Home » Newcomers » Newcomers » Error in web.xml in Eclipse
Error in web.xml in Eclipse [message #244308] Mon, 31 December 2007 03:07 Go to next message
Originally posted by: Abel.MacAdam.eden.invalid
While I'm learning the ropes of Struts (and Eclipse) I sometimes see
errors that make me scratch my head. I learn Struts using a book [1]. I
use code from this book which I downloaded from the Internet. The last
error in web.xml Eclipse is signaling has confounded me.
The error is:
The content of element type "web-app" must match
" (icon?,display-name?,description?,distributable?,context-par am*,filter*,filter-mapping*,listener*,servlet*,servlet-mappi ng*,session-config?,mime-mapping*,welcome-file-list?,error-p age*,taglib*,resource-env-ref*,resource-ref*,security-constr aint*,login-config?,security-role*,env-entry*,ejb-ref*,ejb-l ocal-ref*) ". app15a/WEB-INF web.xml line
4 1198847441457 264
I checked this web.xml with previous ones, and could not find any fault.
Anyway, this is the xml file
<!DOCTYPE web-app PUBLIC "-//Sun Microsystems, Inc.//DTD Web Application
2.3//EN"
"http://java.sun.com/dtd/web-app_2_3.dtd">
<web-app> <!-- Eclipse says the error is on this line -->
<listener>
<listener-class>app15a.listener.AppListener</listener-class >
</listener>
<context-param>
<param-name>dbType</param-name>
<param-value>mySQL</param-value>
</context-param>
<servlet>
<servlet-name>action</servlet-name>
<servlet-class>org.apache.struts.action.ActionServlet</servlet-class >
<init-param>
<param-name>config</param-name>
<param-value>/WEB-INF/struts-config.xml</param-value>
</init-param>
<init-param>
<param-name>debug</param-name>
<param-value>2</param-value>
</init-param>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>*.do</url-pattern>
</servlet-mapping>
<taglib>
<taglib-uri>/tags/struts-html</taglib-uri>
<taglib-location>/WEB-INF/struts-html.tld</taglib-location >
</taglib>
</web-app>
Anyone know what the cause is of this error?
TIA,
Abel
[1] Struts Design and Programming, a Tutorial.
Re: Error in web.xml in Eclipse [message #244344 is a reply to message #244308] Mon, 31 December 2007 08:29 Go to previous message
Abel,
I really don't have a clue, but based on the error message, I could
imagine that your context-param is perhaps required to appear before
your listener.
Abel MacAdam wrote:
> I use code from this book which I downloaded from the Internet. The
> last error in web.xml Eclipse is signaling has confounded me.
> The error is:
> app15a/WEB-INF web.xml line 4 1198847441457 264
> fault. Anyway, this is the xml file
> Application 2.3//EN" "http://java.sun.com/dtd/web-app_2_3.dtd">
> <listener>
> </listener>
> <context-param>
> </context-param> <servlet>
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> </servlet>
> <servlet-mapping>
> </servlet-mapping>
> <taglib>
> </taglib>
> </web-app>
> TIA,
> Abel
Previous Topic:How to get workspace path?
Next Topic:Annoying problem with eclipse (white strange forms)
Current Time: Fri Sep 19 15:56:48 EDT 2025
Powered by FUDForum. Page generated in 0.08106 seconds
