Zest - Overlapping Nodes [message #240519] |
Wed, 09 January 2008 04:40  |
Hey currently the graph opens with the nodes all overlapping. i saw in previous versions you had a style flag NO_OVERLAPPING_NODES but it has been erased. what would be the new way of achieving that?
Thanks! I really like Zest... very sleek.
[Zest] Re: Zest - Overlapping Nodes [message #240583 is a reply to message #240519] |
Fri, 11 January 2008 00:23   |
Originally posted by: irbull.cs.uvic.ca
Thanks for the kind words :-)
I removed the overlapping style because I didn't really work, or make
sense. The problem is, a user can drag a node anywhere, so what happens
when a node is placed on top of another node. We tried to do some
clever things, but it never actually does what you want.
What I have done, is applied a node overlap removal layout algorithm
after I apply my initial layout.
viewer.setLayoutAlgorithm(new
CompositeLayoutAlgorithm(LayoutStyles.NO_LAYOUT_NODE_RESIZIN G, new
LayoutAlgorithm[] { new
DirectedGraphLayoutAlgorithm(LayoutStyles.NO_LAYOUT_NODE_RES IZING), new
HorizontalShift(LayoutStyles.NO_LAYOUT_NODE_RESIZING) }));
What this does, is it creates a composite layout algorithm, first
applying the directed graph layout, and then shifting the nodes
horizontally so they don't overlap.
Would something like work for you? I also have a the prototype for a
general layout algorithm that removes all overlaps (I actually wrote it
last year during EclipseCon) which I could provide, however, it often
produces terrible graphs because it just keeps pushing everything away
until all the overlaps are gone, and sometimes things get really far away.
ian
Re: [Zest] Re: Zest - Overlapping Nodes [message #243368 is a reply to message #240701] |
Wed, 04 June 2008 05:21  |
Originally posted by: realbondy.gmail.com
Hi Michelle,
I happen to have the similar needs as you, i need to avoid overlapping
figures as i have some decorator on one of them, which is on the other
layer.
I am new to GEF, is it possible that you send some code snippet about
how you do that? Or just some directions.
Any response is highly appreciated!
Thanks!
Binbin Deng
> Thanks Ian!
> it worked but we have a few more needs from the layout so i ended up writing one of my own. it's kind of a tree layout that spreads the nodes from root (one who has no one destines to) down in rows. i can send the code if you like. and i've parameterized the distances beween the nodes to suit different needs.
> i'm having a bit of trouble when writing a layout which relies on the actual model. i'm gonna open a separate thread on that.
FUDForum. Page generated in 0.03479 seconds
