Home » Eclipse Projects » GEF » GEF editor background image
GEF editor background image [message #244844] Mon, 11 August 2008 08:06 Go to next message
Originally posted by: sumncc.gmail.com
Hi , every one. I have tried to set Background image on the editor by
modifying the paint method at Venueditpart(createfigur method). This
works fine but when I am drawing components I can not see them as the
layer has been over draw by the image.
Is there any way I can set the layer to the components or the anything
with image which will solve this problem.
Please..
Thanks.
RAJ
Re: GEF editor background image [message #244873 is a reply to message #244844] Mon, 11 August 2008 21:26 Go to previous message
> Please..
> Thanks.
> RAJ
Put the image on the last(bottom) layer which you need create, because
any layer above is transparent. e.g:
overwrite org.eclipse.gef.editparts.ScalableFreeformRootEditPart
protected ScalableFreeformLayeredPane createScaledLayers() {
ScalableFreeformLayeredPane pane = super.createScaledLayers();
pane.add(new BackgroundLayer(),"BACKGROUND_IMG");
return layers;
on EditPart:
public void addNotify() {
IFigure bg_figure = ...
getLayer("BACKGROUND_IMG").add(bg_figure);
super.addNotify();
Previous Topic:How to get the actual size of the Figure whose children can been added?
Next Topic:ZoomManager Looses Center
Current Time: Fri Jul 18 05:38:15 EDT 2025
Powered by FUDForum. Page generated in 0.08395 seconds
