Home » Modeling » TMF (Xtext) » [TCS] TCS Version for Eclipse 3.2 (or others)?
[TCS] TCS Version for Eclipse 3.2 (or others)? [message #23748] Sat, 29 November 2008 17:25 Go to next message
Hi Eclipse NewsPortal - eclipse.modeling.tmf:
I have to admit I am confused about obtaining versions of TCS, though I
realize there are changes occurring with this project. I am hoping to use
a version of TCS compatible with Eclipse 3.2 - which I need to use due to
my initial requirement to use Feature Plugin 0.6.6
(http://gsd.uwaterloo.ca/projects/fmp-plugin/) which only works in Eclipse
3.2 apparently. I can't seem to find earlier versions of TCS. Is there a
place I should be looking? My intention is to create a TCS for the Web
Service Modeling Language (WSML) implementation of WSMO framework so I can
transform via ATL to WSMO. Unfortunately, the current WSML-in-XML format
does not have everything I need so I need to transform into the actual
WSML plain text language.
Any assistance which can be provided is appreciated.
Jeff
Re: [TCS] TCS Version for Eclipse 3.2 (or others)? [message #24241 is a reply to message #23748] Fri, 12 December 2008 13:08 Go to previous message
Hi Jeff,
TCS is currently temporarily unavailable from Eclipse.org because of the
delays in the review process.
We have a recent binary build available
( http://www.sciences.univ-nantes.fr/lina/atl/www/tcsdemo/2008 1103/). We
have only tested previous versions under Eclipse 3.2, but it is likely
this new version will work.
Frédéric Jouault
> use a version of TCS compatible with Eclipse 3.2 - which I need to use
> due to my initial requirement to use Feature Plugin 0.6.6
> Eclipse 3.2 apparently. I can't seem to find earlier versions of TCS.
> Is there a place I should be looking? My intention is to create a TCS
> for the Web Service Modeling Language (WSML) implementation of WSMO
> framework so I can transform via ATL to WSMO. Unfortunately, the
> current WSML-in-XML format does not have everything I need so I need to
> transform into the actual WSML plain text language.
> Jeff
Previous Topic:Xtext content assist -
Next Topic:ImportMetamodel, Linker.ext error
Current Time: Fri Nov 07 18:30:40 EST 2025
Powered by FUDForum. Page generated in 0.03198 seconds
