Home » Archived » BIRT » Accessing ODBC data
Accessing ODBC data [message #242890] Fri, 15 June 2007 03:48 Go to next message
Originally posted by: luc.dooms.c-cure.be
Hi All,
I have been working with BIRT to report on some of MySQL data and I'm
pretty impressed with the results so far.
Now, I need to include some MS Access data, data I can only access through
ODBC.
Does anybody has a proven method to do this ?
1. I know that sun has a JDBC/ODBC bridge included the JDK.
Is that the way to go?
How do you include this bridge into the BIRT Managed Drivers?
2. I have also tried the hxtt MS Access JDBC drivers.
They do work for small MS Access tables, but fail with the larger ones.
Your documented experiences are welcome !
Luke
Re: Accessing ODBC data [message #243124 is a reply to message #242890] Mon, 18 June 2007 11:28 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Luke,
You can access a ODBC source by entering
sun.jdbc.odbc.JdbcOdbcDriver as the driver class.
The driver url would be something like:
jdbc:odbc:mydb
Jason
Luke wrote:
> Hi All,
> through ODBC.
> Cheers,
> Luke
Re: Accessing ODBC data [message #243258 is a reply to message #243124] Tue, 19 June 2007 06:13 Go to previous messageGo to next message
Hi Jason,
Thanks for your answer.
Still, jdbc:odbc:mydb is simply not in the options of my 'Driver Class'
list.
So I need to include it by using the 'Manage Driver...'.
But I don't know what JAR file to add.
Anybody ?
Luc
Jason Weathersby wrote:
> Luke,
> jdbc:odbc:mydb
> Jason
> Luke wrote:
>> Hi All,
>> through ODBC.
>> Cheers,
>> Luke
Re: Accessing ODBC data [message #243351 is a reply to message #243258] Tue, 19 June 2007 12:19 Go to previous message
Luke,
You should be able to type in
sun.jdbc.JdbcOdbcDriver as the driver class. It is not in the drop
down, but you can type it in.
the jdbc:odbc:mydb is the url.
Jason
Luke wrote:
> Hi Jason,
> list.
> Anybody ?
> Luc
>> Luke,
>> jdbc:odbc:mydb
>> Jason
>> Luke wrote:
>>> Hi All,
>>> through ODBC.
>>> Cheers,
>>> Luke
Previous Topic:[BIRT2.2RC0 Deployment] BEA Weblogic 8.1.x
Next Topic:Hiding of Blank / Extra Rows
Current Time: Sun Nov 02 15:00:41 EST 2025
Powered by FUDForum. Page generated in 0.03203 seconds
