Home » Newcomers » Newcomers » Importing defaults to src.com
Importing defaults to src.com [message #242687] Mon, 10 December 2007 14:26 Go to next message
Originally posted by: bstone.doubleclick.com
When using eclipse and trying to import a class by setting my cursor on
the class and typing "ctrl-shift-m", the import appears at the top of the
class as "src.com.project.test", instead of simply "com.project.test".
Does anyone know why this is happening and how i can prevent it?
Thanks.
Re: Importing defaults to src.com [message #242742 is a reply to message #242687] Mon, 10 December 2007 22:46 Go to previous message
Originally posted by: wegener.cboenospam.com
Brett wrote:
> Hello,
> the class as "src.com.project.test", instead of simply "com.project.test".
> Thanks.
It sounds like you don't have your source folder setup properly. On the
Java Build Path, the src directory should be defined as a source
directory. That places the com directory in the root and your packaging
should work correctly.
You may need to check the classes that you are importing. Their package
statement may have src as the start of the package statement.
Previous Topic:Project import failure
Next Topic:tag library descriptor?
Current Time: Mon Nov 03 13:21:00 EST 2025
Powered by FUDForum. Page generated in 0.09879 seconds
