Home » Language IDEs » Java Development Tools (JDT) » Task Tags
Task Tags [message #244325] Thu, 07 June 2007 11:12 Go to next message
Originally posted by: ericaramsey1.gmail.com
Hello, I do I setup Tasks to be Case Sensitive? I went to "project
properties"->"Java Compiler"->"Task Tags" and I set it to case sensitive.
Then I went to preferences"->"Java Compiler"->"Task Tags" and set it to case
sensitive. But entries, for example "import java.todo", that are not TODO
tags are still up as TODO Tags. I know that I can simply go to Task window
and delete them but this is so inconvenient.
Also, I defined my own tag called "DELETE-THIS" but when I enter it in a
comment, // DELETE-THIS: remove this code after testing complete , it
doesn't appear in the Task window and it doesn't show up as bold text like
the "TODO" task tag does.
Well, I hope that someone out there can help me!
Sincerely,
EARamsey
Re: Task Tags [message #244332 is a reply to message #244325] Thu, 07 June 2007 11:19 Go to previous message
Could you please specify your Eclipse build?
Enter a bug report against JDT/Core with required informations and steps
to reproduce.
Olivier
Previous Topic:Is there a way to force annotation processor to run on a file?
Next Topic:Find dependencies of a binary IType
Current Time: Mon Nov 03 13:26:34 EST 2025
Powered by FUDForum. Page generated in 0.03662 seconds
