Home » Eclipse Projects » GEF » strange zest rendering in RCP?
strange zest rendering in RCP? [message #245467] Fri, 12 September 2008 04:13 Go to next message
I am getting stsrted with Zest and have a simple 'HelloWorld' RCP with a
zest graphviewer, which should display a small data atructure that is set
as the input. When I run the app, I should see 4 edges and 5 nodes, but
often edges or nodes are missing. When I step through the debugger to see
what's going on it all looks fine and the graph is displayed correctly.
I can only think there's some sort of threading issuw with the display -
I'm using Ganymede 3.4.0 on Windows XP
All the 'graphsnippet' examples work fine.
We are really keen to use Zest in our project, it's exactly what we were
looking for, apart from this bug.
Would be really grateful if anyone has any ideas how this might be
happening
Richard
Re: strange zest rendering in RCP? [message #245505 is a reply to message #245467] Mon, 15 September 2008 23:26 Go to previous messageGo to next message
Originally posted by: irbull.cs.uvic.ca
Is it deterministic? (i.e. if you run the app twice in a row, do the
number of nodes / edges change)?. Are you using the JFace Viewers or
simply the Zest graph widget?
cheers,
ian
Richard Adams wrote:
> set as the input. When I run the app, I should see 4 edges and 5 nodes,
> but often edges or nodes are missing. When I step through the debugger
> to see what's going on it all looks fine and the graph is displayed
> correctly. I can only think there's some sort of threading issuw with
> the display - I'm using Ganymede 3.4.0 on Windows XP
> happening
> Thanks
> Richard
Re: strange zest rendering in RCP? [message #245509 is a reply to message #245505] Tue, 16 September 2008 04:09 Go to previous messageGo to next message
Hi Ian
Thanks for your reply.
I have discovered that it only seems to happen when the view appears
from application startup. I have added a Window->ShowView action to the
menubar, and if I close the graphview, and reopen it, the graph appears
fine.
The model is 4 source nodes connected to a central destination node
Node1
Node2 ----> CentralNode<------Node 3
Node4
When running from start up, the central node, 1 edge, and and 1 source
node appear in the view, and another node with a self edge but no label.
Two nodes are missing completely. I.e.,
A node -------------> CentralNode
Another_unconnected_node
This is actually pretty consistent - so the central node always appears,
and 2 others.
This is using the 'GraphViewer' class in a custom view class that extends
ViewPart, and is contributed via the plugin.xml, in exactly the same way
as the
'Hello World' RCP view.
Cheers
Richard
Re: strange zest rendering in RCP? [message #245631 is a reply to message #245509] Fri, 19 September 2008 17:42 Go to previous message
Can you open a bug for this? Now that I think about it, there may be
some threading on startup. (I check to see if the canvas is visible
before I try and compute the bounds, and if the canvas is not visible, I
add a callback). I wonder if this is causing some problems.
cheers,
ian
> Hi Ian
> fine.
> Node1
> Node4
> and 2 others.
> extends ViewPart, and is contributed via the plugin.xml, in exactly the
> same way as the 'Hello World' RCP view.
> Cheers
> Richard
Previous Topic:Is it possible to provide a Screen Capture functionality in GEF editors?
Next Topic:[Zest] How to set a ConnectionRouter
Current Time: Fri Nov 07 07:02:37 EST 2025
Powered by FUDForum. Page generated in 0.04510 seconds
