| Installed CDT on Linux - Says Java version too old [message #243652] |
Wed, 19 December 2007 12:36  |
Originally posted by: howa.howa.net
Dialog saying "Java version 1.4.2 is not suitable for this product.
Version 1.5 or greater is required".
So I followed the instructions on Sun's site and installed Java version
1.5. Installation appeared to succeed, but apparently Eclipse is still
looking at the old installation. How do I get it to look at the new Java
installation?
| Re: Installed CDT on Linux - Says Java version too old [message #243709 is a reply to message #243658] |
Thu, 20 December 2007 05:38   |
Originally posted by: 4cs6fcg02.sneakemail.com
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enigCB2993FA6DC8A6947EB0C836
Content-Type: text/plain; charset=UTF-8
Content-Transfer-Encoding: quoted-printable
Manfred Stelzhammer schreef:
> Howard Egan wrote:
>> Dialog saying "Java version 1.4.2 is not suitable for this product.=20
>> version 1.5. Installation appeared to succeed, but apparently Eclipse=
>> is still looking at the old installation. How do I get it to look at
>> the new Java installation?
> Try to start eclipse with the parameter "-vm <path to java1.5 vm>"
Or rather, you might make sure the 1.5 Java is the default one.
Type
java -version
on the command line. It should say something like
java version "1.6.0_03"
Java(TM) SE Runtime Environment (build 1.6.0_03-b05)
Java HotSpot(TM) 64-Bit Server VM (build 1.6.0_03-b05, mixed mode)
Note that I already have java 1.6, which I would suggest you to take
too. No reason to use the old Java 5 anymore.
This means you will have to mess around with PATH and stuff. I supposed
you installed the new Java in /usr/local/, then it will suffice to put a
symbolic link to /usr/local/jdk<version>/bin/java in /usr/local/bin.
Alternatively, as root, type
update-alternatives -config java
on the command line and see whether it offers you your new version. If
not, you=E2=80=99ll have to add it somehow. I do not know how that works=
, though.
Even more possibilities: install it by your favorite package manager,
this should do all that stuff for you.
H.
--=20
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.4-svn0 (GNU/Linux)
Comment: Using GnuPG with SUSE - http://enigmail.mozdev.org
iD8DBQFHakY9e+7xMGD3itQRAlcWAJ4lufeA1Ey12gSslPqYr5dhBIX6qQCd HPV3
/Ic0MwLqVN0ScMPX7MMWpyA=
=GG2O
-----END PGP SIGNATURE-----
--------------enigCB2993FA6DC8A6947EB0C836--
| Re: Installed CDT on Linux - Says Java version too old [message #243722 is a reply to message #243658] |
Thu, 20 December 2007 10:01  |
>> Thanks
Better yet is to add that option to eclipse.ini, taking special care to
follow the correct format. There are many examples to be find via Google.
Hope this helps,
Eric
FUDForum. Page generated in 0.09246 seconds
