Home » Newcomers » Newcomers » Make plugins update with sourcecode
Make plugins update with sourcecode [message #243802] Fri, 21 December 2007 04:19 Go to next message
Originally posted by: zhujiangjun2004200.163.com
I am using Equinox, I want to adapt it to my application by modifying some
code of Equinox. But I do not found a way with which I could add or change
codes into Equinox in Eclipse and I could re-compile the changed source
code ,then my application could run in the new Equinox framework.
Is there any way to do this in Eclipse?please tell me,thanks.
Re: Make plugins update with sourcecode [message #243811 is a reply to message #243802] Fri, 21 December 2007 06:04 Go to previous messageGo to next message
Zhu,
You might want to extract them directly from CVS but if the source
plugins are installed, you could also use File->Import...->Plug-in
Development->Plug-ins and Fragments and select Iimport As->Projects with
Source Folders to import them into your workspace where you can modify
them. When you launch your application it should use these modified
plugins from the workspace...
> some code of Equinox. But I do not found a way with which I could add
> or change codes into Equinox in Eclipse and I could re-compile the
> changed source code ,then my application could run in the new Equinox
> framework.
Re: Make plugins update with sourcecode [message #243815 is a reply to message #243811] Fri, 21 December 2007 06:30 Go to previous message
Ed:
Thanks for you rapid reply and correct answer.
Previous Topic:Launch Equinox using source code but not JAR
Next Topic:Error Updating Eclipse
Current Time: Thu Sep 04 05:21:00 EDT 2025
Powered by FUDForum. Page generated in 0.33216 seconds
