Home » Archived » OHF » new Audit calls on the bridge
new Audit calls on the bridge [message #24403] Wed, 22 November 2006 16:34 Go to next message
Originally posted by: eishays.us.ibm.com
The calls are:
AuditPhiImport AuditPhiExport AuditActorStartEvent AuditActorStopEvent
AuditUserAuthenticationLoginEvent AuditUserAuthenticationLogoutEvent
See the http://wiki.eclipse.org/index.php/OHF_Bridge_Documentation for
more info.
See here for our tests and how we invoke them:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ohf/plu gins/org.eclipse.ohf.bridge.ws/src_tests/org/eclipse/ohf/bri dge/ws/AuditTest.java?rev=HEAD&cvsroot=Technology_Projec t&content-type=text/vnd.viewcvs-markup
Note that the bridge internally calls much more Audit messages like
Glenn wrote (for queries etc).
We are about to publish a full description of log outputs you may use as is.
Here is a sample of the log output (with the Audits):
[INFO ][2006-11-21T21:27:47.072-0800][bridge.conf.TransactionConte xt]
Audit enabled to udp://lswin10.dfw.ibm.com:515
[INFO ][2006-11-21T21:27:47.312-0800][na.audit.syslog.bsd.BSDMessa ge]
Sending Audit message: <13>Nov 21 21:27:47 192.168.1.101 <?xml
version="1.0" encoding="ASCII"?><AuditMessage
xsi:noNamespaceSchemaLocation="healthcare-security-audit.xsd ">
<AuditSourceIdentification AuditSourceID="192.168.1.101"/>
<EventIdentification EventActionCode="C"
EventDateTime="2006-11-21T21:27:47.132-08:00" EventOutcomeIndicator="0">
<EventID code="110107" codeSystemName="DCM" displayName="Import"/>
</EventIdentification>
<ActiveParticipant UserID="testDataSourceId" UserIsRequestor="true">
<RoleIDCode code="110152" codeSystemName="DCM" displayName="Destination"/>
</ActiveParticipant>
<ActiveParticipant UserID="tester" UserIsRequestor="false">
<RoleIDCode code="110155" codeSystemName="DCM" displayName="Source Media"/>
<ParticipantObjectIdentification
ParticipantObjectID=" RID6952^^^HIMSS2005&amp;1.3.6.1.4.1.21367.2005.1.1&a mp;ISO "
ParticipantObjectTypeCode="1" ParticipantObjectTypeCodeRole="1">
<ParticipantObjectIDTypeCode code="2"/>
<ParticipantObjectQuery>ZEdWemRFbHRjRzl5ZEdWa1JHRjBZVWxr</ParticipantObjectQuery >
</ParticipantObjectIdentification>
</AuditMessage>
[INFO ][2006-11-21T21:27:47.502-0800][bridge.conf.TransactionConte xt]
[INFO ][2006-11-21T21:27:47.603-0800][na.audit.syslog.bsd.BSDMessa ge]
<EventIdentification EventActionCode="R"
EventDateTime="2006-11-21T21:27:47.532-08:00" EventOutcomeIndicator="0">
<EventID code="110106" codeSystemName="DCM" displayName="Export"/>
<ActiveParticipant UserID="tester" UserIsRequestor="true">
<RoleIDCode code="110153" codeSystemName="DCM" displayName="Source"/>
<ActiveParticipant UserID="testDataRecipientId" UserIsRequestor="false">
<RoleIDCode code="110154" codeSystemName="DCM" displayName="Destination
Media"/>
ParticipantObjectID="testExportedDataId" ParticipantObjectTypeCode="2"
ParticipantObjectTypeCodeRole="3">
<ParticipantObjectIDTypeCode code="110180" codeSystemName="DCM"
displayName="Study Instance UID"/>
ParticipantObjectID=" RID7502^^^HIMSS2005&amp;1.3.6.1.4.1.21367.2005.1.1&a mp;ISO "
</AuditMessage>
[INFO ][2006-11-21T21:27:47.713-0800][bridge.conf.TransactionConte xt]
[INFO ][2006-11-21T21:27:47.783-0800][na.audit.syslog.bsd.BSDMessa ge]
<EventIdentification EventActionCode="E"
EventDateTime="2006-11-21T21:27:47.733-08:00" EventOutcomeIndicator="0">
<EventID code="110100" codeSystemName="DCM" displayName="Application
Activity"/>
<EventTypeCode code="110120" codeSystemName="DCM"
displayName="Application Start"/>
<ActiveParticipant UserID="dataRecipientId" UserIsRequestor="false">
</AuditMessage>
[INFO ][2006-11-21T21:27:47.893-0800][bridge.conf.TransactionConte xt]
[INFO ][2006-11-21T21:27:47.963-0800][na.audit.syslog.bsd.BSDMessa ge]
EventDateTime="2006-11-21T21:27:47.903-08:00" EventOutcomeIndicator="0">
Activity"/>
<EventTypeCode code="110121" codeSystemName="DCM"
displayName="Application Stop"/>
</AuditMessage>
[INFO ][2006-11-21T21:27:48.053-0800][bridge.conf.TransactionConte xt]
[INFO ][2006-11-21T21:27:48.133-0800][na.audit.syslog.bsd.BSDMessa ge]
Sending Audit message: <13>Nov 21 21:27:48 192.168.1.101 <?xml
EventDateTime="2006-11-21T21:27:48.053-08:00" EventOutcomeIndicator="0">
<EventID code="110114" codeSystemName="DCM" displayName="User
Authentication"/>
<EventTypeCode code="110122" codeSystemName="DCM" displayName="Login"/>
<ActiveParticipant NetworkAccessPointID="initiatingUserNodeIP"
NetworkAccessPointTypeCode="2" UserID="tester" UserIsRequestor="true"
UserName="initiatingUserName"/>
<ActiveParticipant UserID="authenticatingNodeIP" UserIsRequestor="false"/>
</AuditMessage>
[INFO ][2006-11-21T21:27:48.283-0800][bridge.conf.TransactionConte xt]
[INFO ][2006-11-21T21:27:48.334-0800][na.audit.syslog.bsd.BSDMessa ge]
EventDateTime="2006-11-21T21:27:48.293-08:00" EventOutcomeIndicator="0">
Authentication"/>
<EventTypeCode code="110123" codeSystemName="DCM" displayName="Logout"/>
</AuditMessage>
--eishay
Re: new Audit calls on the bridge [message #24570 is a reply to message #24403] Sat, 25 November 2006 02:57 Go to previous message
Audit servers configured for the IBM and MESA RHIOs.
--eishay
Eishay Smith wrote:
> The calls are:
> more info.
> is.
> </AuditMessage>
> Media"/>
> </AuditMessage>
> Activity"/>
> </AuditMessage>
> Activity"/>
> </AuditMessage>
> Authentication"/>
> </AuditMessage>
> Authentication"/>
> </AuditMessage>
> --eishay
Re: new Audit calls on the bridge [message #575545 is a reply to message #24403] Sat, 25 November 2006 02:57 Go to previous message
--eishay
Eishay Smith wrote:
> The calls are:
> more info.
> is.
> </AuditMessage>
> Media"/>
> </AuditMessage>
> Activity"/>
> </AuditMessage>
> Activity"/>
> </AuditMessage>
> Authentication"/>
> </AuditMessage>
> Authentication"/>
> </AuditMessage>
> --eishay
Previous Topic:error when uploading documents
Next Topic:more metadata exposed when doing a document query
Current Time: Wed Sep 17 16:30:50 EDT 2025
Powered by FUDForum. Page generated in 0.20214 seconds
