Home » Eclipse Projects » GEF » Routing Style ..
Routing Style .. [message #244999] Tue, 19 August 2008 11:47 Go to next message
Originally posted by: annamalai.ancitconsulting.com
Dear all
i would like to perform something like the Routing Style available in the
GMF Editor ... Rectilinear or Oblique etc.
How do i do it in GEF Editor ? Any help would be appreciated.
Malai
Re: Routing Style .. [message #245048 is a reply to message #244999] Thu, 21 August 2008 00:03 Go to previous messageGo to next message
GMF ObliqueRouter is derived from BendpointConnectionRouter. So you should
use it or your own extension of it with a GEF editor
GMF RectilinearRouter corresponds to ManhattanConnectionRouter.
Alex
Re: Routing Style .. [message #245079 is a reply to message #245048] Fri, 22 August 2008 02:59 Go to previous messageGo to next message
Dear Alex
Thanks for your reply .. i checkedout the code for ObliqueRouter from GMF
internal draw2d ... And added to my package ...
I tried to use it in Shapes Editor by commenting the
ShortestPathRouterConnection and also applying the routing stuff in the
ConnectionEditPart ...
And i dont see any output change ... can you please explain ... where do i
need to change to get the routing algo working.
malai
"Alex Boyko" <aboyko@ca.ibm.com> wrote in message
news:e8cd639b6a27bb6ca6aa82647bcdd564$1@www.eclipse.org...
> Cheers,
> Alex
Re: Routing Style .. [message #245084 is a reply to message #245079] Thu, 21 August 2008 23:26 Go to previous messageGo to next message
GMF ObliqueRouter and GEF BendpointConnectionRouter are very similar in
terms of the output connection look.
Differences in GMF ObliqueRouter are:
1) It handles routing around obstruction for a connection
2) Routes separately connection where source == target and where source
and target intersect
3) Ignores bendpoints inside source and target shapes
So, what are your expectations of GMF's ObliqueRouter in GEF? Perhaps, the
behavior you're looking for can be implemented elsewhere... on connection
anchors, or using a different bendpoint constraints...?
Alex
Re: Routing Style .. [message #245087 is a reply to message #245084] Fri, 22 August 2008 12:07 Go to previous messageGo to next message
Dear Alex
Thanks for your reply once again ... Ok my expected output is ... when two
lines cross each other one of them needs to jump on the other line ... like
in GMF
If could be a Circular Jump or a Rectangular Jump ... So hope ObliqueRouter
helps me do this ... :)
Ok i get this .. ObliqueRouter helps in connecting the source to itself
again ... :) Hope this understanding is correct now ...
Me really confused with so many classes in GEF but the Framework is
amazingly good.
Thank you very much .. awaiting your reply.
Malai
news:f3e7a371d24809084b796796ba020728$1@www.eclipse.org...
> Cheers,
> Alex
Re: Routing Style .. [message #245098 is a reply to message #245087] Thu, 21 August 2008 23:56 Go to previous messageGo to next message
Those are called "Jump Links" in GMF. Jump Link is a concept defined on
PolylineConnectionEx class in GMF, not on the router.
Alex
Re: Routing Style .. [message #245118 is a reply to message #245098] Sat, 23 August 2008 01:25 Go to previous messageGo to next message
Dear Alex
Thanks for your patiently reply .. Now can i get some pointer on how to use
or implement these Jump Links in GEF ..
This is my requirement now .. i need to be able to jump the intersection of
links ...
Hoping to get some reply ..
Malai
news:7dc2b40867f62280c31c4ec8891f9d75$1@www.eclipse.org...
> Cheers,
> Alex
Re: Routing Style .. [message #246371 is a reply to message #245118] Wed, 26 November 2008 09:05 Go to previous message
Hi Malai,
Jump link in GEF can be achived by using PolylineConnectionEx
class from GMF org.eclipse.gmf.runtime.draw2d.ui plugin.
Niranjan Babu
Previous Topic:3 editparts getting data from 3 different Models need to be displayedon one Root
Next Topic:The examples issue.
Current Time: Sat Jul 19 03:52:03 EDT 2025
Powered by FUDForum. Page generated in 0.04641 seconds
