Home » Eclipse Projects » GEF » [Zest] Basic questions
[Zest] Basic questions [message #243687] Mon, 16 June 2008 05:02 Go to next message
Hi !
I have to graph information from a database, and we have created a
viewer based on GEF. But when i see what can do Zest, it seems that it
can be save us a lot of time ! But i have some basic question to see if
we will not be blocked at some point before switching from GEF to Zest :
- is it possible to remove nodes/connections at demand, for example user
select a node, push "suppr", the node is deleted from the viewer and
from the model (the database).
- Is it possible to add a connection with drag'n drop between 2 nodes ?
- Can i provide a custom Figure for a node ? if we want to draw complex
informations for a node.
- Is there some known limitations, ex: the number of nodes/connections
in the Graph ? (I had some problems with GEF)
Thanks for the informations.
Laurent Marchal.
Re: [Zest] Basic questions [message #243692 is a reply to message #243687] Mon, 16 June 2008 07:02 Go to previous messageGo to next message
I am no expert but I will try to answer your questions.
Removing nodes should be no problem, what I do is: the user selects,
presses delete, then I remove the deleted node from my model, and redo the
layout.
I do not think you can add a connection with drag and drop between two
nodes, you wlll probably have to write this yourself (please correct me
someone if I am wrong).
Custom figures for a node I am told will come out this summer.
I have no performance problem with 500 or so nodes.
I hope this helps, but like I said I have also just started with Zest, so
I am not an expert.
Re: [Zest] Basic questions [message #243714 is a reply to message #243692] Mon, 16 June 2008 09:50 Go to previous messageGo to next message
Thanks for your answers,
I think i will wait if i can not provide custom figures for nodes. This
is very important in my product.
If someone use Zest to edit graphs (create/remove nodes/connections)
please tell me if it's easy to do so.
Regards.
> the layout.
> so I am not an expert.
Re: [Zest] Basic questions [message #243736 is a reply to message #243692] Mon, 16 June 2008 23:56 Go to previous messageGo to next message
Originally posted by: irbull.cs.uvic.ca
Thanks for helping with this Kentusha!
You are right,
1) Adding and removing should work fine
2) Custom figures and documentation are the first two things on the 3.5
development plan. I am just starting that and I will post a preliminary
version here within a few days to get feedback and help drive requirements.
3) We may look at simple drag and drop, but for real "editing", GEF is
more suited for this. Once you get into D&D you probably want undo /
redo, actions, tools, etc.. and this is the whole point of GEF.
4) I'm happy to hear that things work well with lots of nodes. I spent
a bunch of time last year working on optimizations for this. Some of the
layouts will likely keel over and die (since they or O(n^2), but Zest
should do ok) :-)
Cheers
ian
> the layout.
Re: [Zest] Basic questions [message #243746 is a reply to message #243736] Tue, 17 June 2008 02:16 Go to previous messageGo to next message
I should be able to test custom figures for you.
In order to have labels on the top left of the node I draw the labels on
my own layer.
This works, but has the effect that when I drag and drop, the label is
only moved after a layout is invoked (the label is only dropped, but not
dragged).
Re: [Zest] Basic questions [message #243770 is a reply to message #243736] Tue, 17 June 2008 06:17 Go to previous message
Thanks both for your answers.
> You are right,
> should do ok) :-)
> Cheers
> ian
>> the layout.
>> me someone if I am wrong).
Previous Topic:what's is the concept of "Hints" in Draw2D
Next Topic:Zest Layout Algorithmn
Current Time: Sat Jul 26 12:47:45 EDT 2025
Powered by FUDForum. Page generated in 0.04779 seconds
