Go to previous message
Hi Sergey,
You are right,
We will make correct integration today, or you can checkout latest code
from CVS.
Andrei.
> Hi, again!
> Eclipse 3.3 M7
> Latest DLTK from
> The problem is:
> for ex:
> Sergey Gomanyuk
Previous Topic:ASTNode - Expression/Statement suggestion
Next Topic:Editor: Double Quoting
Current Time: Thu Jul 17 22:31:30 EDT 2025
Powered by FUDForum. Page generated in 0.05758 seconds
